Old 6th May 2002, 21:17   #1  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
easiest way to do AC3->MP3
hi all,
i've heard some newbies says that BeSweetGUI is too complicated, so i thought you might wanna know about EasyBeSweet - the easiest tool in the world for transcoding ac3 into mp3/ogg.
this nice tool simply adds a new entry to your Windows Explorer shell extension, and transcoding is being done with right click on the AC3 file in windows.
this makes transcoding as easy as playbacking.
Good Luck !
Dg.
DSPguru is offline   Reply With Quote
Old 7th May 2002, 06:09   #2  |  Link
aleksander
Someone, somewhere
aleksander's Avatar
Thank you DSP for that info!
I am sure it will help some of our newbies
I will make that a sticky for a while.
Take care
aleksander
aleksander is offline   Reply With Quote
Old 20th May 2002, 11:25   #3  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
Another "easy" BeSweet GUI
Hi !
DSPGuru suggested that I put my GUI for BeSweet here.
For me th BeSweet GUI from DD was always somewhat "overloaded" with features I didnīt need and that were IMHO too complicate for newbies. So I wrote my own GUI.
Give it a try !
-D$
Darksoul71 is offline   Reply With Quote
Old 20th May 2002, 19:06   #4  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
very nice !
@newbies
BeSweet can be found here :
http://DSPguru.doom9.org
Old 21st May 2002, 06:58   #5  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
@DG:
But not as nice as BeSweet
-D$
Old 28th May 2002, 20:47   #6  |  Link
Cretak
i am not a newbie anymore but thanks anyway ! a nice gui is always good
Đ Cretak
Cretak is offline   Reply With Quote
Old 2nd June 2002, 05:43   #7  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
so here's another one... although i find DarkSouls' GUI better .
Old 25th July 2002, 04:20   #8  |  Link
bkST88r[CTL]
holy crap that is the best thing =)
THANKS!!!!
i love you =)
-=bkST88r=-
super divx newbie ;-)
ive upgraded my comp finally ;-)
go 9800 pro go =)
bkST88r[CTL] is offline   Reply With Quote
Old 27th July 2002, 20:57   #9  |  Link
Head Hunter
@Darksoul71
Is there a way that you could have your GUI recognise if the AC3 file is 2 channel or 5.1? Most people use LFE to LR -3db on 5.1 channel sources, however you prog doesn't use it.
Head Hunter is offline   Reply With Quote
Old 30th July 2002, 20:30   #10  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
Hi Headhunter !
Sorry for my late reply ! No, this isnīt possible.
My GUI is only a frontend and I donīt have a clue how to check how many channels an AC3 file has.
cu,
D$
Old 26th January 2003, 13:02   #11  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
Iīve just uploaded the latest version of the BeSweet GUI to my homepage:
Latest changes:
2.7 - Added input support for wave, AVI, MPEG audio
- Fixed batch processing module
- Fixed delay extraction from source file name if audiostream
was demuxed with DVD2AVI instead of Smartripper (DELAY vs. Delay_
Download here:
http://home.debitel.net/user/holger..../bsweetgui.zip
Have fun !
-D$
Old 29th July 2003, 20:22   #12  |  Link
BloodyBaron
Re: easiest way to do AC3->MP3
Originally posted by DSPguru
hi all,
Well the link seems to be dead unfortunately!
BloodyBaron
BloodyBaron is offline   Reply With Quote
Old 29th July 2003, 20:47   #13  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
http://www.rip-it.de/modules/news/article.php?storyid=5
Old 12th August 2003, 14:16   #14  |  Link
zedstrange
zedstrange's Avatar
sorry DSP Guru, that URL although not dead only suggests to go to the downloads section, and we end up with a dead download link again.
I found a download site here
http://divx.dva.pl/index.php?dzial=download&nr=2576
click on the CDicon, if you dont understand the language(like me)
zedstrange is offline   Reply With Quote
Old 12th August 2003, 14:33   #15  |  Link
Dark-Cracker
Dark-Cracker's Avatar
perhaps a sticky post with all alternative gui for besweet and other dsguru tools will be welcome , and set them in order of difficulties to use (more detailled to more newbie user).
sorry for my bad english
EDIT: a memory pipe way for the gui could be fine to get the % encoding . just hope dspugur could add this in besweet (dos version) else the dll is the only way to get the % value .
Bye.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 12th August 2003, 15:05   #16  |  Link
zedstrange
zedstrange's Avatar
What i would like to see is instructions how to use the Batch process in BesweetGUI. (sorry if there is one, but i could not find it, here or at the authors site).
Thats what I was looking for when I stumbled across EasyBesweet, which makes it a bit simpler when doing 20 AC3 files at the same time.
Old 23rd September 2003, 21:19   #17  |  Link
KYUSS
wow this is an excellent tool
just the thing i was after for converting directors commentaries to mp3 for my mp3 player so i can gem up on my movie trivia whilst jogging
thanks
and keep up the good work
KYUSS is offline   Reply With Quote
Old 2nd December 2003, 23:24   #18  |  Link
KYUSS
anyone got a working link for easybesweet please?
Old 23rd January 2004, 14:31   #19  |  Link
Kb_cruncher
replecant
Kb_cruncher's Avatar
Are there any working d/l links for easy besweet and darksoul71's gui as non of the links above work(for me)?
"There are no such things as problems,only solutions"-my father
Kb_cruncher is offline   Reply With Quote
Old 23rd January 2004, 21:43   #20  |  Link
KYUSS
i have easybesweet m8 lmk an email address to send to and i'll fire it over to you
