Old 27th April 2004, 01:18   #1  |  Link
h00z
anime DVD nut
DVD Rebuilder with Anime?
Has anyone done any serious testing with the newer builds of DVD Rebuilder on anime titles? I'm currently trying to clean a bunch of ISOs off my working drive so I can start with some serious anime testing (nothing like a few hundred GBs of ISOs laying around), but I was wondering if anyone has had any luck.
I'm mostly concerned with the deinterlacing/IVTC issues and how they're handled by the app. So far I am completely sold on Rebuilder, and if it can do anime... That'd be all the better.
my machines : my retail anime DVDs
h00z is offline   Reply With Quote
Old 27th April 2004, 01:29   #2  |  Link
Joergen
Posts: n/a
Why couldnt it?
Though I'm in PAL and the closest to anime I've done so far is the anime section of kill bill but it came out spot-on.
Animation is easy to compress afaik since it has wast still areas of pure flat color. This is especially true to rendered animation like Shrek, Ice Age etc.
Old 27th April 2004, 01:31   #3  |  Link
nwg
The anime sections of Kill Bill turned out fine (CCE). I have also done Spirited Away as well. That was with Rejig
Is that any help?
nwg is offline   Reply With Quote
Old 27th April 2004, 04:08   #4  |  Link
h00z
anime DVD nut
Anime actually compresses much worse than normal "live action". It's not the big patches of blocky color, it's the sharp edges that make it difficult.
Edges are the hardest thing to compress correctly and anime is full of edges. Anyone who has tried to encode anime (DivX, XviD, DVD, whatever) will know what I'm talking about.
One anime scene in a Hollywood flick isn't nearly enough to judge. I guess I'll just have to do some serious testing of my own.
Old 27th April 2004, 04:15   #5  |  Link
quantum
Titles like The Simpsons episode disks were very hard to handle using big3 as I recall. There were ivtc and interlacing problems and I eventually fell back to using transcoders for these.
Hmm. Maybe I'll stick in the Simpsons Season 1 original disk and see how DVD Rebuilder handles it...
quantum is offline   Reply With Quote
Old 27th April 2004, 05:39   #6  |  Link
esso
Hey all, 1st post. i've done a couple of animes (last exile, Yukikaze, abeno abashi, Escaflowne), all ntsc, and i've had quite a bit of problems with sharp edges and interlacing. It may be just how it was made, some come out fine, others i do with DVD Shrink. i do hear ya hooz on the encoding with divx an all, (hated that). don't know if this helps and all, oh yeah! sorry, the last time i tried RB and an anime was v.35 havent since.
esso is offline   Reply With Quote
Old 27th April 2004, 16:37   #7  |  Link
legomen
well I'll run some tests on various animes today using v.45 and see how well they do.
legomen is offline   Reply With Quote
Old 27th April 2004, 16:58   #8  |  Link
CiViC
Well, i did the trigun dvd's and it came out fine. I don't remember which version of DVDRB I used (it was 0.4x).
BTW, this is originally an 8 disc DVD-5 set..but since i'm cheap, I combined sets of 2 discs to 1 (for a total of 4 dvd's), and sent it over to DVDRB. The result was flawless, which was good considering I couldn't even ivtc it properly with dvd2svcd (and i'm not about to manually select the frames for each dvd just to create "proper" svcds).
CiViC is offline   Reply With Quote
Old 28th April 2004, 05:37   #9  |  Link
zeus163
I did GTO volume 1 and thought it came out great (with version 3.8). I haven't done another anime DVD since, but will on some of my new and cheap Right Stuff purchases when I get them.
zeus163 is offline   Reply With Quote
Old 29th April 2004, 01:03   #10  |  Link
h00z
anime DVD nut
I started my testing with a (relatively easy) re-encode of Wild Arms disk 2. I'll know in about an hour how well it did, then I'll move on to something more difficult.
Old 3rd May 2004, 17:28   #11  |  Link
Joergen
Posts: n/a
I have to admit, DVD-RB could have some settings for anime titles.
I've been trying to encode Titan A.E. SE R2 that is true progressive, and I've had to tweak the average bitrate for the main movie up to 5300kbit and its still not quite enough for all scenes, but I cant go higher as I've already put the extras to 1500kbit half-d1 with ecl optimizer.
The biggest problem is mosquito noise and some block noise that follows certain shades of colour and edges.
CCE does have settings for animation that might help, maybe jdobbs could build special settings for anime in the AVS Setup.
Old 3rd May 2004, 18:08   #12  |  Link
DDogg
Retired, but still around
DDogg's Avatar
Joergen, you might just try putting undot().Deen() in the main avs's. This normally yields a 20-25% reduction in required ABR, but may not do as much for anim.
To test the effect without doing the whole encode you can make a quick avs using the entire appropriate d2v in the rebuilder directory adding SelectRangeEvery(1200,12) to the end. If you will run that with a fixed Q, say 28, you should be able to identify the percentage of reduction the filtering will make and be able to judge any effects from its use by previewing the resulting samples. Also, you will know the quality that will be generated in advance of doing the encode. Anything up to a Q40 ought to be decent if you have to go there, IMO.
To derive the bitrate of the two resulting samples use this.
As you know, there is a point where there is just not going to be enough BR to allow full DVD replicas of some problem encodes. At that stage you have to use filters, or go to 1/2D1 on the main which is of course the last resort.
This is why we need a way to use filters in dvd-rb when required.
If an optional feature, perhaps an INI entry, requested DVD-rb to place a generic but named import line directly after the mpeg2source line we could do this so very easily without the grudge of manually editing a ton of avs files.
In this case, placing the line 'import ("myfilters.avs")', would import myfilters.avs which would just contain "Undot().Deen()" or whatever you desired. That makes it as if you actually typed those lines in the real avs. Jdobbs said he was looking at this way back. I don't know what became of it.
Alternatively, does anybody know of a commandline or program that can alter every avs you specified and add a line in a certain position? That would be very useful to many of us.
From avisynth docs
Import (string filename)
Import evaluates the contents of another AviSynth script.
This is useful for storing multiple script-functions, global variables, and pre-built streams. Strictly speaking it is a script function and not a filter.
DDogg is offline   Reply With Quote
Old 3rd May 2004, 18:34   #13  |  Link
Joergen
Posts: n/a
Sorry, but most of that is beyond me
I'm pretty happy with the results I got from the last encode but I suspect the available bitrate could be used better. There are some scenes that are somewhat blocky with no apparent reason (midtone scenes with nearly no movement or film grain).
But if you could work those into preconfigured AVS options for dvd-rb that might yield better results for animated titles, I'm sure people would appreciate it.
Old 3rd May 2004, 19:45   #14  |  Link
DDogg
DDogg's Avatar
Just go stick Undot().Deen() after your mpeg2source line in every avs of the main movie and then re-encode. You would have to have undot.dll and deen.dll in your plugins dir and it will slow down the re-encode btw.
There has got to be some utility to to do this automatically out there somewhere. Like this:
# AVS File Created by DVD Rebuilder
# VOBID:01, CELLID:07
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MPEG2Dec3.dll")
mpeg2source("D:\WUTEMP\D2VAVS\V12.D2V")
Undot().Deen()
trim(31734,32942)
ConvertToYUY2()
AudioDub(BlankClip())
Old 3rd May 2004, 20:11   #15  |  Link
Joergen
Posts: n/a
Perhaps quantum could incorporate this into RBFarm since it already parses the segments in some way. I can test the resutls easily by adding that to one segment AVS and running it's RBFarm .ecl.
edit: Ok I tried a short segment with undot and deen and compared it to the original encode (withouth these) in dvd2avi and although this quite nicely removes mosquito noise and flattens out areas, imho the effect is perhaps too strong (smart blurry) and removes detail.
I'm against post-processing though. Since the source is very clean it would be best if CCE itself could be tweaked into producing better encodes.
But I can see undot+deen could be added as a cleanup filter into dvd-rb if people so choose.
Old 3rd May 2004, 21:35   #16  |  Link
quantum
Try the animation filter in CCE. Load an ECL and resave with the filter settings and encode. I suggested to the ECL Optimiser author that adding CCE filter settings would be a nice addition but he hasn't bought into it yet.
Maybe some day I'll think about coding up another add on.
Old 4th May 2004, 00:49   #17  |  Link
Joergen
Posts: n/a
The animation filter built-into CCE is what I'd like jdobbs to enable/disable like other features now.
But luckily it looks like I was overcritical of the encoding quality. It's hard/impossible to evaluate the timeline of scenes in animation while scrolling in dvd2avi and the scenes I was worried about are so fast on playback that you dont see the difference.
Plus the half-d1 option combined with ECL Optimizer manual bitrate setting gave me 4.36GB output, and as the original extras were VERY blurry (bad ntsc->pal conversions) you cant see the difference there either!
Another brilliant DVD-RB backup.
Old 4th May 2004, 01:00   #18  |  Link
DDogg
DDogg's Avatar
quantum, if you would consider doing a quick hack to just insert a single text line into a group of avs I would be in your debt. Heck, maybe even a 3 beer debt. I would love to pay off that toll.
I have a funny feeling there is actually a way to do this with a dos command, but my memory has faded a tad over the last few years.
Old 8th May 2004, 00:12   #19  |  Link
thedeath
I tested Spirited Away (PAL), and it was a great result. No Problems,
just a HQ-Copy of it.
Greetings,
TheDeath
thedeath is offline   Reply With Quote
Old 8th May 2004, 07:07   #20  |  Link
dragongodz
dragongodz's Avatar
also you dont have to use both undot() and deen(). you could just try using 1 of them, or any other denoiser for that matter. most do have settings for strength aswell(i havent looked at or tested them all of course) so that can be adjusted to your personal preference.
if edges look a little blurred then you can add Blur(-0.2) for some general light sharpening. i actually prefer MSharpen for anime(with slightly lighter than default settings) but its not exactly fast.
dragongodz is offline   Reply With Quote
