Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 22nd December 2002, 23:17   #1  |  Link
hakko504
Remember Rule One
hakko504's Avatar
GKnot 0.27 Segmented AVI loading
Unfortunately it is only possible to load ONE AVI file into the new GKnot, but there is a workaround. GKnot can now open AviSynth scripts(!) so you only create a .avs file with this single line:
SegmentedAviSource("capture.avi")
...and open it in GKnot. This will setup GKnot correctly for your convenience.
It is then possible to edit the final AVS to incorporate this line instead of AviSource("capture.avs")
/hakko
http://www.boardgamegeek.com
hakko504 is offline   Reply With Quote
Old 24th December 2002, 11:40   #2  |  Link
Wilbert
Note that SegmentedAviSource has a bug in AviSynth v2.07, as a work around you should manually delete the last (small, empty) segment or use v2.06.
Old 27th December 2002, 09:42   #3  |  Link
mazzo
When I use it, it never reads the first file, it says it can't decompress frame 0. But if I trim the first file and save it again, it works.
mazzo is offline   Reply With Quote
Old 6th January 2003, 05:27   #4  |  Link
TheWEF
Gordian Mod.
TheWEF's Avatar
Originally posted by kempodragon
When I saw that Gknot 0.27 opens avi files, it was what I'd been waiting for, especially since I've moved to doing all my caps with Huffyuv in VirtualDub. However, when I tried to open one of my captures, all I got was a grey screen. I saw some other people mention this problem, but no solution. Then I remembered seeing it mentioned 0.27 will also open avs files, so I made a one line avs opening my cap with the AviSource command. I then tried it in Gknot, and bingo, it opened perfectly!!. I then resized and cropped, BUT I didn't use the save and encode function. I merely closed the avs, and edited the original file. I don't know how TheWEF implemented avi files, but it appears to want uncompressed colorspace. I'm not complaining, since I know from my own experience how Murphy's Law LOVES computer programming. :0 This is merely an observation about using this new function.
TheWEF is offline   Reply With Quote
Old 15th January 2003, 18:20   #5  |  Link
mazzo
My experience is that when I open an avi file in GKnot, it will be displayed. When I write an .avs with the same file in it, it will not be displayed, I'll only get the grey screen.
Is there anything wrong with this line:
AVISource("d:\video\simpsons.00.avi")
It will be grey in GKnot.
Old 20th January 2003, 15:04   #6  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Hi Wilbert,
I personally noticed that this 'bug' only occures if I try to load Huffyuv_captures (i.e. 720x576). SegmentedAviSource in AviSynth v2.07 works flawless (in my case) with [PicVideo @q19]-MJPEG. That's why GKnot opens SegmentedAviSource captured with MJPEG like a charm, but refuses to load if captured with Huffyuv.
my 2 cents
regards Sill
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline   Reply With Quote
Old 20th January 2003, 15:15   #7  |  Link
mazzo
Amazing how people's experiences differ. I CAN'T see anything but grey when I open avs (or avi, for that matter) that is captured with picvideo mjpeg q 18.
Old 20th January 2003, 16:03   #8  |  Link
Wilbert
Hmm, can you try the latest 2.07+ binary "http://cultact-server.novi.dk/kpo/avisynth/avs_cvs.html". Same problem?
@mazzo,
Is installing huffyuv of any help (and removing msyuv.dll)?
Old 20th January 2003, 16:33   #9  |  Link
sillKotscha
what's this for?
I already tried... no chance
regards Sill
Old 25th March 2003, 21:33   #10  |  Link
SunDanceKid2001
Solution?
Hi there,
just came over this Thread, coz I also wanted to load segmented AVI's in GKnot.
I have the same "Grey-Screen"-Problem.
My Captures were done with a DC10+ (own MJPEG-Codec).
But for playback/edit I use PicVideo. (...because I process Video on another Machine, which has no DC10 inside...)
I use GKnot 0.27 + SystemPack (Fresh Install, no updated Software...)
Has anybody a Solution for that Problem described above?
Thanx...
SunDanceKid2001 is offline   Reply With Quote
