Thread Tools Display Modes
Old 6th April 2002, 21:04   #1  |  Link
jonny
jonny's Avatar
Utility to automate a 2 pass encoding with VirtualDub and DivX 5 Pro
Homepage: http://jonny.leffe.dnsalias.com/
I'm no longer going to edit the first message on this thread... it's becoming a copy of my site, so better to go to my site .
The original post here was something like:
I've written this tool... here is the v1.00
jonny
jonny is offline   Reply With Quote
Old 6th April 2002, 22:26   #2  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
I downloaded your utility, it's pretty cool, but can you please introduce a batch processing mode or something like a job list, this is very important.
And then an option to shutdown windows when encoding is finished.
Thank you...
DJ Bobo is offline   Reply With Quote
Old 6th April 2002, 22:46   #3  |  Link
SuperflyTNT
nice proggY, I'll use it when i use divx 5
...jeah
SuperflyTNT is offline   Reply With Quote
Old 7th April 2002, 00:06   #4  |  Link
jonny
jonny's Avatar
@bobotns:
nice input
@SuperflyTNT:
thanks
Old 7th April 2002, 15:25   #5  |  Link
ChAoS Overlord
what is the "overwrite/delete" options necessary for? Doesn't this happen automatically?
Also does your utility switch to fast recompress or full processing? I prefer fast recompress most of the time.
Also why did you change: keyframe interval to 250 & max quantiser setting to 12?
ChAoS Overlord is offline   Reply With Quote
Old 7th April 2002, 20:57   #6  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
@ chaos
The delete option is the contrary of the protect option in the codec, so it's usefull!
It works in fast recompress mode.
And jonny hasn't changed anything, you change the settings as you want, if you wanna 250 or 1000 for keyframe, it's your decision. Same for quantizers!
Old 7th April 2002, 21:34   #7  |  Link
ChAoS Overlord
Hmm so am I right when I see, that protect is on when the delete option hasn't been activated then?
Old 7th April 2002, 22:12   #8  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
YES
Old 8th April 2002, 05:33   #9  |  Link
ookzDVD
DVD Rebuilder!
ookzDVD's Avatar
I think this is Divx4pass2 win GUI.
Nice proggie,
next version should be batch support and shutdown after finish.
ookzDVD is offline   Reply With Quote
Old 8th April 2002, 11:21   #10  |  Link
rui
Good work jonny
It even has an ending report, saying our average quantizer.
Rui
rui is offline   Reply With Quote
Old 8th April 2002, 12:08   #11  |  Link
yosemite
Half Dome - Come and see!
thanks for such a prog , very helpful indeed
but I've a little problem:
I encoded Matrix and in Gknot I've choosen a filesize for 3CDs!
But the movie is smaller than 1GB, whats wrong here?
cu
yose
Yosemite National Park, CA - The greatest place on earth
yosemite is offline   Reply With Quote
Old 8th April 2002, 13:27   #12  |  Link
jonny
jonny's Avatar
If you check overwrite/delete, the file will be overwritten (if exists) and deleted at the end of the encode.
If you don't check overwrite/delete, the file will be not overwritten (if exists, this generate and error) and not deleted at the end of the encode.
I dunno if i'll keep this options in the next ver... i think are not so useful... let me knot what you think...
@ookzDVD: hihihi
@yosemite: there are A LOT of answers in the forum for those getting undersized
Old 8th April 2002, 13:33   #13  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
@ yosemite
I thought you asked such a question before. First: 3 CDs is a joke! don't go for more than 2 CDs for any rip! second: Matrix is good compressible, so it's already saturated by 1GB, so go for higher resolution like 640x272 or 704x304.
This has nothing to do with his utility!
Old 8th April 2002, 14:23   #14  |  Link
ChAoS Overlord
You're right, it should be overwritten/deleted by default (also make your program "remember" all settings please)
Old 8th April 2002, 17:59   #15  |  Link
ulfschack
Good job, jonny
Could you make the settings stick? Like in some sort of ini-file, I wonder?
cheers
ulfschack is offline   Reply With Quote
Old 8th April 2002, 18:08   #16  |  Link
jonny
jonny's Avatar
Wait for the next version and keep posting your opinions
Old 8th April 2002, 18:32   #17  |  Link
yosemite
Originally posted by bobotns
@ yosemite
sure, but not if u go for 2 audio streams!
cu
yose
Old 8th April 2002, 19:26   #18  |  Link
UHT
it depends on the format of the audio streams i guess, 2 ac3 streams then maybe 3cd's its still overkill for such a short and dark film
UHT is offline   Reply With Quote
Old 8th April 2002, 19:33   #19  |  Link
yosemite
well, but a video-bitrate about 709kbps are not so nice in my opnion (thats what u get with 2 CDs)
think about it:
the 2 audio streams are about 2x 359MB!
cu
yose
Old 8th April 2002, 22:06   #20  |  Link
Acaila
Retired
Acaila's Avatar
Still, 3 CD's is overkill. For a codec with B-frames it is even more so. And are you really going to listen to all those extra soundtracks?
And the bitrate doesn't say anything about the resulting quality. It's the compressability of the movie that determines the quality. High compressability with low bitrate could sometimes look better than low compressability with high bitrate
P.s.
With any dark movie you'll get ugly marcoblock artifacts in the near-black areas. But not even extreme high bitrate will get rid of those, so it's not worth the effort.
Acaila is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
