Old 22nd January 2003, 19:39   #1  |  Link
toolman2k
ripping speed from 10x to 2x....
hi all,
i have done lots of ripping with decrypter.it worked fast usually like 10/12 speed.which is very nice.but lately is dropped to about max 2x.....i tried ripping on other installation (on same hardware) and it was fast.so idecided to re-install my system which i did today.
well its faster now, but max of 4x, not even near what i used to have.
anybody an idea ? this is weird.i have nothing running and checked processes.which are the same as the other xp install i have.......well antivirus is there and MSN, but even with those disabled it still goes sloooww.....what to do ?? please help me out.
toolman2k is offline   Reply With Quote
Old 23rd January 2003, 15:08   #2  |  Link
killingspree
Newbie Forum Mod
killingspree's Avatar
just answered this question 2 minutes ago, don't want to write it again!
so pls read here:
http://forum.doom9.org/showthread.php?s=&threadid=43748
regards
steVe
Search the forum, read the forum rules once more and use the search function on doom9.org before posting!
oh btw my amazon.de wishlist
killingspree is offline   Reply With Quote
Old 23rd January 2003, 18:26   #3  |  Link
toolman2k
so pls read here:
regards
steVe
thanks alot! i already read that post...but then your answer wasnt there yet...but do i have to remove the controller itself, just the primary+secondary channels or both ?
thanks.
Old 23rd January 2003, 19:09   #4  |  Link
killingspree
Newbie Forum Mod
no just uninstall it in the device manager. just be sure you uninstall the whole IDE bus controller (either primary or secondary) and not the drives themselves, as this would be of no use!
regards
steVe
Old 23rd January 2003, 23:26   #5  |  Link
toolman2k
regards
steVe
well i did what u told me.....but still it doesnt rip fast....i deleted the whole channel and let it reinstall again. but it still rips at 3x, while i can rip easily at7/8x at my other xp installation...i dont get it.
Old 24th January 2003, 13:45   #6  |  Link
killingspree
Newbie Forum Mod
well
if you are ripping above 2x as you said, there is another problem, since PIO mode will not allow anything faster than 2 or 2.1x speeds.
have you tried other rippers?
regards
steVe
Old 24th January 2003, 13:49   #7  |  Link
N_F
Do you find me... pretty?
N_F's Avatar
Have you experienced this with just one DVD or several? It's been my experience some DVD's will rip really slow no matter how fast your DVD-player is.
N_F is offline   Reply With Quote
Old 24th January 2003, 15:06   #8  |  Link
toolman2k
it is with the matrix dvd.....which rips at 8-10x normally...but now only 3x....
Old 10th February 2003, 07:21   #9  |  Link
BrandonClaps
it is the actual dvd player......
BrandonClaps is offline   Reply With Quote
Old 12th February 2003, 02:36   #10  |  Link
jhughe90
You do NOT need to reinstall the entire IDE channel drivers.
The flag for the PIO/DMA is contained in this registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}
Choose 001 or 002 depending on if it's on the Primary or Secondary channel. Delete the MasterIdDataCheckSum and SlaveIdDataCheckSum registry values. Actually it doesn't matter which or where, as long as you delete one of them. Upon the next reboot XP will reinitialize the DMA settings and you should be back to normal.
If someone can find out the correct values for these keys at DMA you could probably even avoid the reboot. Or just write them down and when it resets just change the value back.
Jeff
jhughe90 is offline   Reply With Quote
Old 13th February 2003, 11:26   #11  |  Link
la_Nce01
because I was bored yesterday I wrote a little tool that will gather
the 'normal' DMA checksums and then write them into registry in a configurable interval (e.g. 10 mins). I don't know if this keeps Windows from switching to PIO mode, but we will see.
Wishes and comments appreciated,
la_Nce
Get it here
Sorry for my bad english!
la_Nce01 is offline   Reply With Quote
Old 18th February 2003, 18:04   #12  |  Link
moose69
I to have this problem. No matter what dvd I try to rip I keep getting 1.8X speeds on my A04 burner and I have a Hitachi GD-8000 DVDRom Drive that stays around 1X. I am on windows 2000 pro so I am assuming that the I getting these problems for the same reasons. Is this true?
SIGNATURE
moose69 is offline   Reply With Quote
Old 18th February 2003, 18:47   #13  |  Link
killingspree
Newbie Forum Mod
well i never had these speed problems in win2k, but it's quite a while (almost a year since i've last used win2k)
anyway dvd burners are known to be way slower, but with your normal dvd drive you should get way faster speeds (at least 4-5x i guess)
@la_nce: how does it gather the checksums?
regards
steVe
Old 18th February 2003, 21:37   #14  |  Link
la_Nce01
It's very simple, it deletes all the reg keys, reboots and extracts them rigth after the reboot...
Old 18th February 2003, 22:21   #15  |  Link
killingspree
Newbie Forum Mod
ok but where does it take the values from it extracts before the reboot? maybe this should be blatantely obvious, but i just don't seem to get it
anyway, thanks for the tool, i'm gonna try it tomorrow!
regards
steVe
Old 18th February 2003, 22:55   #16  |  Link
la_Nce01
Choose 001 or 002 depending on if it's on the Primary or Secondary channel...
Old 19th February 2003, 18:35   #17  |  Link
killingspree
Newbie Forum Mod
ok, i've tried the tool and it works perfectly :-P thanks again - and sorry for my stupid questions :-)
regards
steVe
Old 22nd February 2003, 08:12   #18  |  Link
Arc
I've tried what jhughe90 said but it doesn't help.
I have a Pioneer 104 drive. Does anyone else have one of these drives that can read over 2.1x?
Arc is offline   Reply With Quote
Old 22nd February 2003, 12:52   #19  |  Link
killingspree
Newbie Forum Mod
hav you tried la_NCe01s tool? it's attached a few messages above...
regards
steVe
Old 23rd February 2003, 05:23   #20  |  Link
Arc
Yes, I tried la_NCe01s tool but it didn't help either.
