Thread Tools Display Modes
Old 14th February 2002, 14:23   #1  |  Link
Doom9
clueless n00b
DivX4 Q&A
Q: What is the different between DivX4 and DivX3 / DivX ;-)?
A: DivX4 is a new MPEG-4 codec developed from scratch by DivXNetworks: http://www.divx.com/. It offers different encoding modes like quality based and 2 pass encoding and it can play back the old DivX3 files.
Q: I'm doing 2 pass encoding and the final filesize is off target. What can I do?
A: Unfortunately not much. DivX4 can be very accurate in some cases and completely off target in other cases (especially 2 CD rips). Using DivX4log: http://divx4log.narod.ru/ may improve the situation but it also complicates the encoding process.
Q: What program should I use to encode to DivX4?
A: VirtualDub. VirtualDub is being used to encode when you use GKnot which is the best working solution for DivX4 encoding. FlaskMpeg / Xmpeg often has problems and is therefore not suggested.$
Q: Where can I find DivX4 guides?
A: Here: http://www.doom9.org/divx4-guides.htm
Q: Can I use Nandub to encode to DivX4?
A: No.
Q: Why are there big blocks in dark scenes?
A: One problem of video encoders is that
absolute error measure is used (for speed reasons), so it to the encoder it doesn't matter if a brightness value of 200 turns into 201, or a value of 1 turns into 2. In both cases the error is 1.
However, the eye reacts to relative difference, not absolut (so once the brightness is doubled, once it's only change by a factor of 1.005), so it's more likely that you will see errors at dark spots.
Q: How can I split a DivX4 movie?
A: http://www.doom9.org/virtualdub_proc....htm#Splitting
Q: Can I use ABR/VBR MP3 audio?
A: Sure. Follow the DivX4 guides (http://www.doom9.org/divx4-guides.htm) , they will tell you how to do it.
Q: I've heard about DivX 4.5 / DivX 5.0. When will they be released?
A: When it's done. There's no ETA.
Q: How to process noisy movies?
A: Use temporal smoother. GKnot offers several options for noisy movies so GKnot is the easiest way to go.
Q: How to improve compressability of a movie?
A: temporal smoother again. For more info refer to this thread: http://forum.doom9.org/showthread.ph...=temp+smoother
Doom9 is offline   Reply With Quote
Old 26th February 2002, 21:45   #2  |  Link
morello12
The ETA for DivX 5.0 is very soon, actually. Atleast that's what they say on their website, www.divx.com . They are auctioning off a PC with the golden copy of the disc with DivX 5.0 as a fundraiser, and the auction ends in 3 days, as you probably know. Once the auction is approved and goes through, DivX will be released to the public. So one can expect DivX 5.0 in about 4 days to around 1 1/2 weeks.
morello12 is offline   Reply With Quote
Old 1st November 2003, 13:26   #3  |  Link
SeriousWorm
SeriousWorm's Avatar
Re: DivX4 Q&A
[/B]
Huh?
SeriousWorm is offline   Reply With Quote
Old 1st November 2003, 16:58   #4  |  Link
jggimi
Moderator Emeritus
jggimi's Avatar
Hellow, SeriousWorm, and welcome to Doom9's forum.
Note the date on that post you are questioning ... it is from February 2002.
The DivX 3/4 and DivX 5 forums were merged last week into a single forum, and we are in the process of reviewing and revising all the "sticky" threads, and consolidating where appropriate.
Stay tuned!
jggimi is offline   Reply With Quote
Old 6th November 2003, 16:45   #5  |  Link
SeriousWorm
Stay tuned!
I've been lurking this forums for a long time, but didn't notice the need to post anything until a time when I encoutered a big problem with encoding and burning VCDs, and just as I registered and tried to post I got a problem, saying that I must wait 5 days before posting anything :/
Anycase, thanks.
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
