Old 24th August 2002, 12:26   #1  |  Link
johann.Langhofer
Avisynth-Monitor
Hello,
I've written a small extension to monitor an avs-stream. You can download for free, see links below.
Short description of the usage:
Loadplugin ("avsmon.dll")
{your script here}
MonitorFilter
What is the advantage of this Filter:
- You can prview the video (ie. during cce-conversion)
- You can determine an exact audio delay
Best regards,
johann.langhofer@nextra.at
avsmon.dll
johann.Langhofer is offline   Reply With Quote
Old 24th August 2002, 15:24   #2  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Really cool - especially the audio-delay is excellent for me!
I do have some problems:
clip=avisource("D:\SH0DAN\MPG\Ice Age.avi").converttoyuy2()
bc=blankclip(1000000,70,32).killaudio().converttoyuy2().ShowFrameNumber().greyscale()
MonitorFilter(clip)
layer(clip,bc,"add",200,10,0)
Does not show any picture, but
MonitorFilter(clip)
works ok.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 24th August 2002, 15:43   #3  |  Link
johann.Langhofer
At the moment I've no idea where the problem could be, but I'll try to fix it..
Best regards
Old 24th August 2002, 16:45   #4  |  Link
sh0dan
sh0dan's Avatar
No hurry - it already rocks! It would just be great to be able to preview intermediate stages of the filters.
This gives me all new perspectives on an Avisynth GUI. I should really try to do a design-proposal, if I had the time.
Another nice-to-have would be some info like resolution, colorspace, framerate, samplerate, sample depth, channels.
Also a slide for "second-offset" for audio could be useful, especially with the compressed audio support, which has huge sync-problems when skipping in VBR mp3-material.
... I could go on - you really shouldn't listen to me!
Old 24th August 2002, 17:11   #5  |  Link
Koepi
Koepi's Avatar
I think that filter rocks, too! I'm reencoding the matrix with it, just to see it work
(Ok, I'm using more aggressive convolution3d settings than in my last test, too ).
I noticed that if you search backwards, the image doesn't get updated... only if you advance above the point where you've already been. Bug or feature?
Best regards,
and thanks for this nice dll
Koepi
Koepi is offline   Reply With Quote
Old 24th August 2002, 21:28   #6  |  Link
WarpEnterprises
C64
WarpEnterprises's Avatar
Maybe silly question, but how do you get the GUI to show up?
(or doesn't it work on win98).
WarpEnterprises is offline   Reply With Quote
Old 24th August 2002, 21:32   #7  |  Link
sh0dan
sh0dan's Avatar
... it just shows up (XP here)
Old 24th August 2002, 21:34   #8  |  Link
johann.Langhofer
thanks for all the suggestions, I'll see what I can do...
for the actual problem:
MonitorFilter(clip)
I think although I'm not so very familar with scripting the MonitorFilter is an I/O filter that means you must (re)assign the variable you use for the clip. I've tested following versions without problems:
version 1:
clip=avisource("D:\SH0DAN\MPG\Ice Age.avi").converttoyuy2().MonitorFiler
version 2:
clip=MonitorFilter(clip)
version 3:
MonitorFilter(clip)
layer(last,bc,"add",200,10,0)
Old 24th August 2002, 23:59   #9  |  Link
Belgabor
VDubMod Devel
Belgabor's Avatar
Well, i think its quite logical it shows no picture, as in sh0dans script its kinda a dead end. I imagine avisynth to be operated-by-draw-at-the-end-of-the-chain, and in that example nothing draws at the MonitorFilter. (Well, this is prolly what johann meant by stating its an i/o filter)
Cheers
Belgabor
Belgabor is offline   Reply With Quote
Old 25th August 2002, 10:53   #10  |  Link
iago
retired
iago's Avatar
@Koepi
Maybe the wrong thread to ask that, but since you mentioned it here, what convolution3d settings are you trying with Matrix? (I'm also considering to test convolution3d again, using MPEG quantizers and no lumi in both passes, maybe sharp bicubic, with Fight Club aiming for 1CD.)
thanks and best regards ,
iago
iago is offline   Reply With Quote
Old 25th August 2002, 18:34   #11  |  Link
theReal
Piper at theGates of Dawn
theReal's Avatar
Very cool !!! Thanks !! Avisynth only needed a preview to be perfect
"Under a government which imprisons unjustly, the true place for a just man is also a prison"
Henry David Thoreau, On the duty of civil disobedience, 1849
theReal is offline   Reply With Quote
Old 25th August 2002, 19:07   #12  |  Link
johann.Langhofer
thx,
an extended version is now ready for testing...
- more statistics
- histogram switch (works for yuy2 only)
avsmon_vers10a
screendump
Old 25th August 2002, 20:21   #13  |  Link
theReal
theReal's Avatar
one question: what is the audio delay switch for?
Old 26th August 2002, 07:33   #14  |  Link
soulfx
The Digital Soul
soulfx's Avatar
Sw337! This is really cool, awesome work johann.Langhofer.
The Histogram is a nice addition, it seems hard to read, but that's the way AviSynth's default histogram is.
One concern I had/have is effects of this monitor on framerate. I did some tests and what I can tell there really isn't any affect on framerate. Yay.
Peace,
SoulFX
soulfx is offline   Reply With Quote
Old 26th August 2002, 07:44   #15  |  Link
@johann.Langhofer
Well, what is the verdict on Win98? At least two of us don't get any GUI. Are you blowing off Win98 users?
Old 26th August 2002, 10:26   #16  |  Link
johann.Langhofer
To Neuron2: It's not the intention to blow off win98 users
If you can't get any GUI, the reason could be that I've used an api (CreateThread) on which the last argument must not be NULL for Win95/98/Me, but on NT/2000/XP it can be (just found from professor Google).
Sorry, I'll fix that as soon as possible, unfortenatly I'm at work now, so the earliest time to fix is the coming weekend.
To soulfx: I can't believe about the framerate, I've also done tests and was satisfied. The framerate is determined by counting the GetFrame()-calls inbetween a second measured with the multimedia-timer ??!
Best regards,
Johann Langhofer
Old 26th August 2002, 13:37   #17  |  Link
@Johann
Thank you. We will look forward to the Win98 compatible version!
Old 26th August 2002, 14:09   #18  |  Link
@Defiler
Nice move, Defiler. Make enemies of the people that help you.
Old 26th August 2002, 16:02   #19  |  Link
vidiot
Just wanted to say:
Glad Im not the last WIN98SE User in the world...
And Im sure: Less Problems (except Fat32) and more power with the same system than NT or ME or...
(...more bang for the buck...)
BTW: for the price of a nice Win XP Version I could easily buy an DVD Burner - is that an option?
Harald
vidiot is offline   Reply With Quote
Old 26th August 2002, 17:39   #20  |  Link
@Defiler
Please do not hijack this valuable thread with off-topic trolls. Otherwise, I'll have to resort to sanctions. Thank you.
