Old 2nd August 2002, 12:28   #1  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Avisynth 2 CVS binaries
I've done a page for downloading the newest CVS binaries, for those eager to try them out:
Avisynth 2 CVS snapshot binaries
I'll keep it updated.
If anyone has objections to this, just PM or mail me, and I'll take it down.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 2nd August 2002, 12:32   #2  |  Link
Wilbert
Thanks! Are MergeChroma and Layer working again? In the changelog you didn't mention AssumeTFF() and AssumeBFF().
Old 2nd August 2002, 12:36   #3  |  Link
sh0dan
sh0dan's Avatar
Both are working (hopefully!) - dividee fixed layer, and I fixed mergechroma/luma, so you should be ready to rock
AssumeTFF() and AssumeBFF() are in the build, but I haven't tested them myself. (Adding them to history)
Old 2nd August 2002, 13:50   #4  |  Link
ARDA
Thank you very much.I will not have to fight every change to compile
I am newbie for ever.By the way I've post in page 2 of http://sourceforge.net/projects/avisynth2 a small problem I've had with resample.cpp to be able to compile with last comits.
ARDA is offline   Reply With Quote
Old 2nd August 2002, 14:17   #5  |  Link
sh0dan
sh0dan's Avatar
Have you done a Rebuild All? What's your build setup?
Check out you got the newest transform.c and transform.h, the Crop parameter was changed in (transform.h version 1.1, 2002/07/04 13:23:04) to include env.
Old 2nd August 2002, 14:44   #6  |  Link
ARDA
I am really sorry I hadn't update trasnform.h and cpp.
Please forgive this newbie mistake.
Thanks again all of you four your great work
Arda
Old 2nd August 2002, 15:19   #7  |  Link
sh0dan
sh0dan's Avatar
No problem mate - we've all done that one time or another
Old 2nd August 2002, 17:10   #8  |  Link
sh0dan
sh0dan's Avatar
Just updated:
- New function ConvertToMono(clip) - convert stereo to mono.
- New function KillAudio(clip) removes audio from clip. Use this if you get crashes with compressed AVI sound.
- Added sound to Loop() function.
Down'em if you need'em.
Old 2nd August 2002, 22:46   #9  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
I've given you rights to release files via SourceForge. That brings the total to 4 people (me, Koepi, dividee, you) so hopefully we can keep the binaries there more up to date now.
Richard Berg is offline   Reply With Quote
Old 2nd August 2002, 23:31   #10  |  Link
MoonWalker
Just A Walker
MoonWalker's Avatar
Is there a prog tha can download all the files of a cvs and if you have them update only the new ones??
Thanks,
MoonWalker
MoonWalker is offline   Reply With Quote
Old 2nd August 2002, 23:47   #11  |  Link
dividee
@Richard:
I didn't even knew I had this right! Must have missed it somewhere.
@Moonwalker:
Yes of course there are such progs; how do you think developer works ? The most widely used CVS client seems to be WinCVS, for my part I use Tortoise CVS. Be warned these programs are usually a pain to set up.
dividee
dividee is offline   Reply With Quote
Old 3rd August 2002, 04:12   #12  |  Link
trbarry
trbarry's Avatar
Good work guys.
@Richard - Could you add me to the project (as trbarry)?
- Tom
trbarry is offline   Reply With Quote
Old 3rd August 2002, 09:38   #13  |  Link
Richard Berg
developer wannabe
You've been on the list since the beginning, which should at least let you work with CVS. If that doesn't work or you need other rights, let me know.
Old 4th August 2002, 11:41   #14  |  Link
Marc FD
XviD fan
Marc FD's Avatar
if you could release binaries more often on sourceforge (with the source) it would be usefull. I've never used CVS so i'm always waiting for a new updated src. one update per week seems good.
Marc FD is offline   Reply With Quote
Old 4th August 2002, 11:53   #15  |  Link
Koepi
Koepi's Avatar
Uh! Nice to know
But I still don't get avisynth to compile (elsy I would've been playing around with it much more already ).
EDIT: dumb I am!
Finally found the switch wher the "full download" is selectable. now it's prime time *download*
Best regards,
Koepi
Koepi is offline   Reply With Quote
Old 5th August 2002, 07:52   #16  |  Link
sh0dan
sh0dan's Avatar
Once a week sounds reasonable, and we should make the source downloadable too - agree!
Just updated the page with aug. 5 binaries, new features include:
- GetLeftChannel - Returns left channel.
- GetRightChannel - Returns right channel.
- MonoToStereo(clip1_left,clip2_right) - muxes two clips together as one stereo clip.
- MixAudio(clip_1,clip_2,float clip1_volume, float clip2_volume) Mixes two audio sources together.
- Added ConvertBackToYUY2() That only uses chroma from the left pixel to avoid shifting chroma color by multiple YUY2->RGB>YUY2 conversions. ConvertToYUY2 remains unchanged.
- Added Documentation for new parameters
I'll try doing a seperate build with dividee's modified avisource. [EDIT: No - I wont - get it from the ACM thread].
I think we should wait until dividee has finished fixing avisource audio, until there'll be a new release.
The next release will probably be 2.10, due to the many new features.
Old 5th August 2002, 08:10   #17  |  Link
Richard Berg
developer wannabe
Could you (or Koepi or someone) also release the updated builds to SourceForge? Here's a shortcut to the page (it'll make you login first) -- just type in the version # and follow the instructions.
Old 5th August 2002, 09:12   #18  |  Link
sh0dan
sh0dan's Avatar
Yes - I'll do it, but as stated above, I think we should wait a little bit, and do a major release - with PR and everything
Hopefully I get some time for updating the documentation.
I've been thinking of a restructuring, so each filter gets its own html-file. I've not worked much with sourceforge doumentation, but my first impression is, that it would be a lot easier, if documentation was a part of the CVS tree - how does that sound?
Old 5th August 2002, 09:14   #19  |  Link
hakko504
Remember Rule One
hakko504's Avatar
... and don't release anything until you have settled the Decomb issue with Don Graft.
/hakko
http://www.boardgamegeek.com
hakko504 is offline   Reply With Quote
Old 5th August 2002, 09:15   #20  |  Link
sh0dan
sh0dan's Avatar
No - absolutely right!
