#1 | Link |
VirtualDub 1.4.13 with MPEG-2 and AC-3 support (by fccHandler)
Hi there. Recently fccHandler published a patch for VirtualDub which enables it to directly read MPEG-2 streams, as well as AC-3 streams, using its built-in MPEG parser.
I've compiled it and found it pretty nice, now it's possible to directly load a VOB into VirtualDub, play it, and convert or frameserve it to another application, without the need to use an external reader such as AviSynth, DVD2AVI, VFAPI etc, and best of all, with built-in audio, so you don't need to extract and convert it separately. Althought VirtualDubMod already features VOB support, it uses the DVD2AVI engine and has no direct audio support (it's saved on a separate file). So I found this patch really interesting. Surely it could be optimized further, and may contain bugs, but I think it's definitely a step in the right direction. I hope the VirtualDubMod team consider adopting this great patch, at least as an alternative to the internal DVD2AVI reader. If you want to give it a try, check my homepage below. http://es.geocities.com/dextstuff/ DeXT |
#6 | Link | |
VirtualDub 1.4.13 with MPEG2 & AC3 Sources |
#7 | Link | |
I got it and am about to test it out. |
#8 | Link |
oh I get it
it's still alpha code, not for end user noobs call bluengine,
bluengine fades it to distance while the uber coders, and developers discuse and fix the code ...
yeah Last edited by bluengine; 18th January 2003 at 08:09. |
#9 | Link |
VirtualDub + True IVTC
VirtualDub would become invincible as a tool if it allowed filters to do IVTC, through decimation of frames and changing the framerate. And input / output plugins would be nice (though hardcoding into the source is fine, too).
Hey, wait a minute, this is starting to sound like how VirtualDub 2.0 was going to be. I haven't seen any official announcements about it's demise, anyone know about the status? Did I perhaps miss something? |
#11 | Link |
gldblade,, you can use IFO Mode in DVD Decrypter "File Splitting" is None so you will have one vob file.. on your ntfs partition.
I am trying this new virtualdub-patch with Xvid and Ogg acm.. http://hp.vector.co.jp/authors/VA012897/ |
#13 | Link | |
gantz
Gur svggrfg funyy fheivir lrg gur hasvg znl yvir. Jr zhfg ercrng. |
#14 | Link |
#15 | Link | |
Registered Jedi
I have a list of things I'd like to fix, including RFF/TFF and proper MPEG-2 chroma upsampling, but I haven't really had time to work on it. The code is freely available though, if anyone else wants to mess around with it: http://home.attbi.com/~blade66/Mpeg.cpp http://home.attbi.com/~blade66/mpeg_decode.cpp (Note that AC3 support is disabled in those sources.)
May the FOURCC be with you... Last edited by fccHandler; 18th January 2003 at 06:06. |
#16 | Link | ||||
Registered Jedi
May the FOURCC be with you... |
#18 | Link |
I have decoding problem (interlacing and block) with a PAL DVD.
Here is a VOB sample (~1Mo) : http://christophe.paris.free.fr/temp/bd_test.zip
Regards [Toff] |
#19 | Link | ||
Registered Jedi
| Thread Tools | |
| Display Modes | |
