Old 5th February 2003, 07:00   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Hey Arnold!: The Movie [Region 1] Disabling the Aspect Ratio Selection Menu
Hey Arnold!: The Movie [Region 1] (Disabling Aspect Ratio Selection Menu )
Courtesy of 2CL
For those who have children that love watching the Hey Arnold! Cartoon TV series.
2/5/2003 UPDATE: Widescreen steps 7 and 8 have been added to disable titleset 3's Aspect ratio selection menu.
This is a guide on just getting rid of this movieís aspect ratio selection menu. There are still other stuff left for you,on your own, to disable and strip out to get the your movie to fit. For example, unwanted audios. Iíve provided edits for either widescreen or fullscreen.
Iíve cut down my cheat sheets to just doing more difficult DVDs like ones with aspect ratio selection menus or menus that are very complicated.
Tool I used:
SmartRipper 2.41
IFOedit 0.95
VTS_02_* is our Fullscreen movie
VTS_03_* is our Widescreen movie
WIDESCREEN ONLY
1. Rip all files except VTS_02_1 to VTS_02_4.VOBs.
2. Region Free all IFOs and save if RCE is detected.
3. In VTS_02_0.IFO/VMG Overview/Menu Language Unit, delete playback on the following.
Menu 7: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 5)
Tranlsation: Disable Aspect Ratio Selection Menu after Play button is pressed
4. In VTS_02_0.IFO/PGCITI_UT/VTS_PGC_8/PGC Command Table, insert a post command by right clicking post command #1. Edit as follows. To edit new Post commands, double-lieft clicking on line and enter new hex value.
OLD > 1.Post Command NOP [00 00 00 00 00 00 00 00 ]
OLD > 2.Post Command If GPreg<7> > (cmp-val)<0><' then Goto line# 8 [00 d1 00 07 00 00 00 08 ]
NEW > 1.Post Command Set GPreg<6> mov (set-val)<2> [71 00 00 06 00 02 00 00 ]
NEW > 2.Post Command If GPreg<7> > (cmp-val)<0><' then Goto line# 9 [00 d1 00 07 00 00 00 09 ]
Translation: Movie plays widescreen when aspect ratio selection menu is disabled.
5. In VTS_02_0.IFO/VMG Overview/Menu Language Unit section, highlight the follow line and press ďDelete PlaybackĒ button.
Menu 8: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 5)
Translation: Aspect ratio selection menu is disabled
6. Save VTS_02_0.IFO
7. Repeat steps 4 and 5 for VTS_03_0.IFO
8. Save VTS_03_0.IFO
9. Get VTS Sectors
10.DVD-Play and test
Thatís it for getting rid of the fullscreen movie.
FULLSCREEN ONLY
1. Rip all files except your Titleset 3 files (VTS_03_*.*).
4. Save VTS_02_0.IFO
5. Get VTS Sectors
6. DVD-Play and test
Thatís it for getting rid of the widescreen movie.
2COOL
