19th August 2002, 06:50 | #1 | Link |
Yellow wavy lines
I'm not really sure which section this post belongs in, I apologize if this is off topic.. I have been trying to clean up an old Arnold Schwarzenegger clip that I have..for a few days now..without much luck. I have tried various combinations of SpatialSoftenMMX, TemporalSmoother, TemporalSoften, cnr2, sshiq, etc... They do an excellent job of reducing the noise (which ironically I don't really mind since its from the 70's), but there are these yellow wavy lines running through the entire movie that I cannot seem to get rid of, or even diminish somewhat. I realize garbage in = garbage out..maybe this source is beyond hope. This is the source: http://members.shaw.ca/cjv99/shot.jpg Any ideas would be greatly appreciated..thanks cjv |
19th August 2002, 08:20 | #2 | Link |
C64
Those lines come from some signal interference, you won't get rid of them, except maybe:
Have you (captured) then full size (576 lines) movie, too? Since the two interlace fields are shifted in time it could be possible to do a strong temporal chroma smooth or such. If you have the fullsize post it. |
19th August 2002, 08:58 | #3 | Link |
Thanks for checking it out,
Unfortunately I didn't capture this. I've had it for a while time, but just recently got a standalone and I'm in the process of converting to VCD (eventually)..but wanted to clean it up somewhat first..the orig. res is 384x288 div4. I tried something like this: S=AVISource("mov-huff.avi").BicubicResize(640,480,0,0.65) TS=S.TemporalSmoother(3).MergeLuma(S) TS=TS.cnr2().TemporalSmoother(2,1).BilinearResize(384,288) return TS It helped somewhat..is my script way off, or is there anything else you might suggest? cjv |
19th August 2002, 15:15 | #6 | Link |
C64
...but I've found a VD-filter (that works with AVS) that seems to do that. The help is in some chinese/tai language, so I can't configure it correctly, but with AVS:
LoadVirtualDubPlugin("c:\programme\virtualdub\plugins\wNR.vdf","WNR",0) Avisource("c:\_video\problem.avi").converttoRGB32() wnr(0, 0, 0, 0, 0, 65280, 0, 0, 0) wnr(0, 0, 0, 0, 0, 65280, 0, 0, 0) wnr(0, 0, 0, 0, 0, 65280, 0, 0, 0) this is what it looks like: (attachement). |
19th August 2002, 19:15 | #8 | Link |
@WarpEnterprises:
Thank you SO much! I am SO grateful you took the time to help me out. If you only knew how much time I have spent on this clip! The results are simply amazing and I'm amazed how you figured out those parameters from the help file I have posted 2 original clips (huffy..3megs each): http://members.shaw.ca/cjv99/huffy-25frames-dark.avi http://members.shaw.ca/cjv99/huffy-25frames-light.avi in case you have any more ideas on how to clean up this crappy, crappy source (I plan on cropping of course)..or even care to spend any more time. I usually use crystal clean DVD sources..and this is my first attempt at actually trying to fix something. Regardless, you have helped me greatly..and I really appreciate it. cjv PS. I upsize because I was under the impression that temporal filters work better on larger sources..and then bilinear downsize in order to hopefully conceal any artifacts and help compression..although I could be totally off? |
19th August 2002, 20:38 | #9 | Link |
C64
I found the filter some time ago and considered it useless since I didn't understand the settings.
But with neuron2's hint I remembered this. Maybe the parameter can be more optimized, I will play a little and keep you informed (I hope tomorrow). IMHO do not enlarge to filter. It's sometimes good to filter before downsizing but artificially upsizing is not good. Also I think (at least for mpg compression and ONLY IF ITS NECESSARY) a good idea is to do: downsizing > temporal filtering > spatial filtering > sharpening or for a little more quality and much more cpu time temporal filtering > spatial filtering > downsizing > sharpening (sharpening for VCD res and xVCD-bitrates/VBR only) Edit: I think I've figured out what the VD-params are: Show selected plane: (debug) shows only the selected plane Mode: (debug) High-enhances the contrast Diff-shows the diff between original and filtered Thresholds: can be set for each plane (Luminance Y, two color channels Cr, Cb), for X- and Y-direction and 3 different frequencies (0,1,2) seperately. For your case the noise is low-freq in X-direction, therefore X2 must be set. And it seems to be only in one color channel. So you can try yourself (in VirtualDub!) by setting mode to diff and then trying different values in the Cr/Cb X2 settings. To get those settings to AVS: press ctrl-s in VD and look in the vcf-file at the line: VirtualDub.video.filters.Add("wavelet noise reduction (0.1)"); VirtualDub.video.filters.instance[0].Config(0, 0, 0, 255, 255, 255, 255, 255, 255); Those numbers are what you need for avisynth. 2nd Edit: After looking to your videos try this VirtualDub-Settings (make a .vcf-file and load it with ctrl-l): VirtualDub.video.filters.Clear(); VirtualDub.video.filters.Add("wavelet noise reduction (0.1)"); VirtualDub.video.filters.instance[0].Config(16448, 8224, 8224, 0, 4096, 65280, 0, 0, 0); VirtualDub.video.filters.Add("wavelet noise reduction (0.1)"); VirtualDub.video.filters.instance[1].Config(16448, 8224, 8224, 0, 4096, 65280, 0, 0, 0); VirtualDub.video.filters.Add("warp sharp (1.1)"); VirtualDub.video.filters.instance[2].Config(102); This fiters the 1-pixel-noise together with the yellow stripes. You need the WarpSharp filter from DonaldGraft/AveryLee, which seems quite good suited for your clip (normally it's for cartoons, but in your case it helps to sharpen although there is much of this 1-pixel-noise). Enjoy VirtualDub & Avisynth. Last edited by WarpEnterprises; 19th August 2002 at 22:49. |
20th August 2002, 04:53 | #11 | Link |
Wow, the improvement on the walls/flat areas is unbelievable. I implemented your settings, a very light temporal smoother, resized, then applied a really cool sharpening filter..xsharpen.
I tried playing with warpsharp earlier, but that was with the yellow lines still there..you can imagine it wasn't pretty..but the way you have looks good to me. Currently its encoding at 2-3 fps, using XviD MPEG quant..with a little bit of noise added postproc with ffdshow..it looks sweet! (VCD is next) Garbage in does not always equal garbage out Oh yea, the wavlet filter seems unstable on my Tbird, lots of crashes with illegal opcode, but works fine on my P4...hmmm...must be some SSE2 in there. Thanks again, cjv |
20th August 2002, 13:12 | #13 | Link |
C64
Just tried the filter on macroblock removal. It does a really incredible job!
The parameters 0,1,2 correspond to pixel wavelengths of 8-16, 16-32, 32-64 That means it is sensitive on "waves" whith that pixel distance from top to top and will perform a notch filter on these. The GUI has a little bug which doesn't let you enter the numbers directly. The effects are quite mild, the thresholds can hardly be made to large. Btw. I found the site I downloaded it some time ago: http://members.tripod.co.jp/thejam79/index.html |
20th August 2002, 15:17 | #14 | Link |
Asker of Questions
This filter is awesome. It really puts a hurting on color bleeding, in its most aggressive mode.
The preview window is great too.
"The real trick to optimizing color space conversions is of course to not do them." --trbarry, April 2002 |
20th August 2002, 17:33 | #15 | Link | |
here a translation
i haven't tested it, but i have a translation of the readme ....
Big Thanks to blueskyfloating from Ishin-Digital for his help ^^ enjoy Quote:
hmm sorry for the spelling mistake, that has been translated in hurry ^^;; Last edited by bill_baroud; 20th August 2002 at 17:35. |
20th August 2002, 18:06 | #16 | Link |
VDubMod Devel
It didnt go as well as I hoped and I had to recriut a japanese speaking frind of mine to help (thanks again Klepto ) and still couldn't figure out all and finally it doesnt help very much, but here you go:
wavelet noise reduction (wnr 0.1) : thejam This is a wavelet noise reduction filter. Requires: - CPU with MMX and SSE - Height and width must be multiples of 8. To install: - Copy wnr.vdf to the Virtualdub plugins directory To uninstall - Delete wnr.vdf Explanation: filter enable Turn the filter on and off. MODE Operation mode of the filter. Normal: Normal mode High: Emphasis on the high frequency component (which includes mainly noise and contours) Diff: This will show the diffrence in pictures before and after you use the filter. Threshold Select the plane with Y Cb Cr Threshold values are set with the sliders. X is horizontal, Y is vertical, and there are 3 levels respectively Show Preview Shows the preview. Method of Adjustment: While looking at the preview picture, please set threshold value to the high frequency indicatory mode. How to use it with Avisynth Adjust the settings with Virtualdub Use "save processing settings" to create a .vcf file Put the following into the avs script: LoadPlugin("your path\wnr.vdf") WNR("~.vcf") Interlaced material Interlaced material is no problem if you have no noise in Y direction (Y0-Y2 thresholds set to zero). (Couldn't make sense of this sentence, but I think it means something like: ) Otherwise you run into trouble. If you want to process the noise on field level, put a deinterlace filter before and after this one like shown below: deinterlace (mode:unfold) wavelet noise reduction deinterlace (mode:fold) If you have trouble with a too low processing speed Setting Thresholds to 0 can gain a little speed. (There's more in this sentence, but i think thats the essence) Usually its enough to set X0,Y0,X1 and Y1 in the luminance plane (Y). Disclaimer: I'm a picture specialist, no mathematician or programmer, so there might be some errors or fatal bugs. Thank you in advance. Cheers Belgabor Last edited by Belgabor; 20th August 2002 at 18:13. |
20th August 2002, 19:33 | #18 | Link |
VDubMod Devel
well, i think a combination of both would make a quite good one =D Other thing, the filter wont work for me Hitting 'Preview' kills vdub and seeking with it enabled gives me a "Internal error: MMX state left on T:\projects\virtualdub_old\main\VideoSource.cpp:1101" Anyone else with a Athlon 1400 who has the same prob/whom it works for? Belgabor |
20th August 2002, 20:17 | #19 | Link |
C64
MMX-error: is your video a DIVX? If yes see http://virtualdub.org/virtualdub_kb
And is the resolution a multiple of 8? For docu: I'm going to condense your translations into one, add some thing I've found and post it. Thanks! |
20th August 2002, 20:31 | #20 | Link |
Asker of Questions
Belgabor: If that's a Thunderbird CPU, it doesn't have SSE, and thus cannot run this filter. You'll need a Morgan/Palomino/Thoroughbred.
Thanks for the translations, guys. It's awesome that this filter can run saved .vcf settings from inside AviSynth.
