#1 | Link |
AviSynth Developer
![]() Join Date: Nov 2001
Official AviSynth 2.5.0 beta
After a long testing and debugging period, we are now ready to present the AviSynth 2.5.0 beta. A big thanks to everyone here - the testers - the patient developers - and those spreading the word of AviSynth!
We have some great features under the hood of the new AviSynth that hopefully will be able to bring non-linear video editing to a new level! (ok - enough with the rants). The summed up changes: * Native planar YV12 support. * Multiple audiochannels. Unlimited number of channels is now supported. * Float samples support. AviSynth is now capable of processing samples as floats. * Automatic sample conversion. If some filters doesn't support a specific sample type, they are converted to the format preserving most quality. * Optimizations. Many basic features has been optimized, and now performs much better than previous versions. * Temporalsoften has a significant speed improvement, scenechange detection and a new improved blend mode. * Limiter can limit the YUV ranges, to avoid invalid color values and improve compression. * ColorYUV makes it possible to do very exact color corrections. ColorYUV has built-in auto-whitebalance and auto-gain features. * Select separate planes using UToY, VToY and merge them together again, using YToUV. * Fliphorizontal. implemented. * SelectRangeEvery is now part of the core functions. * Blur, Sharpen, Resize optimized. * Fast XviD colorspace conversions. * Updated installer. * AviSynth icons. * See clip info using the info() command. ... and many more internal changes! A rather complete changelog can be found here. ... but we are still in Beta so here are some of the issues we are still dealing with: Known issues are: - Stackvertical can give strange results at some resolutions. Use resolutions that are multiples of 16. - Temporalsoften can still act strange in rare cases. Try moving it to a different location in the filter chain. - Some filters, in a certain order may produce problems. Try moving your filters around, or look for updates. As usual the package can be downloaded from SourceForge. Use the Minneapolis mirror, not all mirrors are updated! Since all filters have to be updated, there has been collected a package of some of the basic plugins used for AviSynth. This can also be downloaded from the URL above. Test away - and report any problem here or at SourceForge! Last edited by sh0dan; 29th January 2003 at 11:37. |
#2 | Link |
Simply me
Yippee
![]() [Edit} I just ran the installer (changed default dir to something else) and it gives the correct info when using Version() Time to play now - thanks to everyone whoes worked on it regards Simon
http://www.geocities.com/siwalters_uk/fnews.html Last edited by Si; 28th January 2003 at 23:27. |
#3 | Link |
Achtung Baby
YV12 support.....excellent.
Very gratefull Edge
http://www.cellular-news.com/images/...il_Ireland.gif |
#13 | Link |
Remember Rule One
WTG sh0dan!
And let's not forget to say thank you to all the other people who have helped out on creating this excellent project. RichardBerg, MarcFD, siwalters, neuron2, vlad59, wilbert, and everybody else that has in any way been involved, making core changes, new plugins and so on. THANK YOU! |
#14 | Link | |
AviSynth Developer
@All: Thanks for the kind words! Now let's get the last problems squished! |
#15 | Link | |
developer wannabe
#17 | Link |
AviSynth Developer
Most other sources - MPEG2, MJPEG, MPEG4 are all in YV12. Most destination formats MPEG1, MPEG2, MPEG4 are YV12 based (though not all encoders handle YV12 that well) That's what the fuss is about.
#18 | Link |
miau
As an avisynth user I also want to thank everyone who is envolved at this breakthrough project!
"... but where are those missing pieces of eternal soul, I can feel them but I can't reach them with my vision" Petition for a software patent free Europe Another vision of what happened at 9/11
#19 | Link |
Unregistered User
how can I use it with GKnot?
when I installed avisynth 2.5 I cannot anymore open .avs file generated from Gknot error: mpeg2dec.dll is not an avisynth plugin? with 2.07 there was not such a problem
my subtitle site |
#20 | Link |
miau
I think you have to use mpeg2dec3.dll.
| Thread Tools | |
| Display Modes | |
