Old 26th December 2002, 14:18   #1  |  Link
juange
how I solve my cce crash problem.
This is how I solve my cce crash problem. I hope will be helpful for some people in this forum.
I’m a beginner user. This is my pc specification:
Athlon xp 2.000
Mobo ecs k7s5a
Ram : 512 (2 dimm spectek)
Hd: western digital 40 gb.
You can see that it’s not expensive ram or mobo.
First: I followed all suggested in “Q&A -DVD2SVCD Official Q&A”. But continued with freezes. Them I change my power supply from 250 watts to 350 watts.
After that no more crashes but CCE stop, no freeze, and it was possible close the program. I read a lot of thread about this, but did not solve my problem.
In some place I read about cluster size and long files, for this I changed cluster size from 4 k to 8 k in my NTFS with partition magic, and everything work perfect, also with cce and vbr 4 passes.
Key found: D4FB73D364
- 25/12/2002 13:19:17
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.0.9 build 3
Initializing
Initializing finished.
- 25/12/2002 13:19:20
- Analyzing subtitles
Subtitle found: StreamID: 0x24 Language: Español
Subtitle found: StreamID: 0x20 Language: English
Subtitle found: StreamID: 0x21 Language: Español
Subtitle found: StreamID: 0x23 Language: English
Executing subtitle selection/verification.
Subtitle selection/verification accepted.
1 subtitle streams selected.
Saving Subtitles ini file
- 25/12/2002 13:21:04
- Free on drive C: 31618.55 mb
- Internal rip
Preparing vobfiles to be ripped:
- F:\VIDEO_TS\VTS_01_1.vob
- F:\VIDEO_TS\VTS_01_2.vob
- F:\VIDEO_TS\VTS_01_3.vob
Ripping: F:\VIDEO_TS\VTS_01_1.vob
Ripping: F:\VIDEO_TS\VTS_01_2.vob
Ripping: F:\VIDEO_TS\VTS_01_3.vob
Ripping finished. Speed: 1792
- 25/12/2002 13:46:05
- DVD2AVI
Creating DVD2AVI INI file:
- C:\movie\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\movie\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\movie\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\movie\DVD2SVCD\Movie\VTS_01_1.vob,C:\movie\DVD2SVCD\Movie\VTS_01_2.vob,C:\movie\DVD2SVCD\Movie\VTS_01_3.vob]
Analyzing DVD2AVI Project file
Force Film activated!
Framerate: 23976
DVD2AVI processing done.
- 25/12/2002 13:47:51
- Free on drive C: 28993.79 mb
- Extracting the subtitles.
Subtitle extraction finished. Extracted these subtitles:
SVCD Stream no: 1 Language: Español Num. of subs: 908
- 25/12/2002 13:51:05
- Free on drive C: 28982.18 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: C:\movie\DVD2SVCD\Movie\Extracted_audio_2.ac3
Found AC3 stream id: 0x81
Filename: C:\movie\DVD2SVCD\Movie\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Audio2 delay: 0 ms
Audio extraction finished.
- 25/12/2002 13:54:02
- Free on drive C: 28555.13 mb
- AUDIO conversion
Converting Audio to MP2. Filename: C:\movie\DVD2SVCD\Movie\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\movie\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\movie\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\movie\DVD2SVCD\Movie\Encoded_audio_1.mp2" -logfile "C:\movie\DVD2SVCD\Movie\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -ssrc( --rate 44100 ) -2lame( -e -b 160 -m s )
Audio conversion of C:\movie\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
Converting Audio to MP2. Filename: C:\movie\DVD2SVCD\Movie\Extracted_audio_2.ac3
"C:\movie\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\movie\DVD2SVCD\Movie\Extracted_audio_2.ac3" -output "C:\movie\DVD2SVCD\Movie\Encoded_audio_2.mp2" -logfile "C:\movie\DVD2SVCD\Movie\Encoded_audio_2.log" ) -azid( -L -3db -c normal -g max ) -ssrc( --rate 44100 ) -2lame( -e -b 128 -m s )
Audio conversion of C:\movie\DVD2SVCD\Movie\Extracted_audio_2.ac3 finished.
Audio conversion finished.
- 25/12/2002 14:23:10
- Free on drive C: 28394.89 mb
- Converting Pictures
Converting: C:\movie\DVD2SVCD\DefaultTitlepicture.bmp
Converting: C:\movie\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 25/12/2002 14:23:20
- Free on drive C: 28393.92 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1644169576
AudioSectors: 170365468
VideoPAPO: 22830012
ScanOffsetBytes: 134195
SeqAligningBytes: 8528825
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 3848544
EmptySectors: 238.00
PictureSectors: 600.00
PureMPEGStream: 1438462524.13
Seconds: 4669.21
CalcMPEGStream: 1438462524.13
Frames: 111829
CDSize: 790.00
Cut point 782.00
Variable Settings:
Frames: 111829
Anti Noise Filter: Off
Passes: 4
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2230
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\movie\DVD2SVCD\SIMPLE~1\SIMPLE~1.DLL")
LoadPlugin("C:\movie\DVD2SVCD\MPEG2Dec\MPEG2D~1.DLL")
mpeg2source("C:\movie\DVD2SVCD\Movie\DVD2AV~1.D2V")
SimpleResize(480,480)
ResampleAudio(44100)
----AVS End----
- 25/12/2002 20:05:00
Initializing
- 25/12/2002 20:05:06
- Free on drive C: 28182.78 mb
- Crash Recovery
- Restarting from: Video encoding
- 25/12/2002 20:05:13
- Free on drive C: 28182.77 mb
VideoPAPO: 22830012
DVDBytes: 0
VideoEndHeader: 8
Seconds: 4669.21
Frames: 111829
CDSize: 790.00
Cut point 782.00
Variable Settings:
Frames: 111829
Passes: 4
Image Quality: 17
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2230
---AVS Begin---
----AVS End----
Closing program
CCE Max Speed: 1.470
Video Encoding finished.
- 25/12/2002 23:42:29
- Free on drive C: 26989.73 mb
- Video Pulldown
Executing Pulldown. Commandline:
"C:\movie\DVD2SVCD\pulldown\pulldown.exe" "C:\movie\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC.mpv" "C:\movie\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.mpv"
Video pulldown finished.
- 25/12/2002 23:46:30
- Free on drive C: 25749.80 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\movie\DVD2SVCD\bbMPEG\default.ini
Executing RunbbMPEG. Commandline:
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\movie\DVD2SVCD\Movie\TitlePicture.bmp.mpg"
- 25/12/2002 23:46:45
- Free on drive C: 25749.75 mb
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\movie\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg"
- 25/12/2002 23:46:49
- Free on drive C: 25749.70 mb
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 782 mb
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 25/12/2002 23:55:37
- Free on drive C: 24315.03 mb
- Determining length of audio
Analyzing: C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
2544.666 seconds C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
Analyzing: C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
2117.094 seconds C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
Analyzing finished.
Saving Subtitle Timecodes.
SVCD subtitles.
Length of C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
2544
Length of C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
2117
- 25/12/2002 23:56:32
- Free on drive C: 24314.34 mb
- Multiplexing CVD Subtitles
Muxing Español subtitles, CD 1
Executing SubMux. Commandline:
"C:\movie\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 -C "C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg" "C:\movie\DVD2SVCD\Movie\Subs\es1-1.sub" "C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File-subbed00.mpg"
Muxing Español subtitles, CD 2
"C:\movie\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 -C "C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg" "C:\movie\DVD2SVCD\Movie\Subs\es1-2.sub" "C:\movie\DVD2SVCD\Movie\bbMPEG_Muxed_File-subbed01.mpg"
Muxing subtitles finished
- 25/12/2002 23:59:18
- Free on drive C: 22879.10 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 14
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\movie\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\movie\DVD2SVCD\Movie\CD_Image_File_CD1.cue" --bin-file="C:\movie\DVD2SVCD\Movie\CD_Image_File_CD1.bin" "C:\movie\DVD2SVCD\Movie\VCDXBuild_Script_1.xml"
- 26/12/2002 0:01:42
- Free on drive C: 22083.41 mb
- No. of chapters to create: 15
CD image #2: CD_Image_File_CD2.bin
"C:\movie\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\movie\DVD2SVCD\Movie\CD_Image_File_CD2.cue" --bin-file="C:\movie\DVD2SVCD\Movie\CD_Image_File_CD2.bin" "C:\movie\DVD2SVCD\Movie\VCDXBuild_Script_2.xml"
CD-Image creation finished.
- 26/12/2002 0:03:37
- Free on drive C: 21423.16 mb
- SVCD Creation finished!
juange is offline   Reply With Quote
Old 27th December 2002, 02:23   #2  |  Link
UltimateDBZ
UltimateDBZ's Avatar
Thanks for the info, hopefully it will help someone sometime
WebMaster: DBZCenter.com
IRC: #anime-xtreme @ irc.mircx.com
UltimateDBZ is offline   Reply With Quote
Old 27th December 2002, 14:49   #3  |  Link
juange
¡Great ¡
I found my thread in “Q&A -DVD2SVCD Official Q&A” Q60
It’s an honour for me.
Now I’ll try use bicubic resize.
Old 27th December 2002, 14:52   #4  |  Link
juange
Note :
I didn´t use "Use the "Safe mode (frameserving)" option in "Encoder" tab " in my first test.
Old 28th December 2002, 12:58   #5  |  Link
juange
Well, I tested setting CCE with :
Video encoding mode : 4 pass vbr
No safe mode
Resized method : Bicubic Resize.
The results it was successful.
The only small problem was that the film is BLACK HAWK DOWN “NTSC 2.35:1 (1.85:1) letterboxed DVD” and I followed this suggest :
qte
4) To convert a NTSC 2.35:1 (1.85:1) letterboxed DVD to a SVCD that looks like a 1.85:1 (4:3) DVD, make your script look like this:
Crop(90,60,540,360) <= insert this line
SimpleResize(480,480) <= this line depends on the resize method used
AddBorders(0,60,0,60) <= delete this line if present
uqte
And the film look a little stretch. I will look for a solution in the forum.
- 27/12/2002 13:21:30
Initializing
- 27/12/2002 13:21:32
Subtitle found: StreamID: 0x22 Language: Portugues
- 27/12/2002 13:22:01
- DVD2AVI
Variable settings:
Executing DVD2AVI.
"C:\movie\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Temp\DVD2AVI_Project_file] -IF=[C:\movie\DVD2SVCD\Movie\VTS_01_1.vob,C:\movie\DVD2SVCD\Movie\VTS_01_2.vob,C:\movie\DVD2SVCD\Movie\VTS_01_3.vob,C:\movie\DVD2SVCD\Movie\VTS_01_4.vob,C:\movie\DVD2SVCD\Movie\VTS_01_5.vob,C:\movie\DVD2SVCD\Movie\VTS_01_6.vob]
Framerate: 23976
- 27/12/2002 13:25:10
- Free on drive C: 21574.35 mb
SVCD Stream no: 1 Language: Español Num. of subs: 1447
- 27/12/2002 14:37:08
- Free on drive C: 21556.13 mb
- AUDIO Extraction
Filename: C:\Temp\Extracted_audio_1.ac3
Audio1 delay: 0 ms
- 27/12/2002 14:42:48
- Free on drive C: 21099.27 mb
- AUDIO conversion
Converting Audio to MP2. Filename: C:\Temp\Extracted_audio_1.ac3
"C:\movie\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Temp\Extracted_audio_1.ac3" -output "C:\Temp\Encoded_audio_1.mp2" -logfile "C:\Temp\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -ssrc( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of C:\Temp\Extracted_audio_1.ac3 finished.
- 27/12/2002 15:15:55
- Free on drive C: 20899.84 mb
- 27/12/2002 15:16:06
StreamSectors: 2495536764
AudioSectors: 210793772
VideoPAPO: 35391888
ScanOffsetBytes: 249185
SeqAligningBytes: 15837078
DVDBytes: 0
VideoEndHeader: 12
SubtitleSectors: 6042400
PictureSectors: 900.00
PureMPEGStream: 2227222428.80
Seconds: 8665.91
CalcMPEGStream: 2227222428.80
Frames: 207654
CDSize: 800.00
Cut point 792.00
Variable Settings:
Frames: 207654
Passes: 4
Image Quality: 17
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2056
---AVS Begin---
mpeg2source("C:\Temp\DVD2AV~1.D2V")
Crop(90,60,540,360)
BicubicResize(480,480,0,0.75)
----AVS End----
- 27/12/2002 16:57:20
Initializing
- 27/12/2002 16:57:21
- Free on drive C: 20956.50 mb
- Crash Recovery
- 27/12/2002 16:57:24
VideoPAPO: 35391888
DVDBytes: 0
VideoEndHeader: 12
Seconds: 8665.91
Frames: 207654
CDSize: 800.00
Cut point 792.00
Variable Settings:
Frames: 207654
Passes: 4
Image Quality: 17
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2056
---AVS Begin---
Crop(90,60,540,360)
----AVS End----
- 27/12/2002 21:19:41
Initializing
- 27/12/2002 21:19:44
- Free on drive C: 20493.80 mb
- Crash Recovery
- 27/12/2002 21:19:49
VideoPAPO: 35391888
DVDBytes: 0
VideoEndHeader: 12
Seconds: 8665.91
Frames: 207654
CDSize: 800.00
Cut point 792.00
Variable Settings:
Frames: 207654
Passes: 4
Image Quality: 17
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2056
---AVS Begin---
Crop(90,60,540,360)
----AVS End----
- 27/12/2002 21:26:04
Initializing
- 27/12/2002 21:26:06
- Free on drive C: 20849.07 mb
- Crash Recovery
- 27/12/2002 21:26:11
- Free on drive C: 20849.06 mb
VideoPAPO: 35391888
DVDBytes: 0
VideoEndHeader: 12
Seconds: 8665.91
Frames: 207654
CDSize: 800.00
Cut point 792.00
Variable Settings:
Frames: 207654
Passes: 4
Image Quality: 17
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2056
---AVS Begin---
Crop(90,60,540,360)
----AVS End----
Closing program
CCE Max Speed: 1.310
- 28/12/2002 4:48:32
- Free on drive C: 18760.48 mb
- Video Pulldown
"C:\movie\DVD2SVCD\pulldown\pulldown.exe" "C:\Temp\Encoded_Video_CCE_NTSC.mpv" "C:\Temp\Pulldown_Encoded_Video_NTSC.mpv"
- 28/12/2002 4:55:55
- Free on drive C: 16703.88 mb
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Temp\TitlePicture.bmp.mpg"
- 28/12/2002 4:56:10
- Free on drive C: 16703.87 mb
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Temp\ChangeCDPicture.bmp.mpg"
- 28/12/2002 4:56:14
Executing bbMPEG.
Variable Settings:
Cut point: 792 mb
"C:\movie\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Temp\bbMPEG_Muxed_File.mpg"
- 28/12/2002 5:14:28
- Free on drive C: 14329.23 mb
Analyzing: C:\Temp\bbMPEG_Muxed_File00.mpg
2855.131 seconds C:\Temp\bbMPEG_Muxed_File00.mpg
Analyzing: C:\Temp\bbMPEG_Muxed_File01.mpg
2638.472 seconds C:\Temp\bbMPEG_Muxed_File01.mpg
Analyzing: C:\Temp\bbMPEG_Muxed_File02.mpg
3161.378 seconds C:\Temp\bbMPEG_Muxed_File02.mpg
Analyzing finished.
SVCD subtitles.
Length of C:\Temp\bbMPEG_Muxed_File00.mpg
2855
Length of C:\Temp\bbMPEG_Muxed_File01.mpg
2638
Length of C:\Temp\bbMPEG_Muxed_File02.mpg
3161
- 28/12/2002 5:16:15
- Free on drive C: 14328.16 mb
"C:\movie\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 -C "C:\Temp\bbMPEG_Muxed_File00.mpg" "C:\Temp\Subs\es1-1.sub" "C:\Temp\bbMPEG_Muxed_File-subbed00.mpg"
"C:\movie\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 -C "C:\Temp\bbMPEG_Muxed_File01.mpg" "C:\Temp\Subs\es1-2.sub" "C:\Temp\bbMPEG_Muxed_File-subbed01.mpg"
Muxing Español subtitles, CD 3
"C:\movie\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 -C "C:\Temp\bbMPEG_Muxed_File02.mpg" "C:\Temp\Subs\es1-3.sub" "C:\Temp\bbMPEG_Muxed_File-subbed02.mpg"
- 28/12/2002 5:20:54
- Free on drive C: 12051.02 mb
- No. of chapters to create: 7
CD image #1: Try0_CD_Image_File_CD1.bin
"C:\movie\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\Temp\Try0_CD_Image_File_CD1.cue" --bin-file="C:\Temp\Try0_CD_Image_File_CD1.bin" "C:\Temp\VCDXBuild_Script_1.xml"
- 28/12/2002 5:23:16
- Free on drive C: 11245.36 mb
- No. of chapters to create: 10
CD image #2: Try0_CD_Image_File_CD2.bin
"C:\movie\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\Temp\Try0_CD_Image_File_CD2.cue" --bin-file="C:\Temp\Try0_CD_Image_File_CD2.bin" "C:\Temp\VCDXBuild_Script_2.xml"
- 28/12/2002 5:25:46
- Free on drive C: 10440.48 mb
- No. of chapters to create: 13
CD image #3: Try0_CD_Image_File_CD3.bin
"C:\movie\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\Temp\Try0_CD_Image_File_CD3.cue" --bin-file="C:\Temp\Try0_CD_Image_File_CD3.bin" "C:\Temp\VCDXBuild_Script_3.xml"
- 28/12/2002 5:29:06
- Free on drive C: 9636.40 mb
[IMG] code is Off
