Old 8th January 2003, 15:54   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Van Wilder Unrated R1 (Widescreen/ Fullscreen) Cheat Sheet
UPDATE: This cheat sheet has been edited for a fix on bypassing aspect ratio screen in step 13.
I'm bouncin' off the wall again...
I did this movie a while back but I had only a month of experience. I'm know better now. This is a really funny movie. I really wanted the uncensored menu "ON" all the time but I couldn't get it to work. So with motivation from others,you know who you are, I revisited Van Wilder Unrated R1 and did my magic.
It's hard to write a guide for all DVD movies and you know they aren't all the same. But I strongly believe in learning by examples. This is not just a cheat sheet, it's a "learning and understanding" cheat sheet.
Remember my motto. "What can be authored...can be de-authored."
Don't be a fool Timmy!, be 2COOL!
Tools I used:
SmartRipper 2.41
Ifoedit 0.95 (Thanks Derrow!)
Nero 5.5.9.17/Imgtool 0.95-98
_________________________________________________________________________________
1.
  • FULLSCREEN: Use Smartripper and rip all files except Vts_04_X.X.
  • WIDESCREEN: Use Smartripper and rip all files except Vts_05_X.X.
2. Use Ifoedit and open up VIDEO_TS.IFO.
3. Region Free just in case. If RCE is present, set your region and save IFO.
4. Get VTS Sectors.
5. Repeat step 3 for rest of other IFOs.
6. DVD play to preview.
7. ****IMPORTANT****:Before we dabble in the IFOs, it is important that we need to BACKUP all our IFOs and BUPs to another folder. In case something goes wrong. Trust me. What we need to do later, you donít want to mess up. Besides, itís a good habit. And also, I also jot down the original values before I change them so I can revert back to them if I erred out. Have a notepad nearby.
8. The first title played is Title 2 which is Artisanís Company Logo and the second is Title 3 which is the DVD contents declaration.
Letís bypass those suckers. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_2. We need to hexedit Pre command 12 as follows so double-left click on line.
OLD > 12.Pre Command...If GPreg<0> == GPreg<4> then (JumpTT) Jump to Title: 2...[30 22 00 00 00 02 00 04 ]
NEW > 12.Pre Command...If GPreg<0> == GPreg<4> then (JumpTT) Jump to Title: 1...[30 22 00 00 00 01 00 04 ]
Translation: Bypass Title 2 & 3 and main menu play upon DVD insert.
Details: Jumping to titles is part of VMGís job. Our instructions are always in VIDEO_TS.IFO / VMGM_PGCI_UTís PGC-Menus. It was easy going through all 14 PGC-Menus looking for a traces of Title 2 and found it in PGC-Menu 2. Title 1 contains your menus so I performed the edit above.
9. Save VIDEO_TS.IFO
10. DVD Play to preview change.
11. This was my first DVD in which I didnít have the movie menus in the same titleset. So I found it in Title 1.
In VTS_01_0.IFO, I viewed the VOBs in VTS overview/Language Menu Unit section and documented the important stuff for you and me.
Menu 7 : [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 1) This is our initial screen, girl pops up and dances with shirt on.
Menu 8 : [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 2) Main menu shirt and dancing (censored)
Menu 9 : [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 3) Main menu shirt and dancing (XXX)
Menu 10: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 4) XXX Main>Shirt Off
Menu 11: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 5) Censored Aspect Ratio>Shirt Off
Menu 12: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 6) XXX Aspect Ratio>Shirt Off
Menu 13: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 7) Censored Aspect Ratio>Shirt On
Menu 14: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 8) Aspect Ratio> Shirt On and dancing
Menu 15: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 9) XXX Main>Shirt Off>Aspect Ratio
Menu 16: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 10) Aspect Ratio> Shirt On and dancing
Menu 17: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 11) XXX Aspect Ratio>Shirt Off
Menu 18: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 12) Aspect Ratio> Shirt On and dancing
Menu 19: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 13) Aspect Ratio> Shirt On and dancing
Menu 20: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 14) Censored Aspect Ratio> Shirt Off
Menu 21: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 15) XXX Aspect Ratio> Shirt Off and fade to black
12. Hereís where the hard work comes in. What I found out was when I was previewing the movie and watching the Gpregs, I noticed only GPreg 11 would have the value of ď1Ē whenever I chose uncensored version. I also tooked in mind that Menu 8 was our censored version and Menu 9 was our uncensored version. So I went through every PGC-Menu in VTS_01_0.IFO / VTSM_PGCI_UT.
If I saw any command containing ďIf GPreg<11> == (cmp-val)<0>Ē, I hexedited that according to a nearby ďIf GPreg<11> == (cmp-val)<1>Ē command.
If I saw any Menu 8s in any command, I changed those to Menu 9s.
Pre-Translation: To view the you-know-what. The DVD will play uncensored (XXX) entirely,even if you chose the censored version.
Hexedit carefully because if you miss one, you wonít get to see the show. Go to VTS_01_0.IFO / VTSM_PGCI_UT and start editing. Oh if you donít know how to be in hexedit mode, just double-left click the command line. The hexedit window will pop up.
PGC-Menu 6
OLD > 13.Pre Command....If GPreg<0> == (cmp-val)<2> then (LinkPGCN) Link PGC 8.....[20 a4 00 00 00 02 00 08 ]
NEW > 13.Pre Command....If GPreg<0> == (cmp-val)<2> then (LinkPGCN) Link PGC 9.....[20 a4 00 00 00 02 00 09 ]
PGC-Menu 30
OLD > 34.Post Command...(LinkPGCN) Link PGC 8......................................[20 04 00 00 00 00 00 08 ]
NEW > 34.Post Command...(LinkPGCN) Link PGC 9......................................[20 04 00 00 00 00 00 09 ]
PGC-Menu 38
OLD > 14.Post Command...(LinkPGCN) Link PGC 8......................................[20 04 00 00 00 00 00 08 ]
NEW > 14.Post Command...(LinkPGCN) Link PGC 9......................................[20 04 00 00 00 00 00 09 ]
PGC-Menu 47
OLD > 12.Pre Command....Set GPreg<11> mov (set-val)<0>.............................[20 00 00 0b 00 00 00 00 ]
NEW > 12.Pre Command....Set GPreg<11> mov (set-val)<1>.............................[20 00 00 0b 00 01 00 00 ]
PGC-Menu 48
OLD > 7.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 8....[20 a4 00 0b 00 00 00 08 ]
NEW > 7.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 9....[20 a4 00 0b 00 00 00 09 ]
PGC-Menu 49
OLD > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 8....[20 a4 00 0b 00 00 00 08 ]
NEW > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 9....[20 a4 00 0b 00 00 00 09 ]
PGC-Menu 50
OLD > 2.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 8....[20 a4 00 0b 00 00 00 08 ]
NEW > 2.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 9....[20 a4 00 0b 00 00 00 09 ]
PGC-Menu 51
OLD > 4.Pre Command.....(LinkPGCN) Link PGC 8......................................[20 04 00 00 00 00 00 08 ]
NEW > 4.Pre Command.....(LinkPGCN) Link PGC 9......................................[20 04 00 00 00 00 00 09 ]
PGC-Menu 52
OLD > 9.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 13...[20 a4 00 0b 00 00 00 0d ]
NEW > 9.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 15...[20 a4 00 0b 00 00 00 0f ]
PGC-Menu 58
OLD > 68.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 18...[20 a4 00 0b 00 00 00 12 ]
NEW > 68.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 19...[20 a4 00 0b 00 00 00 13 ]
PGC-Menu 59
PGC-Menu 60
OLD > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 29...[20 a4 00 0b 00 00 00 1d ]
NEW > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 3....[20 a4 00 0b 00 00 00 1f ]
PGC-Menu 61
OLD > 4.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 30...[20 a4 00 0b 00 00 00 1e ]
NEW > 4.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 32...[20 a4 00 0b 00 00 00 20 ]
PGC-Menu 62
OLD > 9.Pre Command.....If GPreg<11> == (cmp-val)<0><' then Goto line# 22..........[20 a1 00 0b 00 00 00 16 ]
NEW > 9.Pre Command.....If GPreg<11> == (cmp-val)<0><' then Goto line# 28..........[20 a1 00 0b 00 00 00 1c ]
OLD > 19.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 30...[20 a4 00 0b 00 00 00 1e ]
NEW > 19.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 32...[20 a4 00 0b 00 00 00 20 ]
PGC-Menu 63
OLD > 95.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 8....[20 a4 00 0b 00 00 00 08 ]
NEW > 95.Pre Command....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 9....[20 a4 00 0b 00 00 00 09 ]
PGC-Menu 65
OLD > 4.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 14...[20 a4 00 0b 00 00 00 0e ]
NEW > 4.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 16...[20 a4 00 0b 00 00 00 10 ]
PGC-Menu 68
OLD > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 30...[20 a4 00 0b 00 00 00 1e ]
NEW > 5.Pre Command.....If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 32...[20 a4 00 0b 00 00 00 20 ]
You did it! Now the only matter is correcting the aspect ratio screen. This is our fullscreen or widescreen option.
UPDATE: Step 13 and 14 has been edited. Bypassing the aspect ratio screen has been updated. There is a fix now.
13. In VTS_01_IFO/VTSM_PGCI_UT/PGC-Menu_15,
OLD > 1.Pre Command NOP [00 00 00 00 00 00 00 00 ]
NEW > 1.Pre Command (LinkPGCN) Link PGC 21 [20 04 00 00 00 00 00 15 ]
Translation: When you press Play, you go straight to movie.
Details: PGC-Menu_15 had scene after you press play. PGC-Menu_21 has exit scene.
14. Save VTS_01_0.IFO
15. Get VTS Sectors
16. Press DVD Play and preview your movie. Preview in PowerDVD or WinDVD if you got it.
OPTIONAL: If you want to go to straight to your main menu and bypass the menu intro, you can do the following. In VTS_01_0.IFO / VTSM_PGCI_UT / PGC-Menu_7 / Cell Playback section,
OLD > [0000016e] Cell_1: entry point sector 0
NEW > [0000016e] Cell_1: entry point sector 4405 _________________________________________________________________________________
17. Thatís it. Burn what works for you.
Old 8th January 2003, 16:38   #2  |  Link
2COOL
2COOL's Avatar
Removing movie intros in Chapter 1
If you want to get rid of those pesky company logos and intros before the movie really starts then perform the following edit in Vts_05_0.ifo/VTS_PGCITI/VTS_PGC_1/Cell playback section.
Cell Playback:
OLD Cell_1: entry point sector 0 [00002554]
NEW Cell_1: entry point sector 9556 [00002554]
Translation: So when the movie begins to play, you bypass all the unneeded intros and the movie starts where it suppose to.
Old 8th January 2003, 21:35   #3  |  Link
2COOL
2COOL's Avatar
Did you know there is a hidden show (easter egg) on the main menu of disk 1? Well, I wouldn't say it's hidden but the way to navigate to there is sort of illogical. For those who knew, you've been spending too much time on the DVD, like me.
Navigate the star cursor over "SCENES" button and press your "UP" arrow button. Logically, it should wrap-around up and then highlight a button at the bottom of the screen but it jumps to the Van Wilder Logo on middle of her shirt. If you pressed "DOWN" from SCENES, your cursor will go to "PLAY" button.
When you see a smaller star on her shirt,press enter and enjoy! Me Likey!
Old 9th January 2003, 17:16   #4  |  Link
gnutellafan
OMFG, 2cool, your are, well TO COOL. Thank you sooooooo much for your guide. We really need an index for ppl to submit quality guides like yours to so ppl can easily look them up.
Get the fastest and most secure CD Ripper dBpoweramp Reference R13 featuring PerfectMeta
Try the most powerful and easy to use DVD editor - DVD Remake Pro
gnutellafan is offline   Reply With Quote
Old 12th January 2003, 01:23   #5  |  Link
gnutellafan
2cool (or anyone else),
I have a few questions:
Question 1
How did you know when to edit the commands in a certain way:
ie:
PGC-Menu 60
OLD 5.Pre Command If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 29 [20 a4 00 0b 00 00 00 1d ]
NEW 5.Pre Command If GPreg<11> == (cmp-val)<0> then (LinkPGCN) Link PGC 31 [20 a4 00 0b 00 00 00 1f ]
I tried to do this on my own w/o reading the hex edits you gave and just the advice. When I cam to this pgc menu I edited the hex value to:
5.Pre Command If GPreg<11> == (cmp-val)<1> then (LinkPGCN) Link PGC 29 [20 a4 00 0b 00 01 00 1d ]
So how did you know to leave the cmp-val @ 0 and change the 1d to 1f. I can see that you made this pre command basicaly like another one right below it.
Question 2
Your solution for skipping "those pesky company logos and intros before the movie really starts" doesnt work for me. The DVD freezes right before the movie should start. Are you sure this is the correct way to do this?
Question 3
I know you said you couldnt figure this out before but Im sure it can be done. Can you help me try to figure out how to skip the widescreen/fullscreen selection screen altogether. Whatever funtion is associated with going to that selection screen just needs to be changed to go straight to the movie.
Question 4
First, I think you got your direction a bit confused for fixing the widescreen/fullscreen selection menu (they are backwards). Also, if I have to keep the menu, is there a command line that would allow you to go straight to the movie if you select fullscreen (and have the widescreen version) right now it just loops back to play the whole menu again.
Again, thank you for all of your help 2cool, I think I am finally begining to learn some of the finer points of the ifofiles. Now I just wish Derrow would get back because I have soooo many suggestion.
Old 12th January 2003, 04:42   #6  |  Link
2COOL
2COOL's Avatar
gnutellafan,
2CL is here and with replies...
Originally posted by gnutellafan
Question 1
ie:
PGC-Menu 60
So how did you know to leave the cmp-val @ 0 and change the 1d to 1f. I can see that you made this pre command basicaly like another one right below it.[/B]
First of all, we need to be working on the original VTS_01_0.IFO. Open IFO and DVD play. Click on IFOedit status panel and click on the square button on the far right with a dot in it. This shows your GP Register section. Click on title bar of video window to select as active window and click on "uncensored" menu button and watch Gpreg<11>'s value. Initially, you should be seeing a "1" as the original default was your censured menu. Click on "censured" menu button again and watch GPreg<11>'s value. Notice the toggling values?
So, as I stated in step 12 in my above cheat sheet. A value of "1" in GPreg<11> is present when you are playing CENSURED menu. A value of "0" is present when you are in your UN-CENSORED menu.
So as stated in my step 12 in my cheat sheet, where there is a GPreg<11> == (cmp-val)<0>, there's a nearby GPreg<11> == (cmp-val)<1> command which is pre-command #7.
We didn't need to edit the pre-command #7 as it plays our UNCENSORED menu as programmed. We just needed to edit pre-command #5 which contained our (cmp-val)<0>. So don't edit pre-command #7, just mirror what comes after the "then" part in the precommand #5 just like pre-command #7. That's where the bytes "1d" and "1f" come to play.
Do you get the picture now? That's as simple as I can get.
Question 2
Look in this thread in OPTION B, as I mention about doing the same procedure with BarberShop.
http://forum.doom9.org/showthread.php?s=&threadid=42701
I don't experience any freezes on my computer but your configuration is not the same configuration as mine(software and hardware). The only other way I can think of is to probably to cut the desired intro frames out but I wouldn't want to go through the whole trouble. Anyway, changing the entry point sector does work for me but with unpredictable added delay after burn. Maybe it's my burner...maybe it's my player.
Question 3
You had to bring it up! Now the IFOedit side of the brain is wanting to tackle that menu again. Give me time, I'll break the code. I like a good challenge! By the way, doing this makes her show her T*Ts one show less. C'mon, we just can't enough of her puppies!
Question 4a
WHAT THE?!! WHO CHANGED THOSE ON ME?!
Okay. My bad. I missed that one. It was early morning and I was near the end of my cheat sheet. I was really mentally drain. I'm surprise after all the views, no one caught it earlier? Considered it fixed in first thread after this post.
Did it ever occur to that maybe I did that error on purpose so to stimulate your mind and understand the code?
Question 4b
Hmmm...it supposed to work. I don't have the original DVD with me now to check. My backup is not experiencing that. Could you possibly try the updated cheat sheet again and tell me the results?
[/QUOTE]
2COOL
Old 12th January 2003, 05:24   #7  |  Link
gnutellafan
Ok, Ive been going over the ifos like crazy. PGC menu 6 (VTS_01_0.ifo) seems to be the master for all the buttons. Menu 15 is our menu of interest (I think), and it links to PGC menu 65.
I know Im on the right track with menu 15 because I can break the play button with it and leave everything else intact. I tried changing the # of pre-commands to 1 and jumping to the title set but that didnt work.
Old 12th January 2003, 05:27   #8  |  Link
gnutellafan
Could VOBedit be used here? I have no idea how to use it, what its for ect (well, not much anyhow)
Old 12th January 2003, 05:42   #9  |  Link
gnutellafan
OK, im kind leaning towards menu six now.
20.Pre Command If Gpreg<0> == (cmp-val)<9> then (linkPGCN) Link PGC 15 [20 a4 00 00 00 09 00 0f]
If anyone could tell me how to change this to:
20.Pre Command If Gpreg<0> == (cmp-val)<9> then (Jump_TT) Jump To Title 5
(the movie would be title 5 right, or 1??)
I think this would work
Old 12th January 2003, 05:46   #10  |  Link
2COOL
2COOL's Avatar
I rarely use VOBedit.
Anyway I'm currently downloading my Van Wilder files back unto my harddrive.
In the mean time, back in you PGC-Menu_15 pre-command #1, try this
NEW > 1.Pre Command (JumpSS VMGM) Jump to VMG PGC: 2 [30 06 00 02 00 c0 00 00 ]
2COOL
Old 12th January 2003, 05:52   #11  |  Link
2COOL
2COOL's Avatar
Since you are in VTS_01_0.IFO, you can't do a jump from a titleset to title. You must jump from titleset>VMG>title.
2COOL
Old 12th January 2003, 06:31   #12  |  Link
gnutellafan
Im a bit confused. I now understand that we cant jump to the title set, but I think Im still in the right place, just need the right set of commands.
So how do you go from the menus to the movie. Ive tried to follow them through to see where it links to the movie and how it does it but I can find it.
BTW, the hex to get:
Is:
[30 22 00 00 00 05 00 09]
Not sure what the 30 is for
Next would be 02 for a plain (jump_tt), but 22, has the if/then
(I dont know why you cant just edit this with ifoedit, did Derrow just not get around to it yet?? Oooo we need Derrow back or for him to open the source code up)
The 05 denotes the title to jump to, in the case 5
The last 09 is to set it to<9>
Of course this is all mute, but Im just proud I figured it out.
Old 12th January 2003, 06:32   #13  |  Link
2COOL
2COOL's Avatar
Bring it on Jimmy! I'm just 2CL!
You can jump from PGC-Menu to PGC-Menu as that is called navigating within the Titleset PGC domain. To do that, you use (LinkPGCN) command
2COOL
Old 12th January 2003, 06:52   #14  |  Link
gnutellafan
Hmm, Ill have to go back and see if I screwed something up but doing this just causing hitting the play button to go back to the start of the menu for me
Old 12th January 2003, 07:08   #15  |  Link
2COOL
2COOL's Avatar
Cheat sheet in first thread has been updated!
2COOL
Old 4th February 2003, 00:54   #16  |  Link
gnutellafan
2cool, sorry to bring this one back up from the depths, but as I said about your solution to the screen size selection menu just causes me to loop back to the begining of the menu. Any ideas?
Old 4th February 2003, 00:58   #17  |  Link
gnutellafan
Should I change the # of precommands to 1? I didnt but was wondering if this would fix my problem. Ill try it :0
Old 4th February 2003, 01:04   #18  |  Link
gnutellafan
ok, that didnt work, but im going to try something different. If I link pgc 15 to pgc 10 I get the initial lifting to the shirt, not the exit, now I just need to know how to link 15 to the movie. What command do I use to link to the movie since its in a different title set( aka how do I titleset>VMG>title)?
Old 4th February 2003, 01:08   #19  |  Link
2COOL
2COOL's Avatar
Are you working on a region 1 DVD?
By the way, Did you get my PM message alert?
2CL
2COOL
Old 4th February 2003, 01:16   #20  |  Link
gnutellafan
damn, I thought it was your dyslexia. Linking to pgc 12 also gives the exit scene (actually thought there may have been a difference if you choose widescreen vs limited view) but linking to pgc 12 also just causes her to take off her shirt and instead of going to the movie just loops back to the main menue (like the full screen button was set up to do)
