#1 | Link |
what's this for?
strange audio_filter setup (I see them double!!)
hi folks,
after a fresh install of my system I've made some weird experience with my filter setup. Everything works ok, but as you can see (when you open up this link ![]() Can someone tell me any reason for this behaviour. Is it due to an installed filter? here is a rough list of my filter setup: Audio: - ac3filter_0_63b.exe - dsp2dshow-20020930.exe - OggDS0995.exe - ReClock 0.98c.exe - winLAME-rc3.exe - lame 3.93.1_ACM - OdioDec (mlcom.ax) Video: - DivXPro5.02.exe - XviD-29122002-1.exe - EnvivioTV MPEG-4.exe - ffdshow-20021213.exe - ffvfw-20020827.exe - INDEOv5 setup.exe - BTVVC32.DRV - GPEG Codec - huffyuv_ccesp-patch_0.2.2.dll - dx81-yuv-fix.exe - MainConcept DV Codec v2.04 - PICVideo MJPEG - VIDCI263 I've installed Elecard MPEG2_Video_Decoder v.2.0 Beta as well, with the following... - minidivx.ax - mpeg2dmx.ax - mpgdec.ax - pim2null.ax - pva_dmx.ax - windivx.ax just to complete the list... I've used 'RegDrop' to register the following *.ax_files: - AACDEC.AX - AVI_Renderer.ax - D2VSource.ax - DUMP.AX - lame_dshow.ax - MMSwitch.ax - Mpeg2Decoder.ax - Mpeg2Parser.ax - mpgaudio.ax - Multiple_MPEG2_Source.ax - VideoResizer.ax - WAVDEST.AX my system: WinXP_SP1 (as I said a fresh setup) note: I've never ever had it before thanks in advance Sill P.S.: I wish you a happy new year - stay cool, stay clever, doom9(.org_.de) forever!!!
latest mix sets: http://soundcloud.com/sill Last edited by sillKotscha; 3rd January 2003 at 15:49. |
#2 | Link |
You have to enable the audio switcher if you want to load external audio files, and then the two paths of audio will not be connected into separate renderers. The two codec being there is normal, only decoded audio can be switched because differently compressed streams may require different decoders and it wouldn't be easy to swap them out on-the-fly without stopping playback and rebuilding half of the graph.
gabest.org |
#3 | Link |
what's this for?
thanks dude,
one mystery is solved ![]() many thanks Sill Ot: your downloads for the new build of MPC won't work... copy/ paste = leech direct = error 404
latest mix sets: http://soundcloud.com/sill |
