Old 10th March 2007, 10:47   #961  |  Link
Deckard2019
No, this will never work!!!
Ok. Wrong copy/paste (I don't use this method as I use BeHappy to bypass RAW/WAV file creation).
But what about ffdshow ? I still don't understand why/when it's used in eac3toac3 ...
Deckard2019 is offline   Reply With Quote
Old 10th March 2007, 10:56   #962  |  Link
madshi
The reason is that the Sonic Audio Decoder is very unreliable without adding ffdshow to the processing stages. I found that the Sonic Audio Decoder sometimes outputs 16 bit, sometimes 24 bit. Furthermore more often then not only 2 channels contained valid information while the remaining 4 channels were garbage. This all doesn't happen with ffdshow in the chain. Don't ask me why. I don't really know.
Old 10th March 2007, 11:02   #963  |  Link
Deckard2019
Ok. Thank you. The 4 crappy channels thing happened to a friend of mine.
With same source, same tools, it doesn't happen to me ...
Outputting directly AC3 from ffdshow is still considered as a wrong method ?
(For now, I use BeHappy/Aften with .grf embedded in avs script. grf only contains orbitlee filter and sonic one).
Old 10th March 2007, 11:58   #964  |  Link
MichalHabart
Yes, ffdshow can be used only for changing bit depth of output. AC3 created directly by ffdshow has wrong channel order
MichalHabart is offline   Reply With Quote
Old 10th March 2007, 12:16   #965  |  Link
Jack-Bauer
Jack-Bauer's Avatar
Matrix filter can be inserted in beetween sonic and ffdshow, allowing to set its matrix as desired.
Jack
Jack-Bauer is offline   Reply With Quote
Old 10th March 2007, 12:54   #966  |  Link
zgx
Well, LPCM does not seem to work at the moment. With xport or graphedit i get raw file with same size but when i use sox to create wav, i receive 77 minutes instead of 100 and the sound inside is horrible (sounds like when you call to fax machine )
Does anyone manage to get it work?
I did get it to work with Graphedit. I selected the m2ts file with File Source (Async) and selected the LPCM track in Sonic HD Demuxer.
File Source (Async) -> Sonic HD Demuxer -> Sonic Cinemaster Audio Decoder 4.2 -> Dump
Then I converted the raw file to wav and got a working file:
sox -r48000 -t .raw -c 6 -3 -s file.raw file.wav
I'm now trying out the new version of xport (since I don't trust Sonic Audio Decoder). It finds a LPCM track and dumps it:
LPCM Audio Mode = 3/2+lfe
LPCM Audio Bits/sample = 16
LPCM Audio Sample Rate = 48000
But don't know what to do with the dump. Have tried all sorts of options in Sox and BeSweet but I can't convert it to a working wav.
zgx is offline   Reply With Quote
Old 10th March 2007, 14:00   #967  |  Link
MichalHabart
Well, that is exactly the problem i have. but it seems that raw dump is not working, i should get 5GB file but i get only 3,5GB. So thatswhy my soxed wav is not going to work. have you tried to load it to wavewizard? it should be able to tell you length and channels in that wav file.
Old 10th March 2007, 14:54   #968  |  Link
drmpeg
The LPCM output of xport is big endian (just like it's stored in the .m2ts file).
This sequence works:
xport -h2 movie.m2ts 1 1 2
sox -B -r48000 -t .raw -c 2 -2 -s bits0001.mpa bits.wav
besweet -core( -input bits.wav -output bits.ac3 ) -ac3encode
This sequence fails:
xport -h movie.m2ts 1 1 2
sox -B -r48000 -t .raw -c 6 -2 -s bits0001.mpa bits.wav
besweet -core( -input bits.wav -output bits.ac3 ) -ac3encode ( -6ch )
Error 58: Error : Unknown Input-File Format : "bits.wav".
Seems to me that sox can't create a 6 channel .wav file that besweet understands.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
drmpeg is offline   Reply With Quote
Old 10th March 2007, 15:00   #969  |  Link
madshi
I don't know. I've read in this thread that it gives inferior results. And I read that Aften is considered to be a good AC3 encoder, so that's why I did it this way.
Old 10th March 2007, 15:01   #970  |  Link
madshi
Aften revision 449 is happy with sox created 6 channel wav files, as long as you use the Aften "-readtoeof 1" parameter.
Old 10th March 2007, 15:24   #971  |  Link
MichalHabart
Ron
And have you tried to open that multiwav in something else, for example in wavewizard?
I was succesfull in this. probably just besweet has these problems. I was able to demux 6 channel lpcm to raw from Terminator 1 Bluray and converted it to wav and now i made DTS track from it. It sounds wonderful
Old 10th March 2007, 19:04   #972  |  Link
The1n
Do i have to change the channelmapping if im just going to convert eac3 to aac in megui, im using graphedit and loads the graph with avisynth script.
When i play the track in graphedit all channels sound ok, but when i encode it to aac multichannel suddenly the center is gone.
The1n
The1n is offline   Reply With Quote
Old 10th March 2007, 19:14   #973  |  Link
zgx
Perfect lossless LPCM 5.1 to FLAC conversion
It's really easy but has taken me quite a few hours to get it all right.
Programs needed:
xport by drmpeg @doom9
http://www.w6rz.net/xport.zip
sox v13.0.0
http://sourceforge.net/projects/sox
Wavewizard 0.45b
http://www.rarewares.org/wavewiz/wavewizardv0.54b.zip
MediaCoder 0.5.1
http://mediacoder.sourceforge.net/download.htm
flac 1.1.4
http://flac.sourceforge.net/download.html
Step 1 - Extract the LPCM stream from Blu-ray
xport -h movie.m2ts 1 3 2
Explaination:
"1 3 2" selects program 1, video stream 3 and audio stream 2.
Since video stream 3 does not exist you will only demux audio (change to 1 if you want video as well).
The LPCM stream should most often be number 2.
Step 2 - Map channels
sox -B -r48000 -t .raw -c 6 -2 -s bits0001.mpa file.wav
Start Wavewizard and enter channel mapping (F2).
- Create a new mapping "0 1 2 5 3 4".
- Select your new mapping.
- Click "Enable channelmapping"
- Click "Convert" and create a new file.
Explaination:
The channels in the LPCM file are mapped "L,R,C,BL,BR,LFE" as opposed to "L,R,C,LFE,BL,BR". This is corrected with Wavewizard but in order for it to accept the file you need to use sox first.
Step 3 - Encode your FLAC
- Install MediaCoder 0.5.1. Make sure you replace "flac.exe" under the "codecs" directory so you get version 1.1.4.
- Drag and drop your file(1).wav to the MediaCoder window.
- Under Audio select "FLAC" as Encoder and press F5 to start the encode.
Explanation:
FLAC doesn't like 4+ GB wave files but somehow it works with MediaCoder.
Step 4 - Enjoy your FLAC
Enjoy your new FLAC!
May I sugest using mkvmerge (http://www.bunkus.org/videotools/mkvtoolnix/) to mux your FLAC with your video stream to a Matroska container.
Old 10th March 2007, 20:38   #974  |  Link
moshmothma
Hmm, I get to the wavewizard part and get the following error when I try to convert:
Error on: "file.wav". This file is not recognized by wavewizard.
moshmothma is offline   Reply With Quote
Old 10th March 2007, 21:09   #975  |  Link
zgx
Sorry made a typo. Should of course be "sox -B -r48000 -t .raw -c 6 -2 -s bits0001.mpa file.wav" and not "-3".
Old 10th March 2007, 21:24   #976  |  Link
LRN
TeMa=) team member
LRN's Avatar
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
I can't beleive they're using LPCM...They must be completely dazzed by BluRay disc sizes! There's NO reason to but more than 500 kilobits on one channel, and if there IS, they could have used FLAC, WAVPack, damn MLP or something! But not the LPCM...it's so DULL.
P.S. How about fullscale "X.1 E-AC3 -> 5.1 AAC" guide?
P.P.S. Where i could get Sonic 4.2 decoder? 4.1 doesn't works in shown graphs
Without effort, you can't even pull a fish out of the pond.
Without a pond you can't pull it out even with effort.
LRN is offline   Reply With Quote
Old 10th March 2007, 22:13   #977  |  Link
Rectal Prolapse
Wow zgx - just what I was looking for! Hopefully there won't be any issues with FLAC audio decoding past the 4GB mark - when I use WAV I get silence once that barrier is surpassed.
Rectal Prolapse is offline   Reply With Quote
Old 11th March 2007, 00:02   #978  |  Link
madshi
Just for my interest: How big is the FLAC compressed audio track file compared to the original LPCM one? Thanks!
Old 11th March 2007, 00:16   #979  |  Link
LRN
TeMa=) team member
LRN's Avatar
20-30%, iirc
Old 11th March 2007, 00:29   #980  |  Link
zgx
About 25% of the original. For "16 bit/48 kHz/6 channel" movie soundtracks I have gotten files from 1100 to 1900 Kbps so it doesn't take more space then a 1.5 Mbps DTS track does. The only downside is that you need 6 analog RCA cables or HDMI in order to get lossless sound to your transciever. You can of course let AC3filter transcode to AC3 for S/PDIF ouput. Then it won't be lossless but will still sound really good.
