Old 28th January 2003, 22:44   #1  |  Link
FuPP
TotalEclipseOfTheBrain
FuPP's Avatar
Noise filters comparative
I've done a few tests in order to evaluate different noise filter. I have chosen to compare only the ones I consider the more efficient for that purpose (ie removing noise on heavily noised sources, keeping fair amount of detail and delivering fine grain).
Anyway, I did not have time to compare all filters available around here
Candidates are therefore : PixieDust, FaeryDust, Peachsmoother and A3d (from Deen).
The source is a live performance probably filmed with digital cameras : because of filming conditions (darkness), one can see heavy noise on pictures
I have initially used a "calibration frame", enabling me to adjust filters parameters in order to lose details as few as possible. This frame represents a slightly bearded face : when filters are too strong, the beard becomes blured (I have actually observed some other details on the face to calibrate filters).
Here are attached pictures : a part of the one I used for calibation (ATEST), another part of the same picture showing noise ("green picture" = BTEST), and a last one showing lights halos with a lot of noise (CTEST).
Script used :
LoadPlugin("C:\video\avsfilters\MPEG2Dec3.dll")
LoadPlugin("C:\video\avsfilters\<NOISE FILTER>.dll")
mpeg2source("F:\test\vts_03_1.d2v",cpu=0,idct=2)
Crop(8,8,704,560)
<NOISE FILTER>
BicubicResize(448,320,0,0.5)
AddBorders(16,128,16,128)
Settings
Faery : Faerydust(limit=4)
Pixie : Pixiedust(limit=3)
Peach : PeachSmoother(NoiseReduction=45,Stability=15,Spatial=70,NoiseLevel=4.8,Baseline=3.2)
deen : deen("a3d",4,6,8,9)
my observations :
The green picture shows that all filters are efficient, but peach and a3d do the job better
The "halos" picture shows that once more all filters are good, but it seems to me that a3d has thiner and more natural grain.
About compressibility gain :
Normal (no filter) : 100 %
faery : 89.9%
pixie : 88.6%
Peach : 88,4%
a3d : 89.1%
my conclusion
Peach is still the best compromise between efficiency, speed (Pixie, Faery and a3d are terribly slow) and compressibility.
I though prefer a3d grain, which looks better and more natural for me than other filters.
But do not forget Xdust thingies are on early development, and have place for improvement !
Be aware that these results have to be taken for what they are : a specific observation in a specific context : you have to test on different sources and make your own opinion.
A last thing : Peach, Faery and Pixie are avisynth 2.07 filters, a3d is a 2.5 filter. That's the reason why I did not try to directly compare speeds.
Hope it is relevant and usefull
FuPP.
FuPP is offline   Reply With Quote
Old 16th March 2003, 03:06   #2  |  Link
digitalman
I tried PeachSmoother with the settings recommended here, and to me the results were equal to FaeryDust. Plus, the speed of PeachSmoother is a lot faster than FaeryDust. Thanks FuPP for posting your test.
digitalman is offline   Reply With Quote
Old 16th March 2003, 11:40   #3  |  Link
FuPP
FuPP's Avatar
My pleasure
Be aware though that these settings were used in a particular situation, and are therefore not 'universal'.
Regards,
FuPP.
Old 16th March 2003, 15:12   #4  |  Link
jorel
Posts: n/a
hi FuPP
i never used cos don't know A3d filter,
but in your "pictures" the results are fantastics!
please,in what version of avisynth the A3d filter works ?
thanks in advance!
editing:
i post this thread in another forum cos
see that FuPP tests will be apreciated!
http://kvcd.net/forum/viewtopic.php?...658dc70a6ca3e6
great work FuPP!
Old 16th March 2003, 16:38   #5  |  Link
FuPP
FuPP's Avatar
hi
works with 2.5x
Can be found here '(choose Deen)' : http://ziquash.chez.tiscali.fr/index.html
Cheers,
FuPP.
Old 16th March 2003, 21:20   #6  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Too bad Lindsey's gone missing, I would have liked to see PeachSmoother for AVS2.5 so that I could test it myself with some analog TV captures - so much Star Trek to encode
Old 16th March 2003, 23:00   #7  |  Link
FuPP
FuPP's Avatar
"I would have liked to see PeachSmoother for AVS2.5"
So do I... (or a similar Lindsey's thingy). HSD, if you read us...
Old 17th March 2003, 09:19   #8  |  Link
High Speed Dubb
Yeah, where is that guy, anyhow?
I’ve been pretty busy. In any case, Peach Smoother will still need to run in YUY2, even after it has been converted.
FuPP — About that comparison — Were the scenes you looked at in motion? The amount of motion is really important when evaluating the filtering.
9:) Lindsey Dubb
High Speed Dubb is offline   Reply With Quote
Old 17th March 2003, 09:31   #9  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Good to see you around!
Personally I don't care if it wants YUY2 because I do my TV captures in YUY2 I hope you find the time to do the port..
Old 18th March 2003, 21:40   #10  |  Link
FuPP
FuPP's Avatar
Hi Lindsey
You are right, my very first post was not clear about the way I used PeachSmoother; in fact I have used different kind of scenes (including motion) for calibrating Noiselevel and Baseline. I simply used the static picture for adjusting Noise Reduction level.
In any case, Peach Smoother will still need to run in YUY2 even after it has been converted
Would be great anyway... till your next fruity denoiser
Cheers,
FuPP.
Old 19th March 2003, 07:02   #11  |  Link
JuanC
Originally posted by FuPP
Hi Lindsey
I couldn't agree more. I haven't been as systematic comparing filters as Fupp, but after some tests, PeachSmoother has always been my first choice for reducing noise on my captures. It is really great and fast! If I had the chance to use it with AVS 2.5x, I would stop using AVS 2.0.x once and for all.
Thanks HSD!
JuanC is offline   Reply With Quote
Old 19th March 2003, 15:14   #12  |  Link
jamesp
If the programmer of Peach has any time to look at anything, a bug has been noticed in Peachsmoother where some objects remain stationary when they should be moving very slightly. The thread with the bug is
http://www.kvcd.net/forum/viewtopic.php?t=3136&start=15
I've noticed the bug myself. Its a shame because other than this Peachsmoother is the nuts!
Jim
jamesp is offline   Reply With Quote
Old 19th March 2003, 15:35   #13  |  Link
Wilbert
In case you didn't know that, it is possible to use peach in AviSynth v2.5 as long as you stay in YUY2. See Q&A: Q1.something.
Old 20th March 2003, 01:33   #14  |  Link
Shayne
Shayne's Avatar
I think you need to also include the die hard dynamic noise reducer. Tweaked brightness thresholds wirth low color settings can do wonders.
http://members.tripod.co.jp/kiraru2002/#dnr2
converted readme
DNR2 - Dynamic Noise Reduction 2 (YUY2/RGB32/YV12 (CS_YV12, CS_I420))
Download DNR2 v0.7 (included Source files)
VirtualDub plugin - dynamic noise reduction (transplantation edition of MMX) by Steven Don and Avery Lee
DNR2 (threshY_hi, threshY_lo, threshU_hi, threshU_lo, threshV_hi, threshV_lo and type)
ThreshY_hi Brightness of the pixel of the frame data where one ago was accumulated (Y) threshold value 1
[ Default = 8 ]
ThreshY_lo Brightness of the pixel of the frame data where one ago was accumulated (Y) threshold value 2
[ Default = threshY_hi / 2 + 1 ]
ThreshU_hi Color difference information U of the pixel of the frame data where one ago was accumulated (the Cb) threshold value 1
[ Default = threshY_hi * 3 / 4 (YUY2/YV12): ThreshY_hi (RGB) ]
ThreshU_lo Color difference information U of the pixel of the frame data where one ago was accumulated (the Cb) threshold value 2
[ Default = threshU_hi / 2 + 1 ]
ThreshV_hi Color difference information V of the pixel of the frame data where one ago was accumulated (the Cr) threshold value 1
ThreshV_lo Color difference information V of the pixel of the frame data where one ago was accumulated (the Cr) threshold value 2
[ Default = threshV_hi / 2 + 1 ]
Type " DNR2 " (or "") [ default ] OR " DNR1 "
In the CPU which supports MMX MMX is used.
Recommendation value 7 of threshold_hi - 12
Furthermore, in case of the RGB32, it corresponds to the respective Y:U:V = R:G:B.
Processing summary
Each point of the present frame and the point of the same position of the DNR processing end frame of one ago are compared,
It increases levels. Whether or not the difference within threshold with processing differs.
Case1: Type= " " OR " dnr2 " (default)
Presently the pixel = current of the frame, it makes the pixel = previous of the frame of one ago when
If |current - previous|
If |current - previous| > threshold_lo
Then new = (2 * current + previous) / 3 //current values to approach
Else new = (current + 3 * previous) / 4 //previous values to approach
Else new = current
Case2: Type= " dnr1 "
Else new = previous
Else new = current
As for the DNR1 of the type and the difference of the DNR2, the DNR2 is high picture quality, but it does not become help of MPEG compression,
It becomes help of the high pressure reduction in regard to the point, the DNR1 MPEG compression.
Sample
DNR2(8,4,6,3,6,3,"dnr1")
Shayne is offline   Reply With Quote
Old 21st March 2003, 03:21   #15  |  Link
JuanC
Q1.23!! Very interesting. It works!!!
But unfortunately VDMod Crashes every time you quit. AppVer: 1.4.13.2; ModName: Unknown; offset: 059858c0
I'm using:
VDMod 1.4.13.1 with latest Bugfix (2003-01-31)
AVS 2.51 latest CVS snapshot (2003-03-20)
Latest LoadPluginEx from warpsharp package (2003-01-21)
DivX 5.0.3
VDMod will always crash on exit every time you use the LoadPlugin sentence in the AVS script (using the LoadPluginEx.dll), not just when putting it in the Autoload Plugin directory) and you don't even need to use the "loaded" plugin (i.e. peach) to make it happen.
Old 24th March 2003, 06:00   #16  |  Link
High Speed Dubb
Jim wrote
If the programmer of Peach has any time to look at anything, a bug has been noticed in Peachsmoother where some objects remain stationary when they should be moving very slightly...
You’re seeing the standard behavior where the Peach is really, really sure that there’s no motion. Usually that means the noise estimate is off — Take a look at the docs on the “dot” option and on the “I’m seeing lots of blurring...” question.
9:) Lindsey Dubb
Old 24th March 2003, 10:18   #17  |  Link
Wilbert
I got the same problem. Dunno whether the problem is AviSynth or this plugin. The problem is that this japanese guy doesn't read this forum ?
Old 23rd July 2003, 06:28   #18  |  Link
FredThompson
FredThompson's Avatar
I've got similar crashing with Simon Walters' BorderControl filter. Loading it is enough. It doesn't have to be executed. Happens with AviSynth 2.5.2 latest CVS
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 23rd July 2003, 07:31   #19  |  Link
JuanC
I haven't had any problems since I moved the "LoadPluginEx.dll", and any plugin included in the WarpSharp package, away from the AviSynth autoload plugin directory (\Program Files\AviSynth 2.5\plugins).
If you use LoadPluginEx and your issues are related to it, take a look at the thread started by Richard Berg on a smart workaround to this problem.
Hope that helps, :J
P.S. You could also take a look at the following threads to see what kind of problems you could have by leaving the LoadPluginEx at the autoload plugin directory:
http://forum.doom9.org/showthread.php?s=&threadid=49384
http://forum.doom9.org/showthread.ph...adplugin+juanc
EDIT: Also, you should be aware that after you Load the "loadPlugInEx" you can only load AviSynth 1.x/2.0.x plugIns...
Old 23rd July 2003, 07:39   #20  |  Link
FredThompson
I'm sorry, I should have been more explicit. The crashing I'm seeing has nothing to do with loadpluginex. In fact, while it's crashing, the comment really doesn't belong in this thread.
