Old 20th January 2003, 23:03   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Blue Crush (2-DVD Split Movie) Cheat Sheet
Courtesy of 2CL
“You see all that water…all that water crashes into one little island…called Hawaii.” quote from the girls commentaries while viewing the Universal world intro.
FINAL PRODUCT DESCRIPTON:
Disk 1:
Chapters 1 – 16 only
Original menu kept
No French and Spanish audio
No Bonus Materials except commentaries
Disk 2:
Chapters 17 – 20 only
Original menu kept
Bonus Materials
Tools I used:
For ripping movie to harddrive: Smartripper 2.41
For editing the DVD navigations: IfoEdit 0.95
For burning the final product: Imgtools 0.95 with Nero 5.5.9.17 API
For editing button commands: VOBedit 0.6
1. Create a folder named “Blue Crush” and three sub-folder named “Files”,”Disk 1”, “Disk 2”.
2. Rip all files to “Blue Crush” folder.
3. Region Free every IFO and save.
4. Get VTS Sectors.
5. Backup all IFOs to your “Files” subfolder. If you need to copy your original IFO over your badly edited one, get VTS Sector afterwards.
6. In VIDEO_TS.IFO/First Play PGC/PGC Command Table and edit.
OLD > 11.Pre Command (JumpSS VMGM) Jump to VMG PGC: 11 [30 06 00 0b 00 c0 00 00 ]
NEW > 11.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 1, Title(ttn): 1, root-menu [30 06 00 01 01 83 00 00 ]
Translation: No FBI warnings to show.
Details: A Jump to VMG PGC 1 would also do as it contains a jump to root menu.
7. In VIDEO_TS.IFO/VMGM_PGCI_UT/PGC-Menu_14/PGC Command Table, edit
OLD > 1.Pre Command (JumpTT) Jump to Title: 18 [30 02 00 00 00 12 00 00 ]
NEW > 1.Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
Translation: Bypass trailers before movie start.
8. In VIDEO_TS.IFO/VMGM_PGCI_UT/PGC-Menu_5/PGC Command Table, edit
OLD > 1.Pre Command (JumpTT) Jump to Title: 19 [30 02 00 00 00 13 00 00 ]
NEW > 1.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 1, Title(ttn): 1, root-menu [30 06 00 01 01 83 00 00 ]
Translation: Bypass logos at end of movie.
9. Save VIDEO_TS.IFO
10. Get VTS Sectors
SPLITTING
11. Select VTS_01_0.IFO
12. Press VOB Extras
13. We are going to split our DVD and at the same time, strip out French and Spanish audio streams out.
These need to be checked.
- Strip Stream’s
- Correct Vob-Unit (Navigation Pack) pointers in VOB-files
- Correct original IFO files
- Split to 2 DVD-Rs
- Remove P-Uops
- Remove Macrovision
- Remove Ilvu/Angle point.
- Adjust Vob-Unit pointers.
- Adjust Audio/Subp point.
- AutoCopy Menu-files to destination
14. Select Destination directory to your “Disk 1” sub-folder and 2nd Dest. Directory to “Disk 2”
15. Press Ok.
16. Select Ch 17, cell 18 as our new split point.
17. Make sure the “Correct IFO tables” is checked and press split it.
18. In your Stream List, check everything except French [audio 2] and Spanish [audio 3]
19. Make sure the “Correct IFO tables” is checked and press split it. Wait, it’s going to take awhile.
20. When done, copy VIDEO_TS.VOB, VTS_01_0.VOB to Disk 1 and Disk 2 sub-folders.
21. Drag VTS_02_* to VTS_10_* files to Disk 2 subfolders. These are your Bonus Materials VOBs.
DISK ONE: Chapters 1 – 16
22. Select VTS_01_0.IFO in your Disk 1 sub-folder.
23. Get VTS Sectors
24. Backup all IFOs to “Files” subfolder, replacing previous files.
25. In VTS_01_0.IFO/VTSM_PGCI_UT/PGC-Menu_3/PGC Program Map, double-left click and edit
OLD > Program_5: Entry cell number 5 [05]
NEW > Program_5: Entry cell number 4 [04]
Translation: Chapters 17-20 are disabled in scene selection menu
26. In VTS_01_0.IFO/VTSM_PGCI_UT/PGC-Menu_5/PGC Command Table, edit
OLD > 1.Pre Command Set GPreg<0> mov GPreg<4> [61 00 00 00 00 04 00 00 ]
NEW > 1.Pre Command (LinkPGCN) Link PGC 24 [20 04 00 00 00 00 00 18 ]
Translation: Commentaries Menu will show only when Bonus Materials is selected.
27. In VTS_01_0.IFO/VTS_PGCITI, double-left click and edit following audio streams
OLD > [0000000e] Audio stream 2 status 33576 [8328]
NEW > [0000000e] Audio stream 2 status 32768 [8000]
OLD > [00000010] Audio stream 3 status 33792 [8400]
NEW > [00000010] Audio stream 3 status 32768 [8000]
OLD > [00000012] Audio stream 4 status 0 [0000]
NEW > [00000012] Audio stream 4 status 33576 [8328]
OLD > [00000014] Audio stream 5 status 0 [0000]
NEW > [00000014] Audio stream 5 status 33972 [84b4]
Translation: Commentaries buttons are corrected with right audio. Selecting French or Spanish buttons will only play English 5.1 now.
Details: When we stripped our French [audio 2] and Spanish audio[audio 3], Commentaries [audios 4 & 5] shifted up into their places. We had to correct them like our original IFO.
28. Save VTS_01_0.IFO
29. We need to correct our problem when we press our Bonus button in Commentaries menu. Originally, pressing that would go back to our Bonus Materials menu. We need it to go back to our main menu. So with VOBedit, open VTS_01_0.VOB in Disk 1 sub-folder.
30. Check Button at bottom
31. In LBA section, scroll down to 034229 [VOB: 13] [Cell:1] and highlight.
32. On right of VOBedit window, go to Button Navigational Commands/Button 3/command. Double-left click and edit.
OLD > (LinkPGCN) Link PGC 5 [20 04 00 00 00 00 00 05 ]
NEW > (LinkPGCN) Link PGC 1 [20 04 00 00 00 00 00 01 ]
Translation: Pressing Bonus button in Commentaries Menu will return you back to main menu.
33. Close VOBedit.
34. Go back to IFOedit and select VTS_01_0.IFO and Get VTS Sectors
35. Preview and test
36. That’s for Disk 1. See step 48 for my working burning instructions.
DISK TWO: Chapters 17 – 20
37. Select VTS_01_0.IFO in your Disk 2 sub-folder.
38. Get VTS Sectors
39. Backup all IFOs to “Files” subfolder, replacing previous files.
40. In VTS_01_0.IFO/VTSM_PGCI_UT/PGC-Menu_3/PGC Program Map, double-left click and edit
OLD > Program_1: Entry cell number 1 [01]
NEW > Program_1: Entry cell number 5 [05]
OLD > Program_2: Entry cell number 2 [02]
NEW > Program_2: Entry cell number 5 [05]
OLD > Program_3: Entry cell number 3 [03]
NEW > Program_3: Entry cell number 5 [05]
OLD > Program_4: Entry cell number 4 [04]
NEW > Program_4: Entry cell number 5 [05]
Translation: Chapters 1-16 are disabled in scene selection menu
41. Repeat step 27 to correct audio streams.
42. Save VTS_01_0.IFO
43. In VIDEO_TS.IFO/VMGM_MAT/First Play PGC/PGC Command Table, edit
OLD > 11.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 1, Title(ttn): 1, root-menu [30 06 00 01 01 83 00 00 ]
NEW > 11..Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
Translation: Disk 2 will start with movie upon insert.
44. Save VIDEO_TS.IFO
45. Get VTS Sectors
46. Preview and Test
47. That’s for Disk 2. Time to burn.
BURNING DISKS
48. For both disks, I used Imgtools 0.95 with reallocation unchecked successfully.
Note: With using Imgtools, I have Nero 5.5.9.17 installed on my computer.
2COOL
