Old 13th January 2003, 03:48   #1  |  Link
MSharpen for Avisynth 2.5
Here is MSharpen compiled for Avisynth 2.5. It currently supports only RGB and YUY2.
Old 13th January 2003, 14:07   #2  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
*cough*
(Yes, I've caught a cold)
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 13th January 2003, 14:38   #3  |  Link
I'm such an idiot. Cough.
Old 13th January 2003, 14:39   #4  |  Link
wotef
wotef's Avatar
nice, nice
neuron2, do you have any plans to resume development of msmooth?
wotef is offline   Reply With Quote
Old 13th January 2003, 14:41   #5  |  Link
Yes, of course. The YV12 revolution sort of threw a kink in my plans.
Old 13th January 2003, 14:56   #6  |  Link
sh0dan
sh0dan's Avatar
You could look at ffdshow's msharpen implementation. I attached the source of the sharpen filters. There is a C and assembler version a little down. Look at my warpsharp port, if you'd like to see how the different variables are mapped.
I converted Warpsharp/Xsharpen, but didn't want to release msharpen, since you said you were working on it yourself.
Edit: I should not that the attachment only contains a source file.
Old 13th January 2003, 15:06   #7  |  Link
@sh0dan
If you have coded MSharpen for YV12, by all means please send me the code.
Old 13th January 2003, 15:28   #8  |  Link
sh0dan
sh0dan's Avatar
No - I didn't - the code from ffdshow isn't pretty, but it seems to do the job well. It only processes luma, but for sharpening, that's probably better. There might be some pitch issues, since ffdshow assumes input pitch = output pitch.
Old 13th January 2003, 22:17   #9  |  Link
Prettz
easily bamboozled user
Prettz's Avatar
This concerns the Avisynth 2.0 version so it might be a little off topic, but your msharpen seems to work miracles at reducing edge noise and ringing in Akira
keep up the good work!
Prettz is offline   Reply With Quote
Old 13th January 2003, 22:41   #10  |  Link
Considering that MSharpen is designed to apply EE and not reduce it, I find this very surprising. But hey, if it does good things for you...I'm happy.
Old 22nd January 2003, 03:43   #11  |  Link
Prettz
Prettz's Avatar
Sorry to bump this old thread, but I have another question concerning where in my script I should use the MSharpen filter. Specifically, my question is whether I should use it before or after convolution3d. I just want to be sure that I don't inadvertantly screw up the quality (even if it isn't noticeable, I just want to be on the safe side).
Here's my script:
LoadPlugin("C:\Program Files\GordianKnot\mpeg2dec.dll")
LoadPlugin("C:\Program Files\GordianKnot\Avisynth2\plugins\Decomb.dll")
LoadPlugin("C:\Program Files\GordianKnot\Avisynth2\plugins\MSharpen.dll")
LoadPlugin("C:\Program Files\GordianKnot\Avisynth2\plugins\Convolution3D.dll")
mpeg2source("C:\Akira\akira_part1_init_02.d2v")
FieldDeinterlace()
Convolution3d(preset="animeLQ")
MSharpen(threshold=15)
BicubicResize(512,288)
Like I mentioned earlier, MSharpen is actually greatly reducing edge noise and ringing for this movie, and it only bumped the filesize up by (if I remember correctly) a hundred KB or so for a 430MB clip.
Old 22nd January 2003, 04:03   #12  |  Link
I don't like MSharpen after FieldDeinterlace because it amplifies residual combing. Better to do it this way:
SeparateFields()
MSharpen()
Weave()
FieldDeinterlace()
Convolution3d()
BicubicResize()
I think it's OK before Convolution3d() as long as you use a reasonable threshold for MSharpen(). The areas you want Convolution3d() to clean up are the non-edge areas of MSharpen().
Old 22nd January 2003, 04:37   #13  |  Link
Prettz
Prettz's Avatar
Thanks, I'll try that. Although, after using forced-FILM there aren't very many combed frames, and the ones that are are often in such dark and noisy scenes that after resizing, the frame already looks like it was compressed in mpeg4
Old 22nd January 2003, 13:48   #14  |  Link
OK. If it is just catching a few strays your method is probably fine.
Old 5th April 2003, 15:37   #15  |  Link
YV12 support for MSharpen
Attached is MSharpen version 1.10 beta 1. It adds low-level optimized support for YV12.
This enhancement was contributed by Klaus Post and Milan Cutka. Thank you!
Old 5th April 2003, 17:54   #16  |  Link
sh0dan
sh0dan's Avatar
Did you modify it to only sharpen luma in YV12, or is it just a leftover from the older YUY2 documentation:
In YUY2 and YV12 space it sharpens only the luminance channel.
Old 5th April 2003, 20:26   #17  |  Link
It's a leftover. I'll correct it.
The new help file also needs to say Version 1.10 also. Did you miss that?
Thanks again for submitting this improvement.
Old 7th April 2003, 05:02   #18  |  Link
jarthel
plebian
thanks Donald.
Jayel
jarthel is offline   Reply With Quote
Old 7th April 2003, 22:34   #19  |  Link
FuPP
TotalEclipseOfTheBrain
FuPP's Avatar
Hi Neuron,
hmmm... I get a green screen with this one :
LoadPlugin("C:\video\avsfilters\yv12\MPEG2Dec3.dll")
LoadPlugin("C:\video\avsfilters\yv12\msharpen.dll")
mpeg2source("F:\tests\vts_01.d2v",cpu=0,idct=2)
Crop(26,76,668,424)
MSharpen()
BicubicResize(448,320,0,0.5)
AddBorders(16,128,16,128)
Something with cropping values I guess ?
Regards,
FuPP.
Using avs 2.51 build 04/04
FuPP is offline   Reply With Quote
Old 7th April 2003, 23:49   #20  |  Link
Did you try anything to isolate the problem?
Comment out the Crop, BicubicResize, and AddBorders and tell me what happens.
