Old 11th August 2002, 11:13   #1  |  Link
GZZ
Big Bug in Vobinput.dll
I have found that the patial Encoding don't work together with vobinput.dll. If I set the start to 0 and end to 10 sec and press the 'vob to mp2' button it crash. But if I turn Patial Encoding of, then it works fine. So vobinput DON'T work together with patial encoding.
I don't have any log file. Because Besweet only manage to make an empty log file before it crash. :/
I hope you can fix this DSPguru.
GZZ
GZZ is offline   Reply With Quote
Old 11th August 2002, 17:36   #2  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
Re: Big Bug in Vobinput.dll
correct, i never thought of supporting this combination..
i'll think about it.
Dg.
DSPguru is offline   Reply With Quote
Old 11th August 2002, 20:40   #3  |  Link
GZZ
please support it DSPguru and thanks for the best audio encoding program on the net.
Old 19th September 2002, 09:40   #4  |  Link
GZZ
Bug or maybe just missing in vobinput.dll
hey dspguru.
I bougth this up a few month ago and I have seen that you have releases a few update on vobinput.dll since then. But you never fixed my suggestion/bug.
so here it comes again, just so you don't forget it.
GZZ
Old 20th September 2002, 11:28   #5  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
thanks GZZ. i didn't forget.
i will offer this feature as well, but not in the upcoming v1.4.
Old 19th December 2002, 13:34   #6  |  Link
RB
Retired
BeSweet bug with VOB input and -split ... ?
I've been trying to encode the first 30 seconds of audio in a VOB file to MP2 with BeSweet 1.5b9, here's the command line:
BeSweet -core( -input "E:\Audio\VTS_13_1.vob" -output "E:\Audio\VTS_13_1.MP2" -azid( -c light -L -3db --maximize ) -ssrc( --rate 44100 ) -2lame( -m s -b 192 -e ) -split( -start 0 -end 30 )
However, this always encodes the first 30 minutes rather than seconds, no matter what I do. So I demuxed the complete AC3 stream from the VOB, encoded from AC3 and -split worked as expected. Is this a bug or am I missing something?
Thanks!
RB is offline   Reply With Quote
Old 3rd January 2003, 13:38   #7  |  Link
RB
Retired
Just bumping this up in hopes for a reply from Guru BTW, tried with 1.5b11 and same problem.
Old 28th January 2004, 09:55   #8  |  Link
tie
Split with BS v1.5b25
Hi everyone!
I also tried to encode a VOB-Input and split the file.
I used BeSweet v1.5b25
This just ignored the split command!!
It encodet the entire VOB-File instead of just a few minutes!
Are you still working on it??
It would be nice if you can fix it.....
Thanks in advance!
Greets,
Tie
tie is offline   Reply With Quote
