#1 | Link |
AutoRV10 Software !
i have modified my tool (autodub) to make a gui for the Realvideo 10.0 AutoRV10 is a tool to automate the RV10 Encoding. it support , 1Pass or 2Pass (both) can shutdown you computer calculate the bitrate needed, support .AC3, .MPA, .WAV and .PCM file input and start the audio encode process to create a stereo .WAV file (using besweet). Support .D2V as input file and create the Avisynth project file support for the crop/resize filter and some extra filter (for anime) like Warpshap, 2D Cleaner or SmarthSmoother, and some generic filter (Change color and noise reduction). support 2 audio streams. support external subtitles. create .smil file for launch subs and audio. can split the movie to the desired size and encode endcredits separately (quality % mode) Of course this tool work under Win9x/ME, Win2k, WinXP. www.video-tools.com (go in the download section) PS : v1.4 = AutoRV10 v1.0 FAQ LINK : (fullversion) http://benjapi.free.fr/autorv10/down...oRV10_v1.1.zip YV12 decompressor : http://benjapi.free.fr/autorv10/yuvcodecs_1.2.exe Guide Here : http://benjapi.free.fr/autorv10/auto...e/AutoRv10.htm changelog b8 : - use an accurate overhead calculation (accurate at 99.99 %). - rewrite a big part of the audio process. - improve compressibility test. (now give you the *best* suggested resolution) - handle correctly the HDTV file with a weird resolution (1920x1088 instead of 1080) - add ELA (Edge Line Average) when using upper-resize in the anamorphic mode - improve ColorMatrix() use (detect the need to apply a colorimetric filter) - improve the anamorphic formula - possibility to save image as .JPG from the preview window - auto detect insert/eject media CD. - add an fps limiter during the avs preview (crop window) - Improve chapter grabbing (encode text using ISO88-59) - possibility to use COOK instead of RACP for bitrate range 32kbps-96kbps (content patent for the HE-AAC codec use) - select beetween STEREO or SURROUND Matrix if the codec COOK is used for the bitrate 64kbps or 96kbps. - use an accurate overhead calculation (accurate at 99.99 %). - rewrite a big part of the audio process. - improve compressibility test. (now give you the *best* suggested resolution) - handle correctly the HDTV file with a weird resolution (1920x1088 instead of 1080) - add ELA (Edge Line Average) when using upper-resize in the anamorphic mode - improve ColorMatrix() use (detect the need to apply a colorimetric filter) - improve the anamorphic formula - possibility to save image as .JPG from the preview window - auto detect insert/eject media CD. - add an fps limiter during the avs preview (crop window) - Improve chapter grabbing (encode text using ISO88-59) - possibility to use COOK instead of RACP for bitrate range 32kbps-96kbps (content patent for the HE-AAC codec use) - select beetween STEREO or SURROUND Matrix if the codec COOK is used for the bitrate 64kbps or 96kbps. - fix few bugs. - clean,speedup of the code and memory optimisation. changelog b7 : - remove undot filter and now use removegrain. - you need to have the administrator rights to launch the application. - catch and display the "real producer" error messages. - added chroma mode decision option by default. - add the audio bitrate HE-AAC at 32 and 48 kbps - possibility to use an highter complexity (EHQ=65) during the first pass. - now the EHQ value by default is 85. - add an option to turn off the screen after 5 min of inactivity. - possibility to enter float value for the desired ouput size. changelog b6 : - allow to re use the first pass stat file - add EHQ and Anamorphic informations in the tag video - limit minimum monitor resolution at 800x600 to launch autorv10 - correct mpeg2 color conversion and chroma limiter by default - improve filter preset settings - add alternative curve scaling. - improve auto calc inloop cut off quantizer. - improve IFO parser (better detection of subtitle/audio stream ID). - improve preview speed during display. - allow audio preview if directshow filter is found. - remove the "streaming error" option - limit Avisynth Memory usage. - enable multithreads if Hyperthreading or MultiProcessor were detected - at start check if the CPU support MMX instruction (needed for avisynth) - display warning if CPU doesn't support iSSE instruction (needed for some filters). - check if the c++ 7.1 dll are installed (needed for producer) - check if there is a YV12 decompressor installed. - improve dynamic cleaning (high/medium/low motion). changelog b5 : - update dvd2avi and mpeg2dec3.dll with the latest v1.3.0 version. - added new avisynth filters and remove some olders. - get informations (bitrate/channels/frequency) on all the input file (.WAV/.MPA/.MP2/.DTS/.AC3) - add a Vobsub Subtitle Preview - add an online updater (check if u have the latest version) - detect interlaced field parity (for MPEG2 input) - Dynamic denoise cleanning - improve the Ripper Panel (support more than 1 dvd-drive). - fix all bug reported. changelog b4 : - panel ripping (using dvddecrypter). - possibility to extract chapters. - possibility to extract raw subtitles. - add chapters in rmvb header. - grab chapter name on the internet. - updated besweet / mpeg2dec3.dll / dvd2avi rc7. - support new format of .d2v file. - updating the menu icones. - fixed all the bug reported. changelog Autorv10 v 1.0 : - Add support for RV10 and Elysian features. - Fast first pass if u use EHQ. - Added EHQ profil for 75 / 85 / 100. - Replace ATRC audio codec by AAC and HE-AAC. - Add support for new RateControl. - Now use .RPJF file instead of .RPAD file. - Possibility to edit .RPJF file. - Improve Compressibility test. - Improve Autocrop. - Bugfix and clean of the code. Autorv9 v1.3 : - add DTS audio input - add a speed test - improve Hight Motion filtering - improve finale file size calculation - improve .smil file - multilanguage support - support .avs input (this mean avi/directshowsource can now open : .rmvb/.mkv/.omg/.avi/.wmv/.mpg/.qt ) - support the "Real Audio 5.1" codec - support audio 2.0 (stereo) =>5.1 (surround) conversion - added EHQ mode - add chapters support for .smil - add transparent subtitle for .smil - detect the avisynth error msg - improve avisynth editor (support credits .avs). - change latency at 60 sec - added support for Multichannel (create 6 separate .wav mono file) - add support for 5.1 input wav file. - rewritte the rv9 header parser - improve P4 Hyperthreading support. - improve the split : more accurate & fix the black screen bug on second part - fix the problem for the update of avisynth script file - anamorphic encode support - improve smil file for 4/3 movie. - fix the black frames when splitting movie. - improve audio part (full azid comfiguration possible,add boost, pre gain .... etc ) - work with avisynth v2.5.1 - use latest millestone 6 - support anamorphic encode Autorv9 1.2 : - add support of two audio stream - add support of subtitle - add a preview video - add an avs script editor - generate .smil file (needed for launch subs or audio streams) - improve the autocrop - add the overhead calc - improve the quality indice - fix the problem for the "c:\" tempory file - free split size - improve the split (now split on a keyframe) - add filters for avisynth : - Simple Resize - Lanczos Resize - TomsMoComp - Decomb - IT - IVTC 2 - CNR2 - TemporalSoften2 - Unfilter - Msharpen - 2D cleaner - SmartSmoothHiQ - SmoothDeinterlace - Convolution3D - ...... - improve the besweet preset (better normalisation & boost) - autosearch of real producer. - clean of the code & internal changes Autorv9 1.1 : - Add an Auto-Crop function. - Add an "Smart Crop All" function. - Encode the end-credits separately (Quality 30%). - possibitity to adjust the bitrate after the end-credits. - Possibility to split the file after 650/700 or 800 Mo - possibility to change the Encode Process Priority. (Thanks to dannidin) - Display the .Ac3 file informations. (using the CyberDemonII genericmm.dll file). - u can ID3Tag your movie *and Fixed some little bugs*
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec. AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles. Last edited by Dark-Cracker; 18th April 2007 at 16:50. Reason: Added link to archive.org |
#2 | Link |
Great tool AutoRV10 is, thanks
![]() Just a quick question though - does AutoRV10 follow a W-mod 4 x H-mod 4? I've read about DivX/XviD being affected in terms of compressibility if you use anything other than 16 Mod. Is RV10 affected in any way by the Modul you use? |
#3 | Link |
![]() Join Date: Oct 2002
This is the new and clean AutoRV10 thread. Please continue the discussion here.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/ This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
#5 | Link |
It also seems to forget to add Import("F:\Autorv10\SOFTS\AVSFILE\SCRIPT\FIELDORDER.AVS") to the avs script so I get Script error: there is no function named "FieldOrder"
#7 | Link |
i have solve theses 3 problems, no more error if bitrate is empty. the fieldorder was missing if you are using the kerneldeint deinterlacer. now the delete job remove the selected job. I have made a silent update, you can find the fixed .exe at the same url in the first post. PS : the output and input tab will soon be have some cosmetic improvements ![]() Bye.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec. AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles. |
#10 | Link |
i have fix the bug it will be available as soon as i release the next build.
#11 | Link |
Hello DC,
Thx for your works on autoRV10. But I found some problems that the dvddecryper is work not working with the autoRV10 interface. Therefore I would like to suggest in step using dvddecrypter. Can you interface read the .ifo & .vob directly ( remarks: .vob file better support over 1G from harddisk) Therefore is another problem. as .ifo file says that 720x480. but the .vob file is 853x480 (1.78:1, 16:9 japanese HDTV size down from 720p/1080i). Therefore if your autoRV10 can handle that will be great. Ciao, ibear
#12 | Link | ||||
hi,
first thank u for your interest in my software ![]() second, i have a low english skill and i don't fully understand all your sentences, can you please try to explain me what you understand by : Quote:
if it's what you mean, in fact i can't do that because there is some protection on the DVD .vob file and i use dvddecrypter to remove them and copy the new uncrypted .vob file on the harddisk. Quote:
(if you have subtitle in the .vob it's even better i will check if there are handle correctly). but does some other player see them as 853x... or 720x... ? and which resolution does dvd2avi see the .vob file ? and which resolution autorv10 show u when u open the .d2v file ? PS : have you try to set the aspect ratio at 1:1 in the video tab panel ? and which resoltion are you waiting for the output ? Bye.
#13 | Link |
Hello DC,
I think something wrong with my louzy english. I think I need to tell you one by one. For the dvddecryper packing with your software. When I insert the DVD disc. Your software give me this error message (see the attachment) Ciao, ibear |
#14 | Link |
Hello DC,
My second problem is that. In step of rip .ifo & .vob file from DVD disc. Can you add one option that read .ifo & .vob files from harddisk. Because I already have a DVDripper software in the harddisk. And also when I rip the video from DVD disc the .ifo & .vob file in the harddisk most of them are over 1G. In my experience not much software can read / support .ifo & .vob file over 1G. Ciao, ibear |
#15 | Link |
Hello DC,
Here is the third problem, I have NTSC DVD. The content of this DVD is 16:9 TV program the Aspect Ratio is 1.78:1. As I know that the NTSC DVD is 720x480 ( AR 1.33:1) it will look like Letterboxed. If I only want to encode 16:9 the Aspect Ratio is 1.78:1 is it possible to do that !? Ciao, ibear |
#16 | Link |
hi,
now your answer are more clear for me thx ![]() 1) for the error #6 (when the ripper open the DVD) could you plz add in a .zip file all the .ifo file that are in the DVD, i think one of them produce an error in my ifo parser. (send them at : darkcracker#caramail.com replace #=>@ and put the word "autorv10" in the mail subject). 2) could you plz explain me why you want to open directly the .ifo file from your hardisk ? instead of made (manually) the .d2v file using dvd2avi and opening the .d2v later ? could u give me more informations why you want such feature. 3) for the 1.78 ratio i don't have see such dvd (like yours wih 853 resolution), i am not sure how to encode them, i think perhaps the right way is to open you video, crop the black border, select the ratio 1:1 and resize the video. if you provide me a sample with the .ifo file i could perhaps try to see how to handle this. Bye.
#17 | Link | ||
Ciao, ibear |
#18 | Link |
hi,
i have try your .ifo file and i have no problem to read it, do you have only 1 ifo file in the DVD ? else be sure you send me ALL the ifo file that are on your DVD disc it's surely another .ifo file who have a problem. Bye.
#19 | Link | |
#20 | Link |
Still a couple of bugs
Hi DC. I'm still useing and enjoying your tool. But there are 2 quite big bugs.
- Crashes every time I use "set end credits" (runtime error '35600' Index out of bounds crash) - Runtime error 6 overflow when ever I try to encode to a size over 2200MB. It allways crashes at the beining of the second pass. Both of these happen on 2 different machines. I hope you can release 'final' version with these fixed. Right now I have to do 2 or 3 partial d2v projects and then join them to encode a large source. |
| Thread Tools | |
| Display Modes | |
