#101 | Link | |
I hope it will not break an agreement... Personally, I like to discuss such a things like perceptual quality in native language too... EDIT: RBF was faster
#103 | Link | |
Professional Lemming
![]() I'm gonna test this XVID clip on a flatscreen later today. ![]() Too bad I can't play those AVC encodes there ![]() I used 2pass and whole clips. bis besser, Tobias |
#104 | Link | |
#105 | Link |
Testeur de codecs
[HS: MPEG2 and MPEG4 with HDTV resolution]
HDTV bitrate with MPEG2 For calculate bitrate equivalence in HDTV resolution with DVD resolution I use two mathematical formulation: bitrate/(pixels*fps) bitrate/(pixel^(3/4)*fps) -> very better estimation DVD MPEG2 720*480*30 use generaly ~5 Mbps for Average Bitrate 0.48 bit/pel 11.69 Qs HDTV MPEG2 1280*720*30 with equivalent quality for each pixel 0.48 bit/pel -> ~13 Mbps 11.69 Qs -> ~10 Mbps HDTV MPEG2 1920*1088*30 with equivalent quality for each pixel 0.48 bit/pel -> ~30 Mbps 11.69 Qs -> ~19 Mbps HDTV bitrate with MPEG4 MPEG4 and clone (MPEG4 ASP, MPEG4 AVC, VP6, WMV9, RV10) are very better codec than MPEG2 especialy for high resolution. MPEG4 and clone use ~ +/- bitrate/2 for equivalent quality with MPEG2: MPEG4 720*480*30 ~2.5 Mbps for Average Bitrate 0.24 bit/pel 5.84 Qs HDTV MPEG4 1280*720*30 with equivalent quality for each pixel 0.24 bit/pel -> ~6.5 Mbps 5.84 Qs -> ~5 Mbps HDTV MPEG4 1920*1088*30 with equivalent quality for each pixel 0.24 bit/pel -> ~15 Mbps 5.84 Qs -> ~9 Mbps [/HS]
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 17th September 2004 at 13:13. |
#106 | Link |
I don't want to go off topic but this is a recent quote from AVS forum
"I took a quick sample and got the following... HBO HD 13.9mb/s Showtime HD 6.5mb/s (lowest I've ever recorded) HDNet Movies 7.8mb/s (lowest for HDNet Movies I've ever recorded) These were 5 minute samples, so I'll definitely need to collect more data, but it appears they are giving HBO more bandwidth than the other two." Full HDTV is, as you say, 19 Mb/s, but there is no guarantee that is what you get.
#107 | Link | |
Testeur de codecs
RE HS ... sorry Bobololo and Babayaga
little capture in High Motion start credit http://jfl1974.free.fr/Video/Joey-NBC-HDTV.jpg and No Comment ... DVD forum choose HD-DVD with "blue ray technologie" because DVD9 are unable to contain 120 min of 1080i/p MPEG2 ... - Codec: MPEG2 HP@HL, H264 or WMV9 - Resolution Max 1080i/p with 30 fps, 720i/p with 60fps - Capacity: HD-DVD single layer 15 GB, HD-DVD dual layer 30 GB MPEG2 codec MPEG2 576p ~ 5 MBps DVD5: 120 min DVD9: 220 min HD-DVD15: 400 min HD-DVD30: 800 min MPEG2 720p ~ 10 MBps DVD5: 60 min DVD9: 120 min HD-DVD15: 200 min HD-DVD30: 400 min MPEG2 1080p ~ 19 MBps DVD5: 30 min DVD9: 60 min HD-DVD15: 100 min HD-DVD30: 200 min H264 or WMV9 codec H264/WMV9 576p ~ 2.5 MBps DVD5: 240 min DVD9: 440 min H264/WMV9 720p ~ 5 MBps DVD5: 120 min DVD9: 220 min H264/WMV9 1080p ~ 9 MBps DVD5: 70 min DVD9: 130 min HD-DVD could contain H264/WMV9 encoding in 1080i/p 30 fps or 720i/p 60 fps with ~19 Mbps for ~200 min of video: for these codec it's a low quantizer and ultra high quality preset ... it's practically a lossless quality ...
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 18th September 2004 at 20:24. |
#109 | Link |
Here is a nice contribution from SoulHunter :
http://nero.ateme.com/beta_encodes/T...y@1000kbps.mp4 Enjoy
#110 | Link |
Life's clearer in 4K UHD
Wow, Soulhunter that's so cool.
Thanks bobololo for posting the clip and I'm so sorry I've not able to take a more proactive roll As soon as my current crop of work is completed I'll format my PC and hopefully have a more stable PC to commence testing... I'm still reading the posts and testing the clips and look forward to more releases as and when they arrive. Keep up the good work guys.... My apologies again.
#111 | Link |
Testeur de codecs
with Bobololo authorization
Test preview: little Matrix reloaded sample 500 Kbit/s Source from Matrix Reloaded PAL 720x576 16/9 MPG2 MP@ML 6150 Kbps chapter 20 to 26. ~2000 Kbit/s with XviD q2 default setting. H264 sample VP6 sample RV10 sample WMV9 sample XviD sample DivX5 sample H264 Ateme setting: -qual extra -rcmode 2pass -br 512000 -deblock 0 -ref 5 -setef wpred -cartoon -psy 1 -priority idle H264: 41.9397 dB VP6: 41.5968 dB RV10: 41.0143 dB WMV9: 40.7542 dB XviD: test in progress DivX: test in progress ... and here my new signature
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 18th September 2004 at 09:38. |
#114 | Link |
Sagittaire used "weighted prediction" which is not supported by the Nero Showtime filters.
Edit : I may be wrong, wait for bobololo's confirmation. Last edited by Manao; 18th September 2004 at 10:42. |
#115 | Link | |
Nice encode Soulhunter. I like that you decided to used an PAL DVD pixel frame size with AR signalling... very cool! The codec copes particularly well will the "flash" transition scenes... Cheers
#116 | Link | |
Confused
XviD changed my mind about encoding, Ateme could do the same... ![]() Anyhow, for "real" backups I would aim for bitrates around 2500 kbps !!! @ All About the final release... I would prefer a simple standalone (AVS2MP4 GUI) version instead of a Recode2 "inbuild" one !!! Bye Last edited by Soulhunter; 18th September 2004 at 10:44. |
#117 | Link | |
Obviously, when generating encodes from short sources, it's difficult to assess how well AVC will perform with an full movie back-up! For those of us who may have 1CD back-ups of say, an 90-100min movie, generated in 2pass DivX or XviD at 720x480 or 720x576 (ie:1:1), I think it would be interesting to generate some of those movies again using Ateme's AVC in 2passes. Personally I've never been a big fan of comparing an codecs performance using anything less than an 1:1 pixel frame size (PFS)... As it's always been my opinion that a codec should be made to work hard and look good when viewed on a big screen.... just as with an DVD. Cheers
#118 | Link | |
Lost in a Byte
I guess they sell their codec to Ahead, it's not a gift and on Ahead side it looks like they love to create a lot of GUIs and spread different functionalities in different programs in a random way :P |
#119 | Link | |
#120 | Link | |
Confused
![]() Btw, Im also not able to play Sagittaire's H264 sample via NeroShowtime player !?! But playback through MPlayer using the Ateme filters works... ![]() @ LostMP4 Maybe as a small bonus that comes with Recode2 then... ![]() Or someone here codes a gui (as besweet/aac) ??? Bye Last edited by Soulhunter; 18th September 2004 at 17:59. |
