Old 17th March 2002, 16:49   #1  |  Link
teko77
.m2v ok, muxing with IfoEdit makes skips into the videostream
I have been experimenting with the skipping issues my processed
VOBs have and it seems that even though the .m2v -stream generated with ReMpeg does not have any skipping in the videostream, those occur after I mux the .m2v with IfoEdit.
Could it be that I have some wrong settings in the "VOB Extras" as Doom's guide does not have all the new settings that are possible there? Which should one choose there? Or what could I do to get rid of those? I am processing a "movie-only" stream.
Thank you for any help,
Teko
teko77 is offline   Reply With Quote
Old 18th March 2002, 14:12   #2  |  Link
Derrow
Important are the two checkboxes to correct vob-unit pointers and ifo tables.
The check-boxes on the right side should be untouched. They are always preset correctly for a regular usage.
What movie did you transcode ?
Derrow is offline   Reply With Quote
