Thread Tools Display Modes
Old 7th May 2002, 01:00   #1  |  Link
Dark-Cracker
Dark-Cracker's Avatar
"Autodub" tool support Divx3/Divx4/Divx5/Xvid
Hello ,
I Need Beta Tester for "AutoDub" this tool (start automaticly Vdub/Nandub for encoding in 1pass or 2pass (both) or 3pass and u can chose beetween Divx4 Divx5 or Xvid codec and Divx 3.11 SBC)
www.dark-angel.does.it
Version :
Autodub v1.7 Final !!!
INSTALL Xvid BUILD 16/02/03 (or 17/02/03) in the "Other" Download section.
1.7 :
- add support of the Xvid Build (16/02/03 or 17/02/03)
- add support for the VHQ Mode.
- add support of the divx5.0.3 (autodetection beetween v 5.0.2 or 5.0.3)
- add support for the Nthpass mode.
- add support for the 1 pass quality 100%
- add ChromaMotion, keep Interlace, Bframe Offset for Xvid settings.
- automaticly enable Chroma Optimiser when u select chroma motion in Xvid.
- possibility to enable/disable Mv file for divx5.
- added RC avg. half movie's frames for divx5/4.
- added 13 custom matrix for Xvid codec (found on the Doom9 forum).
- add the Xvid autoCalc High/Low distance (based on the PerfectXvid code, autor TheUnforgiven).
- create joblist (multiencode).
- improve the compressibilty test.
- improve the crop tab and autocrop function.
- improve codec generic profil.
- improve preset for avisynth filters.
- added color preset (for tweak filter).
- add filters for avisynth :
(dup v1.4, decomb v4.05, Fluxsmooth v0.4, PeachSmoother,
TemporalCleaner, Xsharpen, Warpsharp, Anticomb 0.5, BlockBuster).
- support of subtitle (.sub,.smi,.ssa,.ass,.srt) using vobsub and texsub filters.
- possibility to configure subtitles (change subtitle font, color...etc).
- add avisynth script editor.
- add 3/4 vew on the preview, and preview with resized parameters.
- for divx3 add an alternative curve scaling (based on the statviewer code, autor Nitrogen).
- improve audio part (a little besweet gui with : boost, gain, altpreset..) .
- autodetect audio delay in the name file.
- disable options for the 5.1 output if input was a 2.0 channels.
- disable the postgain/hybridgain for .wma/.ac3 output file.
- disable options useless when u use hybrid gain.
- bug fix and clean code.
1.6.5 :
- add support of the Xvid Build 21/11/02(B-frames, Qpel, GMC).
- update avisynth filters (SmoothDeinterlacer, DUP 1.4, Decomb 4.01).
- update 1CD and 2 CD profile for Divx5 & Xvid.
- fix the "disable ouput" bug.
- change on the avisynth settings.
1.6:
- add support of the Xvid's build 04-09-02
- add to support the ogg postgain with tobias oggDS 0.9.9.3
- add a compressibility test (work with divx3/4/5 & Xvid)
- add an autocrop
- add a smart crop all
- improve the bitrate calculator.
- possibilty to encode endcredits in greyscale
- possibilty to encode a black screen for endcredits
- now use temporalsoften2 for the endcredits
- add a namual resize (ratio 1:1)
- improve the desinterlace and ivtc value
- add more avisynth filters :
- Simpleresize 0.3.2
- Lanczos
- DUP 1.2
- CRN2
- IVTC22
- IT 0.51
- TomsMoComp
- DeInterlaceQ
- Decomb 3.91
- 2Dcleaner
- SmootherHiQ
- Msharpen
- Unfilter
- TemporalSoften2
- Convolution3D
- update Oggmux version 0.9.2
- clean of the code
V 1.5
- i have added the .OGM support (Mux the .Avi and .OGG with Oggmux)
- add the re-encode of the .AC3 file
- i have added a split function (based on the genericmm.dll file by CyberDemonII)
- improve the MP3 profils
- improve the generic profil for the codecs
- add the "crosspoint" parameters for the divx3.11 (sbc)
- improve the speed in the crop panel
- and the support of the .pcm input file for audio stream
- fixed a bug with the tempory directory
- improved a bit the Xvid and divx generic profil.
v1.4 :
- Add the support for the Divx 5.0.2 / Divx Pro 5.0.2
- Now u must select an .D2V file for input source.
(.AVS file creator)
- Add the support for the Video Crop.
- Add the support for the Video Resize.
- Add the support of the "Tweak v1.3" Avisynth plugin
- Add desinterlace mode ( Decomb 3.8, GreedyHMA)
- Add support for the InverseTelecine (IVTC 2.2 , Decomb 3.8, GreedyHMA)
- Add smooth filter (light, normal, strong) for denoising the movie.
- Add support of Virtual Dub Plugins (Warpshap, Optimized 2D cleaner, Smarth Smoother HiQ)
(Based the Wilbert's Virtualdub filter script importer v1.3, these filters are usefull for anime filtering)
- Add support of the encredits (encode separately or with more compressible)
- Add generic profils for 1Cd or 2Cd.
- Now u can use HintME + (1st pass H.263 & 2nd pass Modulated) in Xvid panel
- Add a bitrate Calculator.
- Fixed some little bugs.
1.3
- Fixed a silly bug with the fast Processing Mode
- Support for Divx 5.x/Divx Pro 5.x is back
- Add the "first pass H.263" + "second pass Modulated" for the Xvid
- Add more options for the Xvid codec (for fine tuning)
- Add support for the Nic's Build 02/05/02
- Add support of the Divx 3.11 SBC (Using Nandub).
- Add Support of Audio Encode part (MP3 , AC3 , WMA output)
- Add support for the CBR/ABR/VBR MP3 profils
- Add normalisation/amplification/downsample 44.1 options
- Add support of two audio streams in an .avi file
- Add mux support for Audio streams with desired delay
- Add the autodetection for "Divx ;-) Audio codec" (WMA Hack)
- Now detect the Virtualdub version and the Xvid date build
- Add the possibility to use a temp folder.(if you have much HD)
- Add warning registry flag for Virtualdub (if it the first time you start Vdub)
PS: This version work only with XVID 02/05/02. think to download again Divx4Inf.zip
(i have fixed a little bug with the internal code fourcc and the registry key)
YOU NEED FIRST SELECT THE PATH OF THE EXTERNAL APPLICATION THEN RESTART AUTODUB (for create the .ini file)
You can mail me at : darkcracker@caramail.com (for comments or request or if you find bugs)
Dark-Cracker is offline   Reply With Quote
Old 7th May 2002, 19:30   #2  |  Link
roy
I did compression using version 1.3. I used Xvid codek and 2-pass encoding. Everything was ok but I wanted do both passes with fast-recompress, but only first was done using this option , second with full processing mode. So it was much more slower. Why it happens?
roy is offline   Reply With Quote
Old 7th May 2002, 19:46   #3  |  Link
Dark-Cracker
starnge perhaps the encode priority have fail and it for that i think the second pass take much time, i have check a the fast or full processing bug but i don't have found , to be sure just open edit the c:\jobpass1.vcf (first pass script) and c:\jobpass2.vcf (second pass script) with the notepad and verifie this :
VirtualDub.audio.SetMode(1); <=== is fast processing.
or :
VirtualDub.audio.SetMode(3); <=== is full processing.
Ps: do you have tested the Divx3 option ? or u don't use the SBC encoding ? do you have find bugs ?
Old 7th May 2002, 21:37   #4  |  Link
roy
In jobpass1.vcf and jobpass2.vcf I have VirtualDub.audio.SetMode(1);, but the second encoding was done in full processing mode. I'm sure.
Old 7th May 2002, 22:13   #5  |  Link
Dark-Cracker
yes you are right i have found the bug i have do a mistake in the creation of the .vcf file for the Xvid second pass it use :
instead of
VirtualDub.video.SetMode
the bug is fixed, download again Autodub v1.3
thank for finding this bug. Bye
Ps: post if this fixed version solve you problems.
Old 9th May 2002, 10:26   #6  |  Link
Tester
Member
problem with starting
Unfortunately, I can't tell you if the program is good or not (but I think it's great ), because I can't start it. When I click on Autodub.exe, an error message appears with no content...
I've winxp...
Or do I have to install all the codecs first???
thanks in advance
Robert
Tester is offline   Reply With Quote
Old 9th May 2002, 14:28   #7  |  Link
yosemite
Half Dome - Come and see!
I've the same prob and the same OS --> XP!
what's wrong?
cu
yose
Yosemite National Park, CA - The greatest place on earth
yosemite is offline   Reply With Quote
Old 9th May 2002, 14:46   #8  |  Link
roy
I want to use this programm in Windows 98 but I can't. When I try to start it I got mesage "the language DLL MSDMO.DLL could not be found". I have installed VB6SP5 but still the same. What's wrong?
Old 9th May 2002, 14:52   #9  |  Link
Kb_cruncher
replecant
Kb_cruncher's Avatar
i also run XP and get an error message about COMCLT32.OCX.i have come across this problem before and needed a specific version of the file to fix it.is this so in autodub's case?
Kb_cruncher is offline   Reply With Quote
Old 9th May 2002, 14:57   #10  |  Link
Kb_cruncher
replecant
Old 9th May 2002, 16:19   #11  |  Link
Dark-Cracker
i fact the problem is that visual basic need a lot of dll, i have do a bundle version (with a setup) who install all the dll file needed, here is the link test it and post a msg to know if this have solve your problems.
http://membres.lycos.fr/darkangel47/...b1.3Bundle.zip
Old 9th May 2002, 16:29   #12  |  Link
Dark-Cracker
PS: think to post the exact msg error , this will help me to solve the problem.
Old 9th May 2002, 18:40   #13  |  Link
Kb_cruncher
replecant
i downloaded the latest version of COMCTL32.OCX and the latest vb6.
solved the first error but know i get"failed to load control'slider'from comctl32.ocx,your version of the file maybe out dated"but htese files are the latest i can get.
will try your bundle and let you know.
Old 9th May 2002, 20:21   #14  |  Link
wing1
Is there a possibility to add wav audio encoding or mp3 transcoding to this application? Also the possibility to correct a/v sync correction as well?
wing1 is offline   Reply With Quote
Old 9th May 2002, 20:33   #15  |  Link
VorteX
www.fastremoval.co.uk
VorteX's Avatar
i have download the latest visual basic sp5 installer from Microsoft site and installed it ok. When i run AutoDub.exe i get error message "Component 'TABL32.OCX' or one of its dependencies not correctly registerd: a file is missing ot invalid" i've removed and reinstalled Vb6 and it still not working.
i am using Windows XP too
www.vortexleather.com - Online International Leather Clothing Store
www.fastremoval.co.uk - London Removals Company
VorteX is offline   Reply With Quote
Old 9th May 2002, 20:37   #16  |  Link
VorteX
VorteX's Avatar
ok i've just downlaod the bundle 3 times now but the installer is not working just after selecting directory when i click on the Computer Icon to continue install i get the error msg
Type Mismatch
une erreur d'installation inattendue s'est produite
i dont know what it means.
Old 10th May 2002, 03:32   #17  |  Link
Obsolete
TABCTL32
If you're getting the TABCTL32 error I found tabctl32.ocx here:
ftp://taurus.bmtmicro.net/vgaplanets/v4/tabctl32.ocx
you'll also need REGSEVER32: ftp://taurus.bmtmicro.net/vgaplanets/v4/regsvr32.exe
Put tabctl32.ocx in any directory then drag and drop it onto regsvr32.exe. If you move tabctl32.ocx to somewhere else on you H.D. you'll get an error unless you repeat the step above.
Autodub seems to work okay now.
Obsolete is offline   Reply With Quote
Old 10th May 2002, 11:36   #18  |  Link
Dark-Cracker
wait few day i work on a full bundle version with all the .ocx needed.
@Kb_cruncher
the new version will use the new comctl32.ocx.
@wing1
wait i am finish well the video part and the audio part will be improved soon.
@vortex
does the 'obsolete' solution has solve your problem ?
Thank u all for testing my prog i hope in a few day the missing file problem will be solved.Stay Tuned.
Old 10th May 2002, 11:54   #19  |  Link
VorteX
VorteX's Avatar
Obsolete method worked for that file but now i got same error but this time for COMCTL32.OCX
Old 10th May 2002, 13:46   #20  |  Link
digi-rip
Memory Error .... mmm
would be a grate option disable sound procesing .....
I am using XP too ...
Divx5.1
digi-rip is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
