Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 9th October 2002, 13:13   #1  |  Link
alexnoe
Banned
alexnoe's Avatar
To all who can't get ADVDInfo work
EDIT fixed links
Download the latest cdrtools and cdrecord-prodvd
Open a dos windows (windows 2000: "cmd", windows 98: "command"), find out the scsi host address of your dvd writer (Possible with Nero or, if you prefer, cdrecord -scanbus), and write:
cdrecord-prodvd -dev=x,y,0 -atip
(with x,y being your host address)
This requires a working aspi layer!
alexnoe is offline   Reply With Quote
Old 10th October 2002, 16:33   #2  |  Link
Taxidermista
OMG, it works! Thanks a lot, alexnoe.
Ah, just a note: cdrecord parameters are case-sensitive.
Taxidermista is offline   Reply With Quote
Old 10th October 2002, 20:52   #3  |  Link
trekkerj
>cdrecord-prodvd -dev=x,y,0 -atip (with x,y being your host address)
What does this command do, btw? (Just before I blindly download and use it)
trekkerj is offline   Reply With Quote
Old 10th October 2002, 21:03   #4  |  Link
alexnoe
Banned
alexnoe's Avatar
It will give you something like this:
Cdrecord-ProDVD-Clone 1.11a22 (i586-pc-cygwin) Copyright (C) 1995-2002 Jörg Schilling
Unlocked features:
Limited features:
Using libscg version 'schily-0.6'
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'PIONEER '
Identifikation : 'DVD-RW DVR-103 '
Revision : '1.90'
Device seems to be: Generic mmc2 DVD.
Using generic SCSI-3/mmc-2 DVD-R/DVD-RW driver (mmc_dvd).
Driver flags : SWABAUDIO
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R
Total power on hours: 5361
book type: DVD-R, Version 5 (2.5)
disc size: 120mm (0)
minimum rate: 10.08 MB/s (2)
number of layers:0
track path: Parallel Track Path (0)
layer type: Rewritable Area (2)
linear density: 0.267 µm/bit (0)
track density: 0.74 µm/track (0)
phys start: 196608
phys end: 2469823
end layer 0: 0
bca: 0
phys size:... 2273216
copyr prot type: 0
region mgt info: 0
cpm: 0
cgms: 0
last rma sector: 0
application code:64
physical code: 193
last rec address:16621272
part v./ext code:5/0
ind wr. power: 135
wavelength code: 13
Manufacturer: 'MCC 00RG200 '
rzone number: 1
border number: 1
damage: 0
reserved: 0 blank: 0 incremental: 0
nwa valid: 0
rzone start: 0
next wr addr: 0
free blocks: 0
blocking factor: 16
rzone size: 2273216
last recorded addr: 2273215
WARNING: Phys disk size 2273216 differs from rzone size 0! Prerecorded disk?
WARNING: Phys start: 196608 Phys end 2469823
Old 10th October 2002, 21:41   #5  |  Link
alexnoe
Banned
alexnoe's Avatar
ADVDInfo suddenly works for me. Have done nothing but changing mainboard+cpu and doing a repair installtions...
Old 10th October 2002, 21:47   #6  |  Link
trekkerj
This is what I get. What does it mean? I don't see "manufacturer"
Unlocked features:
Limited features:
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'MATSHITA'
Identifikation : 'DVD-RAM LF-D310 '
Revision : 'A126'
Supported modes: TAO SAO
minimum rate: Not specified (15)
number of layers:0
phys start: 196608
phys end: 196608
end layer 0: 0
bca: 0
phys size:... 1
copyr prot type: 0
region mgt info: 0
rzone number: 1
border number: 1
damage: 0
reserved: 0 blank: 1 incremental: 0
nwa valid: 0
rzone start: 0
next wr addr: 0
free blocks: 2298496
blocking factor: 16
rzone size: 0
last recorded addr: 0
WARNING: Phys disk size 1 differs from rzone size 2298496! Prerecorded disk?
WARNING: Phys start: 196608 Phys end 196608
Old 10th October 2002, 22:18   #7  |  Link
alexnoe
Banned
alexnoe's Avatar
Maybe your drive doesn't support reading of manufacturer Did you really insert a dvd-r, or was it a dvd-ram?
Old 10th October 2002, 22:42   #8  |  Link
trekkerj
It was a blank DVD-R. Maybe you're right. Is that possible? Any else have a Panasonic?
Old 10th October 2002, 22:44   #9  |  Link
alexnoe
Banned
alexnoe's Avatar
I'll ask the author or cdrecord if this is possible...
OK, he says that it's possible that some drives might not support reading of manufacturer info.
Old 14th November 2002, 04:48   #10  |  Link
Reggatta Mondatta
hp dvd200e
Nero shows the device at scsibus 4, target 0.
'cdrecord-prodvd' lists a disk drive at that location.
Is this an artifact of a using a 'firewire' connection?
RM
Reggatta Mondatta is offline   Reply With Quote
Old 14th November 2002, 05:42   #11  |  Link
alexnoe
Banned
alexnoe's Avatar
Maybe...
Old 14th November 2002, 20:17   #12  |  Link
LIGHTNING UK!
Author of ImgBurn
Just to let you know, the new version of DVD Decrypter (3.1.4.0) also displays this information when in ISO modes.
The Official ImgBurn Website
LIGHTNING UK! is offline   Reply With Quote
Old 14th November 2002, 22:29   #13  |  Link
Reggatta Mondatta
I do not see that version (3.1.4.0) on your site. Is it available?
OBW, great tool and I will be making a donation to support your work.
Best regards,
RM
Old 16th November 2002, 20:46   #14  |  Link
LIGHTNING UK!
Author of ImgBurn
It will be out this weekend - if I get a chance!
