Old 9th February 2003, 04:19   #1  |  Link
bobby8798
XviD with BLACK Solid Background looks Terrible !!
Tried encoding 1-pass XviD with colorful moving objects in the foreground against a PITCH BLACK Background
used 3000 kbits (increasing bit rate has zero impact)
changing i-frame quantizer has zero impact (even tried 1-2)
using latest koepi unstable build XviD-02022003-1
tried h263 and mpeg
1 pass CBR, or 100% quality, or quantizer=3
lumi-masking OFF; on is just as bad
CBR smoother from 0-100, no impact
compared this to DivX3, and DivX is far superior than XviD !!!
the XviD encode has a lot of noise in the background which looks really horrible. looks like color from the foreground is leaking everywhere. Extremely blocky color leakage !!!
The divx encode looks very clean. It has only about 10% of the XviD noise.
If the background is lighter gray, the situation REVERSES and the XviD is far superior than the Divx. It seems like XviD has a very serious limitation against SOLID DARK colors ???
anyone know how to fix this?
bobby8798 is offline   Reply With Quote
Old 9th February 2003, 05:38   #2  |  Link
Y7
Use a filter to adjust the levels so that you have more black. Does 2-pass help?
Y7 is offline   Reply With Quote
Old 9th February 2003, 07:41   #3  |  Link
Zarxrax
Zarxrax's Avatar
Maybe you could post a clip to show what you are talking about?
I don't think xvid has any trouble with black, as I just created a test video myself to see if I could cause some trouble in the codec (pure black background with colored text zooming all over the place) and for all quantizers below 8, it looked very nice.
Probably you just need to filter your source some, maybe adjust the levels like Y7 said. Spatial and temporal cleaners might help as well.
Zarxrax is offline   Reply With Quote
Old 9th February 2003, 12:20   #4  |  Link
Teegedeck
Moderator, Ex(viD)-Mascot
Teegedeck's Avatar
Yup; post a screenshot, please.
It's a man's life in Doom9's 52nd MPEG division.
"The cat sat on the mat."
ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl!
Teegedeck is offline   Reply With Quote
Old 9th February 2003, 13:45   #5  |  Link
Koepi
Koepi's Avatar
Or even better: search the avisynth forum for "luma offset".
Use marc's mpeg2dec3.dll and add this to your avisynth scripts:
LumaFilter()
UnFilter(-5,-5) # - is smoothing, + is sharpening
Regards
Koepi
Koepi is offline   Reply With Quote
Old 9th February 2003, 13:49   #6  |  Link
Sigmatador
Posts: n/a
maybe you should use the refdivx's lumimasking code (koepi's build ^^)
great for dark scene ^^
edit: oops just seen: " just as bad" --->
Old 9th February 2003, 14:39   #7  |  Link
iago
retired
iago's Avatar
Listen to Koepi. That issue was discussed extensively in the past and a working solution was finally proposed/achieved in the "Lumi Masking" thread in this very XviD forum.
regards,
iago
Use LumaFilter(-2) / LumaFilter(-3) / LumaFilter(-3,0.8) etc. depending on the source, together with UnFilter.
iago is offline   Reply With Quote
Old 9th February 2003, 16:27   #8  |  Link
Lothar
Thanks for the info, it's the same problem I posted about some time ago
Now I'm gonna test this solution, thanks again
Never loose that feeling
Lothar is offline   Reply With Quote
Old 9th February 2003, 20:30   #9  |  Link
bobby8798
LumaFilter cleans the noisy blocks !!!
It tends to brush out and use one standard color to remove the blocks and noise.
LumaFilter works nicely to remove the noise in a dark background. I will try a setting of (-1) instead of the default of (-2) because I don't want some of the fine details to have its color transformed to black. LumaFilter also tends to add more of those tiny white DOTs.
I didn't try the UnFilter, because it was not part of the avisynth v.250 package.
Thanks to everyone for being so helpful
Old 9th February 2003, 23:24   #10  |  Link
angelyote
The frumious Bandersnatch
angelyote's Avatar
Here's the thread everyone's referencing.
It's well worth reading and is a who's who of doom9 personalities.
educate me
Dave
angelyote is offline   Reply With Quote
Old 10th February 2003, 05:45   #11  |  Link
McQuaid
I also was recently dealing with that issue. I tried block buster and its seems to have solved the problem quite nicely. I did not try the luma/unfilter trick yet though. The reason I thought block buster would be better suited for this is because it is selective on where it adds noise instead of unfilter doing this everywhere.
Or am I not understanding the effect of the combination of luma/unfilter?
But even though a workaround has been found for this. It's strange the problem is there much more in mpeg4 than mpeg1. I had a tv clip that had this problem and the mpeg1 encoding barely showed the blocks whereas xvid had this problem no matter what I set the bit rate at.
McQuaid is offline   Reply With Quote
Old 10th February 2003, 05:52   #12  |  Link
MaTTeR
AC3 5.1 Addict
MaTTeR's Avatar
Well actually none of us have yet to figure out why it works so well. lol
I've been scratching my head about the same thing. All the MPEG-1 & 2 encoding I've done never really show the blocks during playback but it's a constant battle with all the MPEG-4 codecs
Need AC3 & SPDIF setup info?
MaTTeR is offline   Reply With Quote
Old 10th February 2003, 19:27   #13  |  Link
lamer_de
Member
lamer_de's Avatar
But it is aswell 14 pages of tech talk. I don't have either the time nor the concentration to read up such a huge text just to find the solution on page 10 of 14. I have no problem with reading 10 pages of "me too" or "Great work", but such threads where every post could contain the information and which deal with very technical settings are just over my head. This is aswell true for some other popular threads, which reach up to 30 pages or more.
Sure, the information is there, but a more "user-friendly approach" (you could call it aswell "cheap solution for the lazy bums") wouldn't hurt in my eyes (like in this thread, it saved me reading the 14 pages). Maybe if a solution is found on such topics, it could be added to the first post or made a link to the post which contains the solution. Or made a sticky for some time?
Only my 2 cents,
lamer_de
lamer_de is offline   Reply With Quote
Old 10th February 2003, 20:59   #14  |  Link
bobby8798
It would be nice if threads like that were deleted, and the conclusions / solutions drawn be added to an "XviD Tips & Tricks"
Sticky Post
Old 10th February 2003, 22:36   #15  |  Link
Koepi
Koepi's Avatar
Delete all that knowledge? Are you serious?
Sometime later we might need such infos.
Not believing what I read,
Koepi
Old 11th February 2003, 00:09   #16  |  Link
Belgabor
VDubMod Devel
Belgabor's Avatar
But this part
Sticky Post
is actually a good idea (imho).
VirtualDubMod [SourceForge : Tracker/DL] (FAQ, Some rules)
Be sure to also download the latest DLL package or get the all inclusive package!
Before you post questions, please read the VirtualDub and/or VirtualDubMod FAQ.
If you have a bug report or feature request for VirtualDubMod, be sure to read the rules first.
We give 100% of your donations to the Open Source community
Belgabor is offline   Reply With Quote
Old 11th February 2003, 00:10   #17  |  Link
McQuaid
Well, I've been trying SansGrip's Blockbuster a little more and have had amazing results with this setting:
Blockbuster(method="dither",block_size=3,luma_offset=-2,luma_threshold=30,detail_min=1, detail_max=30)
Although, I saw someone else post the block_size=3 and gave it a try, but I think it should divide evenly into the frame, no?
On the encode I just tested of a TV cap of a cartoon, I had to look out for dark blocks watching through my TV, while normally they are so glaring it's unacceptable.
Dither seems to be the key, as it stop the blocks from having a 'life of their own' (i.e. moving around or flickering where the image is relatively static).
SansGrip mentions in the readme that dither is experimental so maybe this can still be improved.
The place where I see blocks the most now is in somewhat bright solid colour areas. Instead of increasing the variables, I wonder if blockbuster can be modified to tackle a frame at both ends of the luma scale?
Anyways try it out and report back your findings.
Get his plugin here.
Old 11th February 2003, 07:34   #18  |  Link
Teegedeck
Teegedeck's Avatar
Give the 'sharpen'-method (instead of 'dither') a try; very nice, too.
Old 11th February 2003, 13:10   #19  |  Link
drebel
Removing existing mpeg2 macroblocs and not reproducing mpeg4 marcoblocks are two completely different things...
Blockbuster performs the first one, lumafilter+unfilter make sure about the second
I'd go with Teegedeck on this one : "sharpen" seems to be the key for me
regards,
george
PS: u could try the luma_offset=-2 option of blockbuster with unfilter(+x,+x) as a combination of both
drebel is offline   Reply With Quote
Old 11th February 2003, 21:51   #20  |  Link
McQuaid
Ok, I'm trying out sharpen right now to see the results.
Regarding luma filter/unfilter.
Almost every post I've seen is from someone using the luma function that's part of mpeg2dec3.
I'm doing tv captures so obivously, I am not using mpeg2dec3. How do I offset luma without it, if I'm not using blockbuster.
I saw one post using lumafilter(), but I can't find anything on this. Is this part of aviysynth 2.5? I'm still using 2.07.
