#1 | Link |
Retired
AutoFitCD and D2SCCD Plugin
AutoFitCD v1.5 is out. This is a plugin for DVD2SVCD that will provide you with most accurate cropping and resizing, optionally (macro)block and TV overscan optimized. Saves bitrate and can speed up encoding. Download AutoFitCD v1.5 You'll also need the famous FitCD tool, get it here: http://d.moyon.free.fr/CCE/FitCD_v112.zip EDIT Please note : AutoFitCD is designed to work with FitCD 1.1.2, I'm sorry to say that there will be no updates for newer FitCD versions. Anyway, the source code is included and free so if somebody wants to update it to support the latest FitCD, please go ahead! Previous messages on this topic can be found at http://forum.doom9.org/showthread.php?s=&threadid=43944 (thread is now closed). Screenshot can be found here. Here is the readme. Code:
AutoFitCD Crop and Resize Plugin for DVD2SVCD v1.5 by RB
Release : 1.5
Date : Friday, August 29, 2003
1. What's this?
2. How to install
3. Usage
4. Known issues
5. Help!
6. Freeware
7. Notes
8. History
1. What's this?
AutoFitCD is a plugin for DVD2SVCD (see
http://www.dvd2svcd.org) that seamlessly integrates FitCD, the
most powerful MPEG resizing and cropping utility (see
http://shh.dvdboard.de/) with DVD2SVCD. Black borders are
automatically cropped before resizing and you'll get all the
advantages of FitCD such as super accurate cropping and block
optimized resizing, optionally optimized for TV overscan,
without having to edit the AVISynth script in DVD2SVCD
manually. Overall, this will allocate more bitrate to the
actual motion area and can speed up encoding by as much as 10%.
2. How to install
Simply run AutoFitCDSetup.exe and follow the instructions.
AutoFitCD requires FitCD, get it first from
http://shh.dvdboard.de/. The plugin, Readme and source code
will be installed to a AutoFitCD subdirectory in your DVD2SVCD
installation folder. Note that this plugin supports both
AVISynth 2.0.x and 2.5.x but you need to reinstall it after
switching AVISynth versions.
Please also read the FitCD documentation.
3. Usage
Start DVD2SVCD, go to the Frameserver tab and select "AutoFitCD
Detect Borders" from the Avisynth Setup dropdown. Now go to the
Conversion tab, load the AVI/IFO/DVD and click "Go! - Preview
video". There will be lines indicating where AutoFitCD detected
black borders. Click "New Frame" until the motion area is
properly detected. If it is an overall very dark movie and the
motion area is not being well detected, lower the Borders
Threshold value at the bottom of the preview window (0-255,
default is 25).
Now click the "AutoFitCD >>" button in the preview window and
FitCD will be launched with all the correct settings (motion
area and borders detected during the preview, source and target
aspect ratio etc.). The preview window will automatically
update to reflect the optimized cropping and resizing
calculated by FitCD.
Note that there are two modes of operation. If your screen
resolution is lower than 1024x768, FitCD will run in a separate
window ("Standalone"). The only settings we are interested in
are the ones in the lower "MPEG Resizing" and "AviSynth Script"
area. If your screen resolution is 1024x768 or higher, FitCD
will be run in "Plugin" mode, meaning that the controls in the
above mentioned area will appear in the DVD2SVCD preview window
below the video preview, making it much more convenient to work
with the preview and FitCD controls. You can force either
Plugin or Standalone mode by editing the "Plugin" value in the
[FitCD] section of AutoFitCD.ini. 0 means Standalone, 1 means
Plugin and -1 is automatic depending on screen resolution (the
default).
You can now change settings in FitCD and the preview will
automatically update accordingly (note that the destination
resolution combo box in FitCD will be disabled unless you
switch the DVD2SVCD level to 'Advanced' on the Misc. tab). The
"Save custom AVS" (Standalone)/"Edit AviSynth Script" (Plugin)
button need only be used if you want to save a manually edited
AVISynth script, all other changes in the GUI are automatically
transferred to DVD2SVCD (for instance, try modifying the TV
overscan setting and watch the video preview). Note that if you
change some setting in the FitCD GUI, any manual modifications
you made to the AVISynth script will be lost.
If you are satisfied with the results, close the preview window
and start your encode (Go - Rip and convert/Start conversion).
Note that on the Frameserver Tab, the selected setup is now
"FitCD", which is the (relevant parts of) the AVISynth script
generated by FitCD. Note that this setup cannot be used for any
other movie but the one you have currently loaded, make sure to
start over with "AutoFitCD Detect Borders" for every new movie.
4. Known issues
- Requires DVD2SVCD 1.1.0 build 1 or later
- Tested with FitCD v1.1.2 only (the latest version as of
writing this), but should work with older/newer versions.
5. Help!
For suggestions, bug reports and general discussion, please
register at http://forum.doom9.org and post to the following
thread: http://forum.doom9.org/showthread.php?s=&threadid=44445
If you feel like you absolutely need to contact me directly,
again register at http://forum.doom9.org and send member RB
(me) a private message.
6. Freeware
AutoFitCD is freeware and source is released under GPL. It is
based on the AutoCrop AVISynth plugin by Glenn Bussell
available at http://www.videofringe.com/autocrop/. Thanks,
Glenn!
7. Notes
Setup adds two AVISynth script sections, [AVISYNTH_AutoFitCD
Detect Borders] and [AVISYNTH_FitCD] to the default
DVD2SVCD.INI file. If you use multiple INI files, copy and
paste these sections to the other INI file(s), start DVD2SVCD
and load the INI file on the Misc. tab. Now go to the
Frameserver tab and select the AutoFitCD Detect Borders
Avisynth setup. Click the "..." button to the right of the
second line and modify the INI path to point to the INI file
you just loaded. You only need to do this once for each INI.
The AutoFitCD plugin uses an extended version of the original
AutoCrop plugin's parameter list, the first six parameters are
new so the original parameter list is shifted by six and I
modified a few defaults. You can still modify the original
AutoCrop parameters by editing DVD2SVCD.INI, see the Readme in
the download at http://www.videofringe.com/autocrop/.
8. History
29/08/2003 v1.5
- added support for DVD2SVCD 1.2.1 build 1 and newer
12/05/2003 v1.4a
- improved detection of source video parameters for
AVI sources (AVI2SVCD)
- when PAL (source) is unchecked and PAL (destination)
is being checked/unchecked in AutoFitCD preview,
'NTSC To PAL' option in DVD2SVCD is now automatically
checked/unchecked accordingly
25/03/2003 v1.4
- Added support for AVISynth 2.5
- Bug fixed in 1.3c would sometimes still show up. Now
definitely fixed.
17/03/2003 v1.3c
- Fixed: sometimes, when Aspect ratio was set to
"Anamorphic (no borders, encoded as 16:9)" in DVD2SVCD,
FitCD would calculate an incorrect cropping area which
resulted in a distorted image.
04/03/2003 v1.3b
- Removed support for AVISynth 2.5. It didn't work.
Once DVD2SVCD supports AVISynth 2.5, I'll add it
back in and do it right.
- Added: warning message when closing the preview
window without having clicked the AutoFitCD
button.
28/02/2003 v1.3a
- Added: Support for AVISynth 2.5. Untested.
- Fixed: AVISynth script was not properly written to
dvd2svcd.ini on random occasions.
Sorry for this.
26/02/2003 v1.3
- Added: FitCD Plugin/Standalone mode
- Added: when DVD2SVCD Deinterlace mode is set to "Keep
Interlaced", vertical crop round-to in FitCD is
automatically set to 4 as recommended by the
FitCD author.
03/02/2003 v1.2
- Fixed: sometimes the [AVISYNTH_FitCD] section in
dvd2svcd.ini was not updated properly.
29/01/2003 v1.1
- Fixed: anamorphic source was not properly detected
unless DVD2SVCD level was set to Advanced
- Changed: improved usability, better integration of
FitCD, realtime preview
24/01/2003 v1.0
- First release
_____________________________________________________________
Germany, May 2003
#2 | Link |
Retired
D2SCCD Plugin
D2SCCD v1.3d is out, a plugin for DVD2SVCD that will let you use pictures from your movies for the Change CD picture, add audio to the title picture and more. Previous messages on this topic can be found at http://forum.doom9.org/showthread.php?s=&threadid=40374 (thread is now closed) Download D2SCCD v1.3d Here's the readme (screenshot below): Code:
DVD2SVCD Change CD Picture (D2SCCD) 1.3d by RB ============================================== Release : 1.3d Date : Monday, May 12, 2003 1. What's this? 2. How to install 3. Settings 4. Known issues 5. Help! 6. Freeware 7. History 1. What's this? --------------- D2SCCD is an utility you can use with DVD2SVCD (see http://www.dvd2svcd.org) to dynamically generate "Change CD Pictures" during DVD2SVCD's conversion process. With D2SCCD installed, if you set up DVD2SVCD to use a Change CD Picture, then for each (but the last, of course) CD image file DVD2SVCD builds, D2SCCD will create a Change CD Picture from either the last movie frame on the current CD or the first movie frame on the next CD (see 2. How to install). It will also put some configurable text on that picture. All you need to do is to install D2SCCD as described below, configure it, and your CD image files created by DVD2SVCD will use this "movie based" Change CD Picture. To make a long story short, the visual effect of this is that at the time the current CD has finished playing, the movie pauses and your custom "Need next CD" text is being displayed. This is something I wanted for my SVCDs for a long time. It's a pity we have to change CDs most of the time, I think this makes it a little more bearable :-) D2SCCD can also "fix" DVD2SVCD's handling of Title and Last CD pictures and add audio to your Title pictures, see "3. Settings", below. 2. How to install ----------------- Simply run D2SCCDSetup.exe and follow the instructions. The plugin, Readme and source code will be installed to a D2SCCD subdirectory in your DVD2SVCD installation folder. 3. Settings ----------- ---Preview--- The Preview frame provides a preview as to how a a dynamically generated Change CD picture with text will look like. ---Text Settings--- Enter the text you want to place on each generated Change CD picture. Note that as shown in the default Text Setting, you can use the %d token to insert the next CD number at runtime. For instance, for a 3 CD movie, if you enter "Need CD %d, please..." in the Text box, you'll see Need CD 2, please... Need CD 3, please... on your screen when you play the movie and it's time to change CDs. If the text is too long to fit into a single line, it will be wrapped automatically. You can force a line break using an '\n' in your text (example: Please insert disk %d...\n\nCome on, get up!) Click "Font..." to choose a different font for the text, check "Drop Shadow" to add a drop shadow effect to the text. ---Picture Frame--- Select which frame from the film to use for the Change CD pictures. This can be either the last frame on the current CD or the first on the next CD. If you want to use the latter, you should uncheck "CD Overlap seconds" on the bbMPEG tab in DVD2SVCD, otherwise the "movie paused" effect is gone when the Change CD picture is displayed because the picture will be actually a few frames back. If you want a specific first/last picture frame, just use Frame Selection in DVD2SVCD and split at the desired frame. Note that D2SCCD will generate Change CD pictures only if you actually check "ChangeCD pic." on the CD Image tab in DVD2SVCD. ---Configuration--- [ ] Integrate with DVD2SVCD This needs to be checked for D2SCCD to be called by DVD2SVCD during the CD image creation process so D2SCCD can do its work. If you put D2SCCD in the wrong directory (i.e. not a directory inside the DVD2SVCD folder), this option will be unavailable. Checking this option will actually change the 'VCDXBuild' path on DVD2SVCD's CD Image tab to point at D2SCCD. D2SCCD does it's work and then in turn calls VCDXBuild to generate images. As you may guess, this also means that D2SCCD is only useful if you mark the 'VCDXBuild' radio button in DVD2SVCD - CD Image tab. [ ] Handle Title Picture/Handle Last CD Picture This is a "fix" for DVD2SVCD's somewhat strange handling of Title and LastCD pictures. DVD2SVCD does some resizing and adds borders around the pictures which most of the times screws up the pictures aspect ratio and well, looks not so well. So if you check "Title picture" and/or "LastCD pic." on DVD2SVCD's CD Image tab and check the appropriate boxes in D2SCCD, D2SCCD will also take over the task of generating the Title/LastCD MPEG stills from the pictures you pointed at in DVD2SVCD. For best results, use 768x576 pictures for PAL SVCDs and 640x480 pictures for NTSC SVCDs. Images should be true color and must be in the Windows Bitmap (.BMP) format. [ ] Add Audio to Title Picture This let's you play an MPEG-2 audio file while the Title picture is being displayed. While the audio plays, press either Next, Play, Return or key 1 on your remote to start the main movie. By default, the audio is played once and then after a 5 seconds delay the main movie starts automatically. For this to work, 'Title picture' has to be checked in DVD2SVCD on the CD Image tab and the audio file name must exist with the same file name as the Title picture, but an .MP2 extension. For example, if your Title picture in DVD2SVCD is C:\Program Files\DVD2SVCD\DefaultTitlePicture.bmp, then the expected audio file name is C:\Program Files\DVD2SVCD\DefaultTitlePicture.mp2. It doesn't harm if you check this option but the audio file doesn't exist, just audio won't be added to the Title picture then. Note that the audio file needs to be really an MP2 (MPEG Layer 2 Audio) file, it cannot be some other format renamed to *.mp2. You can use BeSweet that comes with DVD2SVCD to convert your favorite audio file to MP2. You may want to lower the CD sizes on DVD2SVCD's Bitrate tab a little bit (just type it in) if you plan on using larger audio files (~ more than 500 kB) because DVD2SVCD is unaware of the audio file addition which may result in slightly too large CD image files. [ ] Loop infinitely As you may guess, this plays the title audio forever in a loop. Press either Next, Play, Return or key 1 on your remote to start the main movie. ---MPEG Stills Quality (kB)--- This controls the maximum size (and thus quality) of the various Title/Last CD/Change CD MPEG "picture" stills generated by D2SCCD (still frames on SVCDs are not really pictures but special MPEG Still Picture streams). Leave this at maximum quality (200 kB) unless you get slightly too large CD image files. The MPEG stills will be usually smaller, but never larger than what you specify here. [ ] Hacked (force 480p) Force MPEG stills horizontal display size to be 480 - standards say 540 or 720 but some DVD/SVCD players screw up with these values (check this if you are using the "VCD Header Trick" plugin). Click OK to save your custom settings. Of course you can re-configure D2SCCD this way at any time. D2SCCD will log it's activities to file D2SCCD_MJPEGTools_log.txt in the directory where the bin/cue files are created. Tile/Change CD/Last CD Pictures (converted to JPEG) generated by D2SCCD can be found in the 'Muxed' folder of the current encode. 4. Known issues --------------- - picture quality will not be optimal for Win9x/ME users. Sorry, no fix for this unless I find some free high quality image resizing code so I no longer have to use StretchBlt() (Win9x/ME does not support the HALFTONE stretch blit mode which produces high quality images in NT/2000/XP). 5. Help! -------- For suggestions, bug reports and general discussion, please register at http://forum.doom9.org and post to the following thread: http://forum.doom9.org/showthread.ph...082#post251082 If you feel like you absolutely need to contact me directly, again register at http://forum.doom9.org and send member RB (me) a private message. 6. Freeware ----------- D2SCCD is freeware. No strings attached. D2SCCD was basically written by "plugging it into" the DVD2AVI source code and also uses Smalleranimal's free jpeglib library (http://www.smalleranimals.com/jpegfile.htm). Source code for D2SCCD is included and released under GPL. The MJPEGTools included with D2SCCD are not written by me, they are a Win32 compilation of the MJPEG/Linux tools (http://sourceforge.net/projects/mjpeg), the binaries included here can be found at ftp://ftp.vcdimager.org/pub/mjpegtools/. 7. History ---------- 12/05/2003 v1.3d - Fixed: when set to handle title and last CD picture, created title and last CD picture in NTSC format even though DVD2SVCD performed a NTSC to PAL conversion. 22/04/2003 v1.3c - Reverted to MJPEGTools v1.6.0 because some people reported problems obviously caused by v1.6.1 04/03/2003 v1.3b - Added "Hacked" option to set MPEG stills horizontal display size to 480 (check this if you are using the "VCD Header Trick" plugin). 26/02/2003 v1.3a - Updated MJPEGTools to v1.6.1 29/01/2003 v1.3 - Added: D2SCCD now better coexists with other VCDXBuild plugins. Install any other plugin first and then start d2sccd.exe and simply click OK. - Fixed: Title and Last CD pictures were not anamorphic when handled by D2SCCD and you created an anamorphic SVCD 09/01/2003 v1.2 - Added: Title audio looping is now optional - Added: Change CD Text can now be multiple lines - Added: warning when title audio file cannot be found - Changed: Title audio file is now expected in non-multiplexed MP2 format (*.mp2) 17/12/2002 v1.1 - Added: handling of Title/Last CD pictures - Added: option to add audio to Title picture - Added: MPEG Stills quality setting - Added: Integrate with DVD2SVCD option (you no longer need to change the VCDXBuild path in DVD2SVCD manually) - Fixed: %d token was sometimes replaced by the number 2 in the .INI file when clicking OK - Fixed: preview was sometimes not properly repainted 13/12/2002 v1.0 - First release on Friday the 13th... :-) _____________________________________________________________ Germany, April 2003 Last edited by RB; 3rd November 2006 at 06:57. |
#3 | Link |
miau
Thank you, your plugins are great
"... but where are those missing pieces of eternal soul, I can feel them but I can't reach them with my vision" Petition for a software patent free Europe Another vision of what happened at 9/11
#5 | Link |
miau
@winxi
You can delete your posts. This problem has also happened to me 3 or 4 times.
#6 | Link |
Moderator & Mediator
Thank you for the hint, onesoul
!I hope, that nobody minds that the beginning of this thread is quite off topic .greets, winxi
thanking DVD2SVCD for helping me to make the best SVCDs around!!! |
#7 | Link |
Retired
Here's something you may found useful: if you installed AVISynth 2.07 or use the latest version of DVD2SVCD released today (it updates AVISynth to 2.07), edit line 8 of section [AVISYNTH_AutoFitCD Detect Borders] in dvd2svcd.ini as follows:
8=AddBorders(0,^BorderTop,0,^BorderBottom,$A0A0A0) or use a color of your choice for the last parameter (like HTML color code). This will give you a better idea of what the real movie borders are because the borders that are added just to make the preview look nice will be in a different color. @DVD2SVCD: I hope you don't mind me stealing the "Repaint frame" button in the preview window in the new version, but since it's always disabled, I thought it was OK.
#10 | Link |
Question about D2SCCD
Okay I've got d2sccd 1.3 working now with vcd header 0.4 and my images are being made, and the movie plays fine, I just have one problem left. My Title and Last CD pics are the correct one's, but my change cd pic is still the little white hand and cd. Im not getting the last frame of the first disk.
Also its probly just my standalone dvd player but my title change and last cd pics don't show up on my standalone dvd player (Panasonic RV32) but they do on my computers dvd. Here is a look at my last rips log file: WNASPI32.DLL 4.71.1.0 -------------------------------------------------------- - 01/02/2003 8:26:20 PM - DVD to SVCD Conversion - DVD2SVCD ver. 1.1.1 build 2 -------------------------------------------------------- Initializing Initializing finished. -------------------------------------------------------- - 01/02/2003 8:26:26 PM - DVD2AVI -------------------------------------------------------- Creating DVD2AVI INI file: - C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI Variable settings: iDCT_Algorithm: 32-bit SSE MMX Executing DVD2AVI. Executing DVD2AVI. Commandline: "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[D:\DVD Rips\Analyze This\VTS_01_1.vob,D:\DVD Rips\Analyze This\VTS_01_2.vob,D:\DVD Rips\Analyze This\VTS_01_3.vob,D:\DVD Rips\Analyze This\VTS_01_4.vob] Analyzing DVD2AVI Project file Force Film activated! Framerate: 23976 DVD2AVI processing done. -------------------------------------------------------- - 01/02/2003 8:28:14 PM - Free on drive C: 23076.84 mb - AUDIO Extraction -------------------------------------------------------- Found AC3 stream id: 0x80 Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 Audio1 delay: -84 ms Audio extraction finished. -------------------------------------------------------- - 01/02/2003 8:30:30 PM - Free on drive C: 22792.87 mb - AUDIO conversion -------------------------------------------------------- Encoding Audio. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 Executing BeSweet. Commandline: "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.mp2" -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -ota( -d -84 ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s ) Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished. Audio conversion finished. -------------------------------------------------------- - 01/02/2003 8:50:20 PM - Free on drive C: 22650.87 mb - Converting Pictures -------------------------------------------------------- Converting: C:\Documents and Settings\HughFrogger\My Documents\My Pictures\10068157.bmp Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp Converting: C:\Documents and Settings\HughFrogger\My Documents\My Pictures\10068157.bmp Finished converting pictures -------------------------------------------------------- - 01/02/2003 8:50:42 PM - Free on drive C: 22648.75 mb - Video Encoding using Cinema Craft -------------------------------------------------------- Executing Cinema Craft Encoder. StreamSectors: 1663691176 AudioSectors: 151794384 VideoPAPO: 23420088 ScanOffsetBytes: 178477 SeqAligningBytes: 11343218 DVDBytes: 0 VideoEndHeader: 8 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 900.00 PureMPEGStream: 1476955001.20 Seconds: 6240.33 CalcMPEGStream: 1476955001.20 Frames: 148731 CDSize: 800.00 Number of CDs: 2 Cut point 795.00 Variable Settings: Frames: 148731 Anti Noise Filter: Off Passes: 4 Image Quality: 17 VAF file creation: On Video Encoding Mode: Multipass VBR Min. bitrate: 300 Max. bitrate: 2530 Avg. Bitrate: 1893 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec.dll") mpeg2source("C:\PROGRA~1\DVD2SVCD\Movie\DVD2AV~1.D2V") BicubicResize(480,360,0.0,0.6) AddBorders(0,60,0,60) ResampleAudio(44100) ----AVS End---- Closing program CCE Max Speed: 1.440 Video Encoding finished. -------------------------------------------------------- - 02/02/2003 2:51:48 AM - Free on drive C: 21212.35 mb - Video Pulldown -------------------------------------------------------- Executing Pulldown. Commandline: "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\Program Files\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC.mpv" "C:\Program Files\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.mpv" Video pulldown finished. -------------------------------------------------------- - 02/02/2003 2:55:28 AM - Free on drive C: 19812.63 mb - Converting Pictures from ES to PS -------------------------------------------------------- Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini Executing RunbbMPEG. Commandline: "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\TitlePicture.bmp.mpg" -------------------------------------------------------- - 02/02/2003 2:55:35 AM - Free on drive C: 19812.59 mb - Converting Pictures from ES to PS -------------------------------------------------------- Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini Executing RunbbMPEG. Commandline: "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg" -------------------------------------------------------- - 02/02/2003 2:55:42 AM - Free on drive C: 19812.55 mb - Converting Pictures from ES to PS -------------------------------------------------------- Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini Executing RunbbMPEG. Commandline: "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\LastCDPicture.bmp.mpg" -------------------------------------------------------- - 02/02/2003 2:55:49 AM - Free on drive C: 19812.52 mb - Multiplexing and cutting -------------------------------------------------------- Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini Offset in Seconds: 0 Executing bbMPEG. Variable Settings: Movie offset: 0 seconds Cut point: 795 mb Executing RunbbMPEG. Commandline: "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg" Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg 3016 Seconds Offset in Seconds: 3016 Executing bbMPEG. Variable Settings: Movie offset: 0 seconds Cut point: 795 mb Executing RunbbMPEG. Commandline: "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg" Multiplexing and cutting finished. -------------------------------------------------------- - 02/02/2003 3:04:37 AM - Free on drive C: 18225.00 mb - Determining length of audio -------------------------------------------------------- Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg 3046.478 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg 3187.252 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg Analyzing finished. -------------------------------------------------------- - 02/02/2003 3:05:31 AM - Free on drive C: 18225.00 mb - Creating CD-Images using VCDXBuild -------------------------------------------------------- - No. of chapters to create: 19 CD image #1: CD_Image_File_CD1.bin Executing VCDXBuild. Commandline: "C:\PROGRA~1\DVD2SVCD\D2SCCD\d2sccd.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1.cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1.bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~1.XML" -------------------------------------------------------- - 02/02/2003 3:10:12 AM - Free on drive C: 17264.61 mb - Creating CD-Images using VCDXBuild -------------------------------------------------------- - No. of chapters to create: 16 CD image #2: CD_Image_File_CD2.bin Executing VCDXBuild. Commandline: "C:\PROGRA~1\DVD2SVCD\D2SCCD\d2sccd.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2.cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2.bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~2.XML" CD-Image creation finished. -------------------------------------------------------- - 02/02/2003 3:14:29 AM - Free on drive C: 16928.24 mb - SVCD Creation finished! -------------------------------------------------------- Hopefully you have some anwers for me you guys always seem to be helpful, and many of us appreciate all your hard work. Thanks again NateDawg11 |
#11 | Link | |
Also, when one goes to encode the movie, should the "aspect ratio" setting be set to "4:3 [No borders, encoded as 4:3]" even if the movie is 16:9? I don't remeber D2SVCD defaulting to that setting before, but now it does everytime with the AutoFitCD plugin. Or should I still leave it as "16:9 [Borders Added, Encoded as 4:3" if it is a 16:9 movie? BTW, thanks for the great tools/plugins man! Last edited by Forseti; 2nd February 2003 at 14:33. |
#12 | Link |
@Forseti:
It should appear in the preview screen, left from the Sho DVD2SVCD button. Make sure to use the latest version of the plugin. greets, winxi
#13 | Link | |
You can edit DVD2SVCD.INI and change as follow
For the aspect ratio you have to choose the right aspect ratio, if your movie is 16/9 choose 16/9 border added encode as 4/3, if your movie is 4/3 choose 4/3 no borders encoded as 4/3. HTH |
#14 | Link |
Hmmm, that was really weird. I went and checked my DVD2SVCD.ini file, and i was mising quite a few lines in it (under the autofitCD area). I just uninstalled DVD2SVCD and deleted the plugins. Then did a reinstall of both, and it works fine now, and the "threshold" box is now there.
#15 | Link | |
Retired
@NateDawg11:
Can you please post the first .XML file? @Forseti: Quote:
@emilius256: Please don't edit the [AVISYNTH_AutoFitCD Detect Borders] section! With the latest version of the Plugin, you can modify the borders threshold in the preview window. |
#17 | Link | |
#18 | Link |
[QUOTE]Originally posted by RB
[B]@NateDawg11: Can you please post the first .XML file? @Forseti: Okay Here it is I have to cut it in half and paste it into 2 post it is too many characters to fit into a single post. <?xml version="1.0" ?> <!DOCTYPE videocd (View Source for full doctype...)> - <!-- SVCD created with DVD2SVCD ver. 1.1.1 build 2 --> - <!-- Download DVD2SVCD: http://dvd2svcd.doom9.net --> - <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="svcd" version="1.0"> <option name="svcd vcd30 mpegav" value="false" /> <option name="svcd vcd30 entrysvd" value="false" /> <option name="relaxed aps" value="false" /> <option name="update scan offsets" value="false" /> - <info> <album-id>ANALYZE_THIS</album-id> <volume-count>2</volume-count> <volume-number>1</volume-number> <restriction>0</restriction> </info> - <pvd> <volume-id>ANALYZE_THIS</volume-id> <system-id>CD-RTOS CD-BRIDGE</system-id> <preparer-id>HughFroggers Release</preparer-id> </pvd> - <filesystem> - <folder> <name>EXTRA</name> - <file src="C:\PROGRA~1\DVD2SVCD\Movie\VCDXBuild_Script_1.xml" format="form1"> <name>DVD2SVCD.XML</name> </file> - <file src="C:\PROGRA~1\DVD2SVCD\Movie\SVCDInfo.txt" format="form1"> <name>SVCDINFO.TXT</name> </file> </folder> </filesystem> - <segment-items> <segment-item src="C:\PROGRA~1\DVD2SVCD\Movie\TITLEP~1.MPG" id="segment-titlepicture" /> <segment-item src="C:\PROGRA~1\DVD2SVCD\Movie\CHANGE~1.MPG" id="segment-changecd" /> </segment-items> - <sequence-items> - <sequence-item src="C:\PROGRA~1\DVD2SVCD\Movie\BBMPEG~1.MPG" id="sequence-00"> <entry id="entry-chapt-01">0.000</entry> <entry id="entry-chapt-02">221.050</entry> <entry id="entry-chapt-03">330.160</entry> <entry id="entry-chapt-04">456.280</entry> <entry id="entry-chapt-05">520.350</entry> <entry id="entry-chapt-06">648.640</entry> <entry id="entry-chapt-07">756.120</entry> <entry id="entry-chapt-08">988.980</entry> <entry id="entry-chapt-09">1379.870</entry> <entry id="entry-chapt-10">1475.470</entry> <entry id="entry-chapt-11">1637.300</entry> <entry id="entry-chapt-12">2016.550</entry> <entry id="entry-chapt-13">2103.600</entry> <entry id="entry-chapt-14">2209.370</entry> <entry id="entry-chapt-15">2390.380</entry> <entry id="entry-chapt-16">2538.570</entry> <entry id="entry-chapt-17">2623.830</entry> <entry id="entry-chapt-18">2866.690</entry> <entry id="entry-chapt-19">3008.840</entry> </sequence-item> </sequence-items> - <pbc> - <!-- chapter-00 is the titlepicture --> - <selection id="chapter-00" rejected="false"> <bsn>1</bsn> <next ref="chapter-01" /> <return ref="end" /> <timeout ref="chapter-01" /> <wait>5</wait> <loop jump-timing="immediate">1</loop> <play-item ref="segment-titlepicture" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-01" rejected="false"> <bsn>1</bsn> <prev ref="chapter-00" /> <next ref="chapter-02" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="sequence-00" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-02" rejected="false"> <bsn>1</bsn> <prev ref="chapter-01" /> <next ref="chapter-03" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-02" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-03" rejected="false"> <bsn>1</bsn> <prev ref="chapter-02" /> <next ref="chapter-04" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-03" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-04" rejected="false"> <bsn>1</bsn> <prev ref="chapter-03" /> <next ref="chapter-05" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-04" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-05" rejected="false"> <bsn>1</bsn> <prev ref="chapter-04" /> <next ref="chapter-06" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-05" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-06" rejected="false"> <bsn>1</bsn> <prev ref="chapter-05" /> <next ref="chapter-07" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-06" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-07" rejected="false"> <bsn>1</bsn> <prev ref="chapter-06" /> <next ref="chapter-08" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-07" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-08" rejected="false"> <bsn>1</bsn> <prev ref="chapter-07" /> <next ref="chapter-09" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-08" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-09" rejected="false"> <bsn>1</bsn> <prev ref="chapter-08" /> <next ref="chapter-10" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-09" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-10" rejected="false"> <bsn>1</bsn> <prev ref="chapter-09" /> <next ref="chapter-11" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-10" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> |
#19 | Link |
[B]@NateDawg11: Can you please post the first .XML file? @Forseti: 2nd half of xml </selection> - <selection id="chapter-11" rejected="false"> <bsn>1</bsn> <prev ref="chapter-10" /> <next ref="chapter-12" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-11" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-12" rejected="false"> <bsn>1</bsn> <prev ref="chapter-11" /> <next ref="chapter-13" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-12" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-13" rejected="false"> <bsn>1</bsn> <prev ref="chapter-12" /> <next ref="chapter-14" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-13" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-14" rejected="false"> <bsn>1</bsn> <prev ref="chapter-13" /> <next ref="chapter-15" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-14" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-15" rejected="false"> <bsn>1</bsn> <prev ref="chapter-14" /> <next ref="chapter-16" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-15" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-16" rejected="false"> <bsn>1</bsn> <prev ref="chapter-15" /> <next ref="chapter-17" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-16" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-17" rejected="false"> <bsn>1</bsn> <prev ref="chapter-16" /> <next ref="chapter-18" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-17" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-18" rejected="false"> <bsn>1</bsn> <prev ref="chapter-17" /> <next ref="chapter-19" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-18" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="chapter-19" rejected="false"> <bsn>1</bsn> <prev ref="chapter-18" /> <next ref="ChangeCD" /> <return ref="end" /> <timeout ref="ChangeCD" /> <wait>0</wait> <loop jump-timing="immediate">1</loop> <play-item ref="entry-chapt-19" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> - <selection id="ChangeCD" rejected="false"> <bsn>1</bsn> <prev ref="chapter-19" /> <next ref="chapter-00" /> <return ref="end" /> <wait>-1</wait> <loop jump-timing="immediate">1</loop> <play-item ref="segment-changecd" /> <select ref="chapter-01" /> <select ref="chapter-02" /> <select ref="chapter-03" /> <select ref="chapter-04" /> <select ref="chapter-05" /> <select ref="chapter-06" /> <select ref="chapter-07" /> <select ref="chapter-08" /> <select ref="chapter-09" /> <select ref="chapter-10" /> <select ref="chapter-11" /> <select ref="chapter-12" /> <select ref="chapter-13" /> <select ref="chapter-14" /> <select ref="chapter-15" /> <select ref="chapter-16" /> <select ref="chapter-17" /> <select ref="chapter-18" /> <select ref="chapter-19" /> </selection> <endlist id="end" rejected="true" /> </pbc> </videocd> Thanks again |
#20 | Link |
RB, first of all, thank you very much for the plugin. I have read countless number of your posts. And since this is the first time I have posted directly to you, I will take the time to thank you personally for your great work around here!! People like you are the reason this Forum is so popular, Real People, with real knowledge, that are friendly enough to answer people who don't know any better.
Now on to the question, LOL! I am an AVI2SVCD user. I have only done a couple of DVD encodes, usually just for test purposes. I have done hundreds of AVI2SVCD encodes Using D2S. I have developed my own technique, which first of all uses D2S as a front-end for AVIsynth. I then modify the AVS, to use in VDUB. Creating a Quantizer2 DIVX 5/WAV(AC3) file, that is already resized and filtered accordingly. I then feed the "Prepped" AVI file into D2S. I use the following script... [AVISYNTH_BLANK] This gives me speeds usually in excess of 2.0. Allowing a 6 pass, 2 hour movie to encode in 6 hours (Dual MP1600s). A final perfection to this Method, would be to crop the black bars from the prepped file, encode, and then add the black bars back. The problem with this is that when I use your script, it resizes the file. Is there a way to make it just cut the black borders and not resize? |
| Thread Tools | |
| Display Modes | |
