Old 24th August 2002, 05:28   #1  |  Link
Snilly
BeSweet Mono or no Mono?
Hi all,
After searching through the forum for an answer to my question I am still unclear as to a solution.
I am trying to create a mono lame mp3 using BeSweet. The source is a mono AC3 file. Everytime I try an encode I end up with a joint stereo mp3 which is not what I want. Others have had this problem but what I am uncertain of is this a limitation with BeSweet (ie mono just is not supported), or is it a bug in Lame?
Thanks
Snilly
Snilly is offline   Reply With Quote
Old 24th August 2002, 12:04   #2  |  Link
Snilly
Well,
Based on some testing I've done I have to conclude that BeSweet does not recognize lame mono command line switches. In short the culprit is BeSweet.
DSPguru, any plans to support mono going forward?
Snilly
Old 25th August 2002, 15:32   #3  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
yes.
DSPguru is offline   Reply With Quote
Old 17th September 2002, 20:26   #4  |  Link
tom758
Mono encoding?
perhaps you can integrate the possibility that BeSweet can encode mono files and the result is mono, too (I know the solution with Monoto2Stereo Plugin, but I need a mono file as result).
tom
tom758 is offline   Reply With Quote
Old 18th September 2002, 17:37   #5  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
features list of BeSweet v1.4 is closed. built-in mono support will be probably introduced in v1.5.
Old 23rd January 2003, 21:02   #6  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
v.15b12
current status :
1. native support for mono inputs (wav/ac3/MPx).
2. support for mono mp2/mp3 outputs.
Old 29th January 2003, 05:31   #7  |  Link
wmansir
wmansir's Avatar
Besweet mono encoding error
I'm trying to encode a mono wav file to mono mp2. The resulting file sounds like it is double speed, but also has a pulsating stutter making it unintelligable.
The source is stereo AC3 converted with BeSweet to a 44.1khz stereo wav file. Then using AviSynth and Vdub it is edited and converted to a mono wave file. It is this file (wav, 44.1khz, 1ch, 16bit) that I am attempting to encode to 48kbps mono MP2.
Here is a copy of the log. Although the log says the duration is 1:45:14.477, the actual length is half that (~52 min). 2lame can encode the file, but I find it occationally stalls on encodes, so I would like to replace it.
BeSweet v1.5b13 by DSPguru.
Using MP2enc.dll v1.129 (23/5/2002), Engine 1.129 <http://www.cdex.n3.net>.
Logging start : 01/28/03 , 23:02:18.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\drugstore\drug2_com.wav -output f:\drugstore\drug2_com.mp2 -logfile e:\BeSweet.log ) -2lame( -m m -b 48 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : e:\drugstore\drug2_com.wav
[00:00:00:000] | Output: f:\drugstore\drug2_com.mp2
[00:00:00:000] | Floating-Point Process: Yes
[00:00:00:000] | Source Sample-Rate: 44.1KHz
[00:00:00:000] +------- MP2ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | MP2 bitrate : 48
[00:00:00:000] | Channels Mode : Mono
[00:00:00:000] | Error Protection: No
[00:00:00:000] +---------------------
[01:45:14:477] Conversion Completed !
[01:45:14:477] Actual Avg. Bitrate : 23kbps
[00:01:06:000] <-- Transcoding Duration
Logging ends : 01/28/03 , 23:03:24.
wmansir is offline   Reply With Quote
Old 29th January 2003, 08:10   #8  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
would you mind trying transcoding directly the ac3 into mono mp2 ?
(don't forget to include your logfile)
Old 30th January 2003, 08:01   #9  |  Link
wmansir
wmansir's Avatar
No problem. I used the original AC3, but using the same method as above I haven't gotten a mono wav->mono mp2 encode to work with any file I have tried.
I included the 44.1 khz downmix for this job.
Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu).
Using Shibatch.dll v0.24 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Logging start : 01/30/03 , 01:25:37.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\drugstore\VTS_02_1 - 0x81 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY -66ms.ac3 -output e:\navarone\whole.mp2 -logfile C:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet.log ) -azid( -s surround2 -c normal -L -3db ) -ssrc( --rate 44100 ) -2lame( -m m -b 48 )
[00:00:00:000] | Input : e:\drugstore\VTS_02_1 - 0x81 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY -66ms.ac3
[00:00:00:000] | Output: e:\navarone\whole.mp2
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Input Channels Mode: 2/0, Bitrate: 192kbps
[00:00:00:000] | Output Stereo mode: Dolby surround compatible
[00:00:00:000] | Total Gain: 0.000dB, Compression: Normal
[00:00:00:000] | LFE levels: To LR -3.0dB, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] +------ Shibatch -----
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] | Dest. Sample-Rate: 44.1KHz
[00:00:00:000] | Attenuation : 0.0db
[01:41:25:568] Conversion Completed !
[01:41:25:568] Actual Avg. Bitrate : 23kbps
[00:09:31:000] <-- Transcoding Duration
Logging ends : 01/30/03 , 01:35:08.
The resulting file was double speed with a duration of 50:42. Even though it was double speed it did not have the the pulsating distortion present in the previous wav->mp2 job.
Ah ha. I ran a second encode, direct from the stereo AC3 -> mono mp2, only this time I didn't downsample to 44.1khz and the resulting file was perfect. Here is the log:
Logging start : 01/30/03 , 01:41:05.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\drugstore\VTS_02_1 - 0x81 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY -66ms.ac3 -output e:\navarone\whole.mp2 -logfile C:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet.log ) -azid( -s surround2 -c normal -L -3db ) -2lame( -m m -b 48 )
[01:41:25:568] Actual Avg. Bitrate : 48kbps
[00:04:55:000] <-- Transcoding Duration
Logging ends : 01/30/03 , 01:46:00.
I'll try with again with a 48khz mono wav file and post the results in a little bit.
Old 30th January 2003, 09:07   #10  |  Link
wmansir
wmansir's Avatar
I tried a 48khz mono wav file to mono mp2. The results were bad, with the same stuttering pulsating distortion. And while the voices were high pitched, it didn't appear to be at double speed. Here's the log, note that it's a different source file than the previous test, but it was a simialar source, processed the same with the exception of the downsampling, and is approximatly the same length as the other file at just around 52 minutes.
Logging start : 01/30/03 , 02:57:33.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input f:\navarone\navarone1_com.wav -output e:\navarone\navarone1_com.mp2 -logfile C:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet.log ) -2lame( -m m -b 48 )
[00:00:00:000] | Input : f:\navarone\navarone1_com.wav
[00:00:00:000] | Output: e:\navarone\navarone1_com.mp2
[01:42:50:949] Conversion Completed !
[01:42:50:949] Actual Avg. Bitrate : 24kbps
[00:01:13:000] <-- Transcoding Duration
Logging ends : 01/30/03 , 02:58:46.
Old 8th February 2003, 14:15   #11  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
retry with beta15.
Old 9th February 2003, 15:44   #12  |  Link
wmansir
wmansir's Avatar
I don't have the orignal source files, this file is of the same type and is processed the same as those previously. The duration is just under 45 minutes.
First I tried my normal 44.1khz mono wave. The results were like like the 48khz wav last time. It wasn't double speed, but still had the stuttering distortion and voices were very high pitched. Again, the log shows twice the duration and around half the bitrate.
Log (source: 44.1khz mono wave) :
BeSweet v1.5b15 by DSPguru.
Logging start : 02/09/03 , 09:03:11.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\buffy3\ep1.wav -output f:\buffy3\ep1.mp2 -logfile e:\BeSweet.log ) -2lame( -m m -b 48 )
[00:00:00:000] | Input : e:\buffy3\ep1.wav
[00:00:00:000] | Output: f:\buffy3\ep1.mp2
[01:29:49:637] Conversion Completed !
[01:29:49:637] Actual Avg. Bitrate : 23kbps
[00:00:59:000] <-- Transcoding Duration
Logging ends : 02/09/03 , 09:04:10.
Next I tried the same file without the downmix when transcoding from ac3 to wav. So the source is now a 48khz mono wav. The results were the same as the 44.1khz wav. stuttering distortion, high pitched voices, but at the correct playback speed. Again, the log shows it as twice the durtation and half the actual bitrate.
Log (source: 48Khz mono wav):
Logging start : 02/09/03 , 09:14:22.
[01:29:49:174] Conversion Completed !
[01:29:49:174] Actual Avg. Bitrate : 24kbps
[00:01:02:000] <-- Transcoding Duration
Logging ends : 02/09/03 , 09:15:24.
The next encode is direct from AC3 to mono mp2 with 44.1khz downmix. This appears to be fixed from the last beta as the result was perfect.
Log (Source: AC3 2chan w/Downmix):
Logging start : 02/09/03 , 09:22:57.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\buffy3\ep1\VTS_03_1 - 0x80 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY 0ms.ac3 -output f:\buffy3\ep1.mp2 -logfile e:\BeSweet.log ) -azid( -s surround2 -c normal -L -3db ) -ssrc( --rate 44100 ) -2lame( -m m -b 48 )
[00:00:00:000] | Input : e:\buffy3\ep1\VTS_03_1 - 0x80 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY 0ms.ac3
[00:44:54:656] Conversion Completed !
[00:44:54:656] Actual Avg. Bitrate : 48kbps
[00:06:52:000] <-- Transcoding Duration
Logging ends : 02/09/03 , 09:29:49.
Next, the same test without the downmix. This worked last time, and still worked perfect.
Log (source: AC3 2chan):
Logging start : 02/09/03 , 09:33:29.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input e:\buffy3\ep1\VTS_03_1 - 0x80 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY 0ms.ac3 -output f:\buffy3\ep1.mp2 -logfile e:\BeSweet.log ) -azid( -s surround2 -c normal -L -3db ) -2lame( -m m -b 48 )
[00:02:02:000] <-- Transcoding Duration
Logging ends : 02/09/03 , 09:35:31.
As a last test I'm trying something I haven't tried before, a regular stereo wav file (48khz, since sample rate didn't affect any previous test I won't bother with 44.1khz). This worked perfect.
Log (source: 48khz stereo wav):
Logging start : 02/09/03 , 09:38:11.
c:\easyenc\program shortcuts\BeSweetGUIv0.5\BeSweet\BeSweet.exe -core( -input f:\buffy3\ep1.wav -output f:\buffy3\ep1.mp2 -logfile e:\BeSweet.log ) -2lame( -m m -b 48 )
[00:00:00:000] | Input : f:\buffy3\ep1.wav
[00:01:04:000] <-- Transcoding Duration
Logging ends : 02/09/03 , 09:39:15.
So it seems the problem is with mono wav input or perhaps any mono input, I don't have a 1-chan AC3 to test right now, at least I don't think I do, I'll have to check my dvds. I hope this helped, and thank you for your work.
Edit: Actually I think Azid decodes (or can decode) 1 chan AC3 to stereo anyway, so it probably doesn't affect 1chan AC3 with the correct settings.
Old 11th February 2003, 06:18   #13  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
i guess there's still a problem with mono wave input.
thank you for all the useful logfiles !!
Old 11th February 2003, 22:58   #14  |  Link
kikounet
Indeed there is a problem with mono !
I recorded Cartoon Network directly from satellite (Hauppauge Nexus-s) and theese toons are broadcasted with monoraul MPEG-2 audio.
I need to convert to 44,1 KHz to do VideoCD for my child. And I get the same hard to describe horribly distorded sound. So for now I use SoundForge 6 to treat the *.mpa file (Splitted with Dvd2avi).
But it's a pity, cause I love BeSweet for all other stereo broadcasts !
You'll make it, my Guru !
kikounet is offline   Reply With Quote
Old 11th February 2003, 23:02   #15  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
@kikounet
were you using the latest beta ?
please post your logfile.
Old 11th February 2003, 23:53   #16  |  Link
kikounet
Here is a new log, made with beta 15, with same result :
Using hip.dll v1.18 by Myers Carpenter <myers@users.sf.net>
Logging start : 02/11/03 , 23:41:13.
C:\Program Files\BeSweet\BeSweet.exe -core( -input f:\Captures\Tom&Jerry1 MPA T01 DELAY -54ms.mpa -output f:\Captures\Tom&Jerry1 MPA T01 DELAY -54ms-New.wav -2ch -logfilea C:\Program Files\BeSweet\BeSweet.log ) -ota( -d -54 )
[00:00:00:000] | Input : f:\Captures\Tom&Jerry1 MPA T01 DELAY -54ms.mpa
[00:00:00:000] | Output: f:\Captures\Tom&Jerry1 MPA T01 DELAY -54ms-New.wav
[00:00:00:000] | Floating-Point Process: No
[00:00:00:-54] | Source Sample-Rate: 48.0KHz
[00:00:00:-54] +---------------------
[00:05:59:010] Conversion Completed !
[00:05:59:010] Actual Avg. Bitrate : 1535kbps
[00:00:09:000] <-- Transcoding Duration
Logging ends : 02/11/03 , 23:41:22.
I uploaded the MPA test file (5,7MB) on http://dirinfo13.free.fr/bin/Tom&Jer...DELAY-54ms.rar
Regards
Old 14th February 2003, 12:00   #17  |  Link
kikounet
Sadly, there is still the same probleme with mono waves or mono MP2 as input... Did you try the sample I uploaded for you ?
Old 15th February 2003, 15:31   #18  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
@kikounet
i updated the b15 package.
please retry.
Old 16th February 2003, 00:19   #19  |  Link
kikounet
Thank you my Guru! Indeed it works now! So you had to change only the Hip.dll did you?
I'm not sure you really wants the log, but Guru only knows:
Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net>
Logging start : 02/16/03 , 00:04:51.
c:\Program Files\BeSweet\BeSweet.exe -core( -input e:\Documents and Settings\Utilisateur\Mes documents\Ma musique\Totale_Tom&Jerry5 MPA T01 DELAY -126ms.mpa -output e:\Documents and Settings\Utilisateur\Mes documents\Ma musique\Totale_Tom&Jerry5 MPA T01 DELAY -126ms.wav -2ch -logfilea c:\Program Files\BeSweet\BeSweet.log ) -ota( -d -126 ) -ssrc( --rate 44100 )
[00:00:00:000] | Input : e:\Documents and Settings\Utilisateur\Mes documents\Ma musique\Totale_Tom&Jerry5 MPA T01 DELAY -126ms.mpa
[00:00:00:000] | Output: e:\Documents and Settings\Utilisateur\Mes documents\Ma musique\Totale_Tom&Jerry5 MPA T01 DELAY -126ms.wav
[00:00:00:-125] +------ Shibatch -----
[00:00:00:-125] | Source Sample-Rate: 48.0KHz
[00:00:00:-125] | Dest. Sample-Rate: 44.1KHz
[00:00:00:-125] | Attenuation : 0.0db
[00:00:00:-125] +---------------------
[00:14:08:071] Conversion Completed !
[00:14:08:071] Actual Avg. Bitrate : 1411kbps
[00:03:33:000] <-- Transcoding Duration
Logging ends : 02/16/03 , 00:08:24.
The output is still Stereo though. I guess one has to ask Danni Din to add an option into the "Output" dropdown list...
Thanks again, and give peace a chance!
Old 16th February 2003, 04:21   #20  |  Link
airon911
Hi again
I'd like to know if Besweet can downmix from a stereo source, or pick a channel from a stereo source, to a mono output(MP3 usualy) ?
My primary use for this is archiving old cartoon tracks as well as commentary tracks.
Last I remembered, the mono switch didn't work so well for stereo input, but it's been a few months since I tried.
I'm curious if this has changed.
Take care
Tony
airon911 is offline   Reply With Quote
