Old 9th June 2002, 17:03   #1  |  Link
Vladdy
AC3 Machine files
Having downloaded the latest besweet and ac3 machine 0.3, i have encoded a few sample ac3 files, namely music files from stereo wave files. I'm assuming I'm doing something wrong, because the files that I encode come up with white noise when playing back in winamp. I use in_ac3.dll in winamp, and for a few seconds the song is fine, then get a few bits of white noise, and then goes back to normal playback. When i play this file thru my spdif connection to my dd5.1 receiver, the DD flag comes on, but the audio is totally silent.
I haven't toched any of the settings other than the location of my wav, ac3 and besweet files.
Vladdy is offline   Reply With Quote
Old 9th June 2002, 18:29   #2  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
hi vladdy!
please post your logfile.
DSPguru is offline   Reply With Quote
Old 9th June 2002, 19:43   #3  |  Link
kilg0r3
! - User - !
kilg0r3's Avatar
i don't think this is a problem of the encoded file but of the winamp plugin. for i have the same problem with material directly decoded with dvd2avi. winamp just gives white noise and also shows a wrong playing time. i have not been able to use the besplit gui for this reason. the current test file is a 224kbps mono ac3.
-> where to get the most recent version of this plugin?
Keep your tone warm and your sigs decent!
kilg0r3 is offline   Reply With Quote
Old 9th June 2002, 19:54   #4  |  Link
MaTTeR
AC3 5.1 Addict
MaTTeR's Avatar
Try playing the file back in PowerDivx or ZoomPlayer. I get perfect playback using either. If it doesnt work on either of these apps then something is wrong with the file.
WA is know to have problems with AC3 playback for sure.
Need AC3 & SPDIF setup info?
MaTTeR is offline   Reply With Quote
