Old 19th January 2003, 06:54   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Fight Club (2-DVD Split Movie) Cheat Sheet
Courtesy of 2CL.
Tools I used:
For ripping movie to harddrive: Smartripper 2.41
For editing the DVD navigations: IfoEdit 0.95
For burning the final product: Nero 5.5.9.17 DVD-Video
_____________________________________________________
1. Create a folder named “Fight Club” and three sub-folder named “Files”,”Disk 1”, “Disk 2”.
2. Rip all files except VIDEO_TS.* VTS_01_*, and VTS_02_* to “Fight Club” folder.
3. Region Free every IFO and save.
4. Get VTS Sectors.
5. Backup all IFOs to your “Files” subfolder. If you need to copy your original IFO over your badly edited one, get VTS Sector afterwards.
6. In VIDEO_TS.IFO / VMG Overview / Menu Language Unit [ ] section , delete playbacks on the VOB-Ids 4 to 8.
Translation: No FBI warnings to view.
7. In VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_16 / PGC Command Table, edit
OLD > 1.Pre Command (JumpTT) Jump to Title: 4 [30 02 00 00 00 04 00 00 ]
NEW > 1.Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
Translation: 20th Century Fox logo and THX sampler are bypassed before movie start.
8. Save VIDEO_TS.IFO
9. Get VTS Sectors
10. Time to split DVD. Select VTS_02_0.IFO and click on VOB Extras
11. These need to be checked.
  • - Correct Vob-Unit (Navigation Pack) pointers in VOB-files
    - Correct original IFO files
    - Split to 2 DVD-Rs
    - Remove P-Uops
    - Remove Macrovision
    - Remove Ilvu/Angle point.
    - Adjust Vob-Unit pointers.
    - Adjust Audio/Subp point.
    - AutoCopy Menu-files to destination
12. Select Destination directory to your “Disk 1” sub-folder and 2nd Dest. Directory to “Disk 2”
13. Press Ok.
14. Cell 30 is selected by IFOedit as a middle point to strip. Select Cell 29 as your new split point.
Let me tell the reason I do this. When I viewed my scene selection menus, the chapters are grouped to each page.
[1-6] [7-12] [13-18] [19-24] [25-30] [31-36]
Each chapter menu is a cell. We can disable cells. Look for the nearest chapter point from your original point. In this case, it was either chapter 18 or 24, according the chapter layout. The logical choice is chapter 18 since it is still within the central point. And chapter 18 is Cell 29. After the strip, Disk 1 will have chapters 1 – 18 and Disk 2 would have 19 – 36) .
15. Make sure the “Correct IFO tables” is checked and press split it. This is going to take awhile as this movie has 8 vobs.
16. When done, copy VIDEO_TS.*, VTS_01_*, and VTS_02_0.VOB to Disk 1 and Disk 2 sub-folders.
DISK ONE: Chapters 1 – 18
17. Select VTS_02_0.IFO in your Disk 1 sub-folder.
18. Get VTS Sectors
19. In VTS_02_0.IFO / VTSM_PGCI_UT / PGC-Menu_10 / PGC Command Table, edit
OLD > 1.Pre Command (SetHL_BTNN) Set Button Nr: (set-val) 28 [56 00 00 00 1c 00 00 00 ]
NEW > 1.Pre Command (LinkPGCN) Link PGC 9 [20 04 00 00 00 00 00 09 ]
Translation: Chapter selection for 19 – 24 is disabled.
20. Do the same for PGC-Menus 11 & 12.
21. Save VTS_02_0.IFO
22. In VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_17 / PGC Command Table, edit
OLD >1.Pre Command (JumpTT) Jump to Title: 5 [30 02 00 00 00 05 00 00 ]
NEW > 1.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, root-menu [30 06 00 01 02 83 00 00 ]
Translation: Bypass post movie logo and properly go to main menu immediately.
23. Save VIDEO_TS.IFO
24. Get VTS Sectors
25. Preview and test.
26. That’s for Disk 1. Burning procedures located after Disk 2 procedures.
DISK TWO: Chapters 19 – 36
27. Select VTS_02_0.IFO in your Disk 2 sub-folder.
28. Get VTS Sectors
29. In VTS_02_0.IFO / VTSM_PGCI_UT / PGC-Menu_5 / PGC Command Table, edit
NEW > 1.Pre Command (LinkPGCN) Link PGC 10 [20 04 00 00 00 00 00 0A ]
Translation: Chapter selection for 1 – 6 is disabled.
30. Do the same for PGC-Menus 8 & 9.
31. In VTS_02_0.IFO / VTS_PGCITI / VTS_PGC_1 / PGC Program Map, right-click and delete the following
Program_19: Entry cell number 31 [1f]
Translation: Prevents forward skip in Chapter 36 from going to main menu.
32. Save VTS_02_0.IFO
33. In VIDEO_TS.IFO / VMGM_MAT / First Play PGC / PGC Command Table, edit
OLD > 4.Pre Command (JumpSS VMGM) Jump to VMG PGC: 2 [30 06 00 02 00 c0 00 00 ]
OLD > 4.Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
Translation: When DVD is inserted, play the movie right away. Press root menu on remote to return to main menu.
34. In VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_17 / PGC Command Table, edit
35. Save VIDEO_TS.IFO
36. Get VTS Sectors
37. Preview and Test
38. That’s for Disk 2. Time to burn.
BURNING DISKS
For Disk 1 & 2, I used Imgtools 0.95 with reallocation unchecked successfully.
With using Imgtools, I have Nero 5.5.9.17 installed on my computer.
2COOL
Old 19th January 2003, 08:16   #2  |  Link
2COOL
2COOL's Avatar
If you want to bypass the movie intros then ...
..In VTS_02_0.IFO/VTS_PGCITIVTS_PGC_1/Cell Playback Section:, edit
OLD > Cell_1: entry point sector 0 [00000000]
NEW > Cell_1: entry point sector 14363 [0000381b]
Translation: Movie plays at actual starting point.
2CL
2COOL
