Old 21st February 2003, 23:22   #1  |  Link
litlin
Slow ripping speeds
When I decrytp using DVD Decrypter or SmartRipper, it takes over an hour to rip the DVD because it never rips faster than 1 X. I have the
LITEON LTD-163D DVD-ROM.
It used to rip faster than this. I think the Drive reads at 8x.
I tried the settings with the DMA, but it seems the IDE settins default back to PIO, so no lukc there.
Do you think it has to due with the firmware upgrade on this drive which I did a bit ago, then it slowed down. How can I fix it?
Thanks
litlin is offline   Reply With Quote
Old 22nd February 2003, 12:54   #2  |  Link
killingspree
Newbie Forum Mod
killingspree's Avatar
try the tool that is linked somwhere a bit down in this thread... it worked for me...
http://forum.doom9.org/showthread.php?s=&threadid=43758
regards
steVe
Search the forum, read the forum rules once more and use the search function on doom9.org before posting!
oh btw my amazon.de wishlist
killingspree is offline   Reply With Quote
Old 22nd February 2003, 13:28   #3  |  Link
litlin
I appreciate your elp and will try this right NOW!!
Thanks sooo much
Lit
