Old 2nd February 2003, 23:51   #1  |  Link
Dionysus
(s)vcd onto DVD-R??
I was wondering if I were to encode a movie using the vcd format instead of the divx .avi would I still be able to make a huge (s)vcd and put it onto a dvd-r disc without having to buy a dvd-writer and instead of putting each movie onto two or three discs inorder to make it decent quality?? Cuz you can buy bulk dvd-r's for dirt cheap and if that works I'd rather just do that than go out and spend the money on a writer if I don't have to?? or is there a special burning process that goes into a dvd-writer that a normal cd-writer doesn't have?? let me know... thanks ppl.
Dionysus is offline   Reply With Quote
Old 3rd February 2003, 09:11   #2  |  Link
dani82
A D S
dani82's Avatar
i have never once though of that possibility; but i doubt it (unless someone made a new type of cd-burner), cause i'm sure someone in this forum would have said so, if it was possible.
it's better to play dumb, than to act smart
a fan of irony & sarcasm
dani82 is offline   Reply With Quote
Old 3rd February 2003, 19:37   #3  |  Link
htc10825
Gladiator
DVD has a diff. wave length as CD-R/CD-RW. Other optical elements must be used.
The producer of DVD-Burner must pay the licens fee to SONY/Toshiba 10 times as high as that for CD-Burner.
It's not meaningful to make such fantasy.
htc10825 is offline   Reply With Quote
Old 7th February 2003, 18:37   #4  |  Link
jshumate
VCD video is valid for DVD as is. You have to convert the audio to 48 KHz from 44 KHz. Tools such as BeSweet can do this conversion for you, but you should expect some slight audio degredation in this conversion. You may or may not notice it. I don't recommend that you burn VCD format to DVD-R as DVD players do media detection and if they see a DVD disc, they will assume that it has DVD format on it and never check for VCD format. http://www.vcdhelp.com has a guide on doing VCD to DVD conversion.
In summary - yes, it is possible to burn your VCDs to DVD-R, but you should burn them in DVD format for best results.
jshumate is offline   Reply With Quote
Old 8th February 2003, 00:52   #5  |  Link
Dionysus
clarity...
so your saying that I can go out and buy a DVD-R/W (RW just for trial) and reformat my movies from DivX to SVCD(which i am doing already with TMPGEnc) and then put the DVD-R/W into my REGULAR CD-R/W and it will burn it onto it and I will have an SVCD the size of something like 4.5GB's? Cuz I followed the guide that you posted for me and foudn what I was looking for but I'm not sure if I just go into Nero and choose SVCD NTSC and then insert my DVD-R/W and hit burn and it should work in my DVD Player... BTW I've got a JVC XV-S502SL
thanks ppl.
Old 8th February 2003, 09:53   #6  |  Link
dani82
A D S
dani82's Avatar
i think jshumate didn't quite understand your question; no you can't burn a dvd-r/w on a regular cd-burner (unless someone didn't make a new type of cd-burner).
i think what he meant to say was:
you can burn (s)vcd on a dvd using a dvd-burner.
try this, the first line of dvd-vcd should explain everything http://www.dvdrhelp.com/vcddvdr.htm
Old 8th February 2003, 14:28   #7  |  Link
htc10825
Gladiator
I think the people from Western Canada do not want to give up their dream so easy.
Old 8th February 2003, 19:56   #8  |  Link
jorel
Posts: n/a
Re: (s)vcd onto DVD-R??
maybe the dream is coming:
http://kvcd.net/forum/viewtopic.php?...a2d32d57b3b9a3
and
http://www.kvcd.net/guides/kguide/kvcdguide.htm
and all information that you need:
Old 8th February 2003, 22:24   #9  |  Link
Dionysus
thanks jorel... I don't know what the deal is how no one that replied knew anything about KVCD and that website or similar stuff but the ppl on there that I've talked to are proclaimed that this method is flawless. anyways thanks again man... gonna try and see if this sheit works..
ttyl
Old 8th February 2003, 22:52   #10  |  Link
jorel
Posts: n/a
ttyl
for me is very good,and i use the dvd2svcd program to make my kvcds.
i get 142 minutes in 1 cdr 700mb with good quality and
120 minutes (480x480 mpeg1) with fantastic image!
editing:
i don't have a dvd burner,i only have cdr-w but
some people there got the results that you want and more.
see the kdvd thread!
Old 9th February 2003, 22:38   #11  |  Link
jorel
Posts: n/a
hi again Dionysus,
i search for long time to find this:
http://kvcd.net/forum/viewtopic.php?...25372affaf815a
Old 25th March 2003, 13:45   #12  |  Link
dvd_maniac
capture direct to 48khz?
I own an ati aiw capture card. I can record directly to vcd mpg format but I read that it needs 48khz audio. What if I capture directly to 48khz using mmc edit capture profile?
dvd_maniac is offline   Reply With Quote
Old 28th March 2003, 05:38   #13  |  Link
jorel
Posts: n/a
Re: capture direct to 48khz?
sorry for late answer friend...internet problems here!
as i wrote,i don't have a dvd burner,i only have cdr-w but
many people there got the results that you want and more.
my english is poor and i can't post it.
trying to help you i post this links:
read please.
[IMG] code is Off
