Old 5th March 2002, 21:25   #1  |  Link
ECY
Divx5 and Divx4
is it possible to run both of them at the same time ??
ECY is offline   Reply With Quote
Old 5th March 2002, 21:29   #2  |  Link
dragoman
DivX.com Mod Squad
Far as I know...DivX 5 installs over DivX 4.xx when you install it.
Only thing I can think of is try re-installing 4.xx again...shoudl be able to keep both on your system
dragoman
dragoman is offline   Reply With Quote
Old 5th March 2002, 21:47   #3  |  Link
ffroms
ffroms's Avatar
I tried that , but nothing . They have same dll (divx.dll).I tried renaming it and change some values in register and win.ini but nothing. Is there anyone who knows how to do that ?
FFS
OK. I found out that it's possible to have both version of divx at same time and thay work , but it needs little register editing.
ffroms is offline   Reply With Quote
Old 6th March 2002, 02:38   #4  |  Link
movmasty
maybe a "little register editing" could also let decode divx3 vids with divx3 decoder ?????????
movmasty is offline   Reply With Quote
Old 6th March 2002, 10:56   #5  |  Link
pdontthink
pdontthink's Avatar
..."little register editing"... please don't
just leave it at that. EXPLAIN, if you would,
what exactly you did to accomplish this.
thank you!
pdontthink is offline   Reply With Quote
Old 6th March 2002, 11:39   #6  |  Link
ECY
yeah explain please
how did you manage to did it ???
with the register editing.
Old 6th March 2002, 12:36   #7  |  Link
pdontthink
pdontthink's Avatar
perhaps this magic registry editing, yet to be
explained to us, will help those of us who also
want to retain the 3.11 codec as well??
Old 6th March 2002, 16:20   #8  |  Link
ffroms
ffroms's Avatar
OK , I'll trie to explain .
For Windows ME (maybe all Win9x , I din't trie that yet)
First install Divx4.12 , goto to windows\system folder and rename divx.dll in divx4.dll. Open system.ini in windows folder and find under drivers32 vidc.DIVX=DivX.dll and change it to vidc.DVX4=DivX4.dll
Now open regedit
Editing register
Under
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
creat new value
vidc.dvx4=DivX4.dll
Under
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\MediaResources\icm\]
creat new keywith name vidc.DVX4 , and under that key enter new strings
"Description"="DivX Codec 4.12"
"Driver"="DivX4.dll"
"FriendlyName"="DivX Codec 4.12"
Now you can start VirtualDub and under Compression you'll see Divx 4.12 and when you click on it will show "Divx4.dll" . Now you can install Divx5.
For Windows XP
Install Divx4.12 ,rename divx.dll under windows\system32 in to divx4.dll
"vidc.DVX4"="DivX4.dll"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\MediaResources\icm\]
creat new Key
vidc.DVX4
and under that key new strings
Description=Divx 4.12
Driver=DivX4.dll
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\MediaResources\icm]
creat new Key
vidc.DVX4
Driver=DivX4.dll
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Control\MediaResources\icm]
creat new Key
vidc.DVX4
Driver=DivX4.dll
And that's it. It worked for me.And one warrning . Divx4 and Divx5 place they settings in same place in register so if you change like bitrate in divx4 it will have same effect on divx5.
FFS
I just found out that settings for WinME works on Win98SE.
Old 7th March 2002, 13:59   #9  |  Link
theReal
Piper at theGates of Dawn
theReal's Avatar
Thank you VERY MUCH for this tweak, it works great!
Without this I would not have installed Divx5 again, because I need a reliable Divx4.12 to capture from WinTV (divx5 crashes every time when I try to capture in realtime).
theReal is offline   Reply With Quote
Old 7th March 2002, 15:19   #10  |  Link
ECY
thanx ffroms
i made a inf file to make the installation od divx 4.12
easier idf someone want it just mail me
Old 7th March 2002, 16:07   #11  |  Link
ffroms
ffroms's Avatar
Glad to help.
Old 7th March 2002, 22:14   #12  |  Link
pdontthink
pdontthink's Avatar
ECY, why not just attach it to your post
here, since I'm probably not the only one
who will ever want it...
thanks in advance!
Old 8th March 2002, 14:44   #13  |  Link
ECY
Here are the inf and renamed Divx.dll
http://www.angelfire.com/empire/ecy/divx4.zip
add a inf for WinXP i don't know if it works!!!
Old 8th March 2002, 16:17   #14  |  Link
ECY
Does the link work
or the Attachment ????
Old 8th March 2002, 16:40   #15  |  Link
Chibi Jasmin
Here:
left click no, right click-save as yes
Chibi Jasmin is offline   Reply With Quote
Old 9th March 2002, 20:11   #16  |  Link
ECY
Does anyone has the source code for Divx 4.12 Direct Show filter ??
or for the Divx 3.11
Old 9th March 2002, 21:38   #17  |  Link
Acaila
Retired
Acaila's Avatar
Neither DivX3 nor 4 are open source, so no-one will have a -legal- source code lying around.
Nic used the OpenDivX code to produce the XviD DSF, so you should be able to find that one somewhere. Check ProjectMayo or ask Nic directly.
Acaila is offline   Reply With Quote
Old 11th March 2002, 17:56   #18  |  Link
ECY
Ok i know it actually don't belong here
does anyone has the lastest version of "rpcndr.h" and "divxfilter.sbr" for Vc++ ?
cause i am not allowed to install the service Pack for it in the ComLab of the uni
Old 12th March 2002, 20:40   #19  |  Link
ECY
OK another Question
does someone successfully compiled the opendivx decoder filter ???
and if so what compiler did you used or developer enviroment ??
Old 25th March 2002, 17:46   #20  |  Link
ECY
i added a inf file for WINXP
i don't know if it works !!!
just try it out if you want
