Old 12th August 2002, 03:59   #1  |  Link
DoC hEx
2 VB R !2 VB Dat is D Q?
DoC hEx's Avatar
A short movie in DVD format to a CD???
This might be a stupid question... but... Is it possible to take a shot movie (I have a short animation I created) that I want to play at DVD quality from an ordinary CD??? I want to make it compatible with all DVD players. I know about VideoCD, and Super VCD. But I really want DVD menus and stuff.
Any help would be great!
DoC hEx
DoC hEx is offline   Reply With Quote
Old 12th August 2002, 13:16   #2  |  Link
auenf
avatar doesn't support IE
auenf's Avatar
miniDVD/cDVD/DVDonCD(TM) work on aprox 1% of all standalone dvd players cause (quoting loosely from the dvd faq) "by the time a standalone gets to looking for a CD, its given up looking for DVD content"
the closest your going to get is SVCD (you would only be able to use SVCD bitrates on miniDVD anyway) or make a miniDVD, just almost everyone will have to watch it on their computers.
Enf...
auenf is offline   Reply With Quote
Old 12th August 2002, 15:39   #3  |  Link
DoC hEx
DoC hEx's Avatar
Thanks!
Old 13th August 2002, 22:08   #4  |  Link
Arky
Each of the following links contains a little information on issues relevant to writing DVD content on CDRs, along with other general points. Perhaps (hopefully!) you'll find a sentence or two of useful info:
http://forum.doom9.org/showthread.ph...ional+velocity
http://forum.doom9.org/showthread.ph...567#post132567
Regards,
Arky ;o)
Arky is offline   Reply With Quote
