Old 17th February 2002, 23:16   #1  |  Link
alkasecond
Can't capture in Vdub what to use FlyDS or iuvcr
For some reason capturing directly in Vdub does't work for me.
WindowsXP , ati TV wonder ,drivers from http://btwincap.sourceforge.net/
The original ones(mmc7.1) are crap.
Which of the 2 programs would you recomend, FlyDS or iuvcr?
I dont want to install both, for me less software less headache.
I'd like to keep my system clean.
Thank you.
alkasecond is offline   Reply With Quote
Old 18th February 2002, 00:12   #2  |  Link
mkanar
Maybe I am way off base here, the drivers you are using are for the BT8x8 chipset. Doesn't ATI use a proprietary chipset?
mkanar is offline   Reply With Quote
Old 18th February 2002, 00:31   #3  |  Link
SuperGood
alkasecond: I have the same card as you and am using winxp, I have tried iuvcr, but the video and audio are somtimes not in sync. I have a question. How did you get those other drivers to work. I downloaded them from the same website, and when I installed them, it screwed up my tv program. I had to re-install the ati original drivers. I would like to use those generic drivers. If you could tell me how you were able to install them properly, that would be great. Thanks.
SuperGood is offline   Reply With Quote
Old 18th February 2002, 04:10   #4  |  Link
alkasecond
I just downloaded them ran installer set everything at autodetect
and voila!
I decided on iuvcr, its running right now.
It probably helped a little that I didn't have any ati drivers
installed EVER on that particular install of XP.
ATI not only SUCKS!! writing drivers but they can also
KISS MY ASS now.
I can capture now at 640x480 no problem and choose compressor I like.
Loking for suggestions for settings (capture from VHS).
ps.
I got little carried away but 5 months of waiting does it for you.
Lucky I didn't buy Tv Wonder usb. LOL.
Old 18th February 2002, 10:33   #5  |  Link
henriQ
The basic problem is your video hard & sotware.
Still I would install FLYCAP - it is reliable,
it is light and it is free.
HN
henriQ is offline   Reply With Quote
